Gt35r Vs Garrett T04z - Discussion (just Post In This Thread To Create A Database)
Dcieve on these forums made 400rwkw on a 0.8 gt35, it had abit more than 19psi but they can definately make the numbers and from the best of my knowledge his doesnt have any headwork at all, only a set of poncams.
i dont think you realise what you are sayiung.
im telling you he did not make 400kw on a .8 gt35r
i think i do mate, and the actual dyno he used is known to be very low reading as well, it would make around the 550rwhp+ mark (417rwkw) on most dyno dynamics dynos in Perth . Its in a r31 and runs 131mph on the one pass he did before he broke the axles. I aint making it up its proven :/
put the cars weight in the drag calc (around 1440kg or so with driver from his last weigh in) and it says 420rwkw for 131mph! The drag calc is almost spot on for every other car ive put in.
Noel (FineLine) made 520hp (damn close to 400kw) with a gt35r .82ex on an rb25... also has an 11.2 @ 126mph (if i remember correctly) to back it up
That's a fantastic effort there rezlo. Do you have any more specs on the car? Looking at your sig it seems like you put a rb25 in your silvia? No rb30? Ported?
How much power did you make with the t04z?
Another GT35 example 455 rwhp @ 17psi on a stock RB26(just ecu + injectors).
Car has run 10.35 @ 128mph.
I actually have a t04z as well but am finding it hard to justify upgrading when there is so much more left in the GT35.
Graph scale is a little off redline is actually 7800 so move everything back about 200-300 rpm. Also boost controlled with $50 bleeder.
im totally with ya there buddy.
im trying to reach the 400kw mark and find ti very hard with a gt35r, but alot of ppl are saying its possible. so before i buy a to4z i want to make sure 100% the 35r is out of puff.
That dyno is a customer of mine. Basic RB25 build with some mild porting, CNC blended combustion chamber, greddy intake mani, hand build exhaust mani ectr... its in a S13
I ran the identical combo in my S14 (besides the CNC blended chamber) and when I upgraded to the T04z twin scroll (I sold my GT35 to him) it was a massive change, the car is more responsive, more mid range and faster spooling and at 2 bar its more fear than fun (it is still loosing traction at over 140mph on 285's at only 1.8bar -
There is nothing wrong with the GT35, its a great all round turbo thats easy to get good numbers out of, that said if you take the time and run the right manifold setup on a T04z it is a fantastic turbo....
Having owned and driven both turbo's on the same car, same managment, identical motor ectr what would i built my car again? T04z again,,, all day every day. That seems to be the general outlook, the guys that run T04z's on GOOD setups love them, the guys that talk shit about them most likely have never been in a properly setup T04z, that or they try to defend their purchase of a GT35 and aim for a lower power rating.
So again, I like the GT35 (especialy on SR20's and 4G63's)but I think results in a T04z all come down to setting it up right and when setup right it will outshine the GT35.
If you've run them back to back where are the plots to back up the claims?
I've compared plots of a properly setup hks t04z on a full house jun 2.7 and it makes a bucketload of power but I wouldnt in any way suggest its more responsive or has better mid-range than the smaller gt35.
So your telling me you know my car better than me and i dont make that sort of power just coz you cant do the same with yours?????
It run 170km/h in the 1/8mile, whats that tell you??
    • I can't agree. If we hadn't all been brought up with the noise caused by the inefficiency of an ICE, no-one would actually ask for all that. An EV is like any other car, it just goes better.
    • 2 more things I have to work out Easy one first...can anyone describe how to pull the fuel pump and sender from a 33? I can feel there is some sort of mount and clips but don't have a manual and don't know the trick......if not I'll spend some quality time in the boot witha lighter tomorrow. Second question is harder.  He had changed the upper plenum to a plazmaman but clearly got to a point with the vacuum hoses where he said "f**k it, I'm going inside for a beer" and never came back to that job because it was a mess. Am I right to think that I need: 1. Pre throttle (16mm nipple on inlet) to AAC's main 20mm fitting as the main pre throttle feed 2. ACC has a second 13m outlet joined to that 20mm fitting which I think is the pre throttle air supply for the cold start valve? 3. Cold start valve's outlet fitting then goes to Plenum (to bypass throttle?) There is some adapter on the back of the ACC with 2 fittings (13mm and 10mm), do I run the 10mm through a 1 way valve to the Brake Booster (4) and the 13mm back to a 13mm nipple on the Plenum as the Idle control (5)? 6. Run a 6mm vacuum line from the Turbosmart BOV to the Plenum? 7. Run a 5mm vacuum line from the Fuel Pressure Reg to the Plenum? 8. Run a 5mm vacuum line from the Turbosmart Boost controller to the Plenum? (Wastegate already has a pre turbo pressure source running to the solenoid then the wastegate on the other side of the bay)  Any help appreciated, the GTR is quite different setup and while the Stagea also has FFP it is different again. (And no Dose, I'm not pissing it all off and putting a ethrottle on it....)
    • OK, onto some questions to try and speed up the process a little. Does anyone know what core this Garret is? I know it is a high flowed standard turbo but nothing else about it. Tag says OK 0169J - 446179-5032 Same question for the injectors, I don't know what they flow and ideally can work it out before it hits the dyno, they are a mustard yellow side feed
    • Quick side trip into the engine externals, alternator and PS were in place including tensioned belts, but the PS was dry (my guess is he had the steering rack reco-ed). Filled it up with Transmax Z but it will need more bleeding once the engine is running no doubt. BTW I've said before, I don't know what kind of soft animals you have in the city, but out here they breed the rats tough. I bet they were disappointed when they tasted synthetic ATF.... Coilpacks are Splitfires with a factory loom in reasonable condition. I didn't pull one put I bet the spark plugs are new as its a new engine
    • Onto intake pressure test. I have a Raceworks (damn brand thieves!) pressure test adapter that lets you apply pressure through a standard tyre valve and comes with a pressure gauge.....I just blocked off the other end immediately before the throttle body. Applied 30psi....and the turbo intake immediately popped off with a bang. Sorted that but it was still leaking, turns out there is a pinhole leak at the BOV adapter that I'll have to find a local place to TIG up. I'm sure it makes SFA difference with such a small leak but I want it to be right. Everything else up to the throttle body was good. Also cleaned and oiled the KNX cone filter, and this is the AFM if anyone can identify it (car runs a PowerFC)
