Gt35r Vs Garrett T04z - Discussion (just Post In This Thread To Create A Database)
Cerbera's car has been parted out for about a year, so the T04Z run is a little old.
We're stumped as to why it's restricted. The only thing we can think is the head I'm using (off a 34 N1 motor) has a few imperfections in it which is causing turbulence. I'm using a china manifold, but the same type on Natalotto's car did 630hp with a T04Z. Exhaust is fine, intake is free, plenum is stock, cams are pretty big (270x10.8).
Disco, I'm using the GCG T04 rear for the 35. It's a T4 flanged 0.84 housing. I don't think the rear housing is the issue to be honest.
I would assume that a R34 N1 head stock would be better than or at least on par with my 89 shitter standard head, i'm still thinking it is the manifold. I remember back in the day Natalotto had heaps of problems with his china manifold and they did extensive modifications to it to get it working right. I dont know if Brockas has done anything to his?!?
I agree the boost is all over the shop, ramps hard then creeps and then falls over... which to me points at a manifold issue!!!
my t04z run is about 2 years old, still same dyno, same operator etc etc
Manifold hasn't been touched yet. Simple china shitter ceramic coated and bolted on.
It has a gasket leak on the exhaust side anyways, so the manifold has to come off. May see about modifying it while its off.
i was looking into the to4z with a 3litre bottom end on a 25, personally i think its a bit too large for track, big turbos tend to be slow on track cars, leave larger turbos to the drag racers is my advice. Go Hks GTSS, fantastic turbos for track and relatively tight courses....
I had the pleasure of driving a T04Z'd 25/30 in a 32 GTS4 a couple of weeks ago on the skidpan. Bit laggy compared to the GT30'd R33 I also got to drive, but, when it comes on boost.. HOLY SHIT.
Edited by bubba
that mikes new settup?!? how much power did he end up making?
Just got back from the workshop.
Compared my GT3582 setup (blue line) with a Cerbera's T04Z setup (green line), which were both run up on the same Dyno Dynamics dyno in shootout mode.
Not sure if Simon's had any issues, but my setup is strangled HARD in the top end. So much so, that adding 5psi and 2 degrees ignition timing gained me a whole 1hp up top. Did gain about 30hp through the mid range though, but I obviously have a large restriction in my inlet/exhaust which isn't allowing any more than 500hp flow.
Anyways, enough ricers excuses, here is the comparison:
Thats a perfect comparison.
You gain up to 60 hp more through the low - mid range. For a top end trade of of about 70hp.
I actually think you would find the two cars down the 1/4 would be very simular in times.
You have the big advantage though as your car would be more driveable on the street / track.
Be interesting to see once you have the issues sorted out.
How the top end power would compare on the same boost levels.
If you end up only trading 30 or so top end HP for a midrange gain of 60hp you will be well ahead.
Yup, but after 6 months of the car being off the road, I'm not touching it again for a while, so will have to make do with that comparison.
If I get the motivation I will fork out for a 6boost manifold and see if that makes a difference.
The manifold is the cheap solution, the head is not so cheap. I'm hoping that with the boost dropping off, that indicates a manifold issue.
yeah 3.5-4.5k about a average of 35hp more but from 4.5-8k about a 50hp average more
i dont know what crack you have been smoking butters, but when do you have revs less than 4.5k down a quarter mile :(
i remember the difference in speed of my car on lowish boost (19psi 510rwhp) and high boost (24psi 574rwhp) was not even comparable... 510 was fvcking fast, 574 was just scary :)
  • 2 months later...
Reviving this one once again. Looking for some opinions on the following, given the choice of a 3582 1.06 twin scroll or the equivalent sized borg warner s300sx (83/75 I think) both on a proper twin scroll t4 flanged manifold - which would be the more responsive while aiming for ~500rwhp.
nick have a look at nytsky's engine build thread
he is using a 3076r on a built 25 and making 485rwhp with e85 and an amazing power curve, i'd imagine your motor could make a little more...
i would be thinking along the lines of a 3076r with a 1.0ish split rear
Edited by Cerbera
I would be going for the TS Gt35R, definitely. I am not convinced on the BWs yet - they COULD be really good but there are contrasting results for them, while the GT35Rs are a very known quantity.
That was going to be my next question, full race are the only ones I've found so far - and at 6-700 delivered (exh housing only) it's looking like buying a whole new turbo will end up cheaper.
Edited by DCIEVE
i think a 3076r with a 1 housing would be pretty awesome suited as simon suggested. With correct setup in a lightweight r31 it would be nuts, mine seems to be abit better now with new exhuast and in a lighter car i could see it be pretty damn good (ill find out soon enough). Ill have to take you for a spin and show you how it goes and response and then u can decide for yourself and mine isnt even sorted properly. Surely a 450hp setup with awesome response would beat a 500hp setup with a fair bit more lag on a track.
on another note, the sloth (scradly) just made 430(allstarhubberlovehp) the other day on a stock neo with cams and a 3076r 0.82 with only around 17-18psi boost with awesome response
surely a built 26 with another 6psi could smash out 500+
DOOOOOOOOO IT
    • Hi all,   I’ve got the biggest lot of problems with my R33 GTS-T   It was a freshly rebuilt 25th anniversary RB25DET (plastic cas, neo cams) probably 6 years ago now   The engine was running so well but I fkd up badly and trusted someone I’d known for 10 years that was well known around Plazmaman for his welding and fab work. I added a lovely photo of some of his previous work. Not sure why my car was worked on by whoever did this shit     I’m normally someone who would never open myself up to something like this, I still can’t believe I did it. Trusting him literally fkd it all up for me. Everything has been a struggle, like it’s almost been 6 years that’s how much I’ve just on and off been trying to work it all out.    All I wanted was a car that danced down low, like full boost from around 3~3500rpm to redline, don’t really care what power it puts down (if it ever does) but I just wanted it to be quick to get on it.    He recommended the turbo to get, I picked Hypergear but he told me to get the front 4” with a T4 and 0.68 rear housing.    I was expecting all these beautiful welds, tidy fab work and paid for it to be ready to go to a tuner when I got it back.    I got a car back that was an absolute mess, I actually couldn’t believe it was my car anymore. I don’t think you could even call what he did welds, they’re disgusting.    So I stripped everything he touched off it and with every bolt I loosened it just got worse and worse.    I covered it and literally built and finished another car in the meantime but now it’s getting to the point where I really want my Skyline back.   Its a struggle because I paid him to do all this shit because I didn’t know how to and now I’ve had to try and figure it all out omg    Please excuse the bird shit horrible welds, I’ve got my show pony car and am so beyond dealing with this car I don’t even really care at this point.    If someone told me about what he did to my car I wouldn’t have believed them but it happened to me. It was unbelievable. He went missing, my car went missing, it came back missing parts, the straight af chassis rails bore the scars of being dragged up a trailer backwards, even the sandwich plate was bent. Everything was leaking and open to whatever fell into it, rounded off/ missing bolts, power steering oil and coolant everywhere, no gaskets, parts stolen off it, even managed to damage the sump pan.   Promised me he’d finish the car, knew what it meant to me, I paid him thousands and thousands just for him to trash it. He told me he was fully licensed and insured, come to find out he’d cancelled his ABN, so obviously no insurance. I had laid up insurance on the car and would’ve been covered but I was scared they would’ve written it off or because the business was no longer trading I’d still be liable.    He was supposed to:  New fully custom mild steam pipe exhaust manifold with turbo location moved from factory position to high forward mount. (I don’t know if it is a mild steam pipe, I’ve got a funny feeling the waste gate isn’t in a very good position and I don’t think the outlets off each cylinder are equal) 4” custom stainless steel dump with external gate (he re-plumbed it) Cut and shut OEM intake manifold with throttle reposition (I ended up doing the throttle reposition) Box in pod filter (left out) New 100cel catalytic converter (pretty sure it’s there but unsure if it’s 100cel) Front mount intercooler piping fabricated to suit (all smashed up and rusty holes where he was supposed to make it look standard where fmic piping passes through. I don’t even think my front bar is going to fit 🙄) Custom 5” intake pipe from pod to turbo (didn’t come with it so had to do something to make it work with the Z32 afm)   Engine: Full cylinder head service & machining  Brand new valves Precision upgraded spring kit Engine block honed New bearings  New piston rings  New ARP conrod bolt kit New ARP head studs Cometic head gasket VRS kit   ATR43SS2 ball bearing turbo 0.68 rear housing  Turbosmart 45mm external wastegate (got delivered to the fab bloke, I’ve got no idea what spring is in it, I’m assuming the one that came pre installed) Walbro 260 fuel pump  Nismo 740cc injectors (tested to 880) Spitfire coil packs GCG FMIC RB25DET manual 5 speed 4:11 rear diff   I’ve got an Apexi Power FC in it atm, I was hoping to just get it to operating temp to make sure everything was okay before towing to a tuner but it’s over-fuelling too much. I don’t think that’s going to happen so i think I’m going to get either a Link G4 or Haltech for it. What do you guys recommend? I can’t work out the power FC so just gonna give up on that one     It’s got an exhaust leak coming from somewhere I can’t see 🙄    The fuel pressure was steady but now it like drops from 40 to 20psi randomly (noticed this yesterday)    I’ll attach pics of the shit he put on my car and the engine bay now as it sits    I really just need some help, I need a tuner in Sydney I can trust, I’d like to be with the car while it’s being tuned if possible, I know it looks terrible but unfortunately I’ve just got to put up with it for now and fix the cosmetic stuff later   Do you guys think the manifolds are going to be okay? Or do I throw the exhaust manifold and try again?   I don’t even think these combinations are going to work tbh   I know everything I fitted was rated to be able to take at least 400kW but most rated higher    If you’ve gotten this far I really really appreciate it 🙏 I don’t mind if you trash me or the car, I made a rookie error and f**k I’ve paid for it. As you’ll see 🙄
    • From everything I’ve heard you’ll be waiting a long time for  the parts to arrive
    • Have you looked at the workshop manual?
    • Hmm. I've gotten pretty good outcomes from talking to them about things that I've had go wrong or ideas for improvement. Have had a lot to say about the R32 FUCAs, and they have sent out some replacement parts for those, gratis, on a couple of occasions. Mind you, I have bought a couple hundreds of $ of replacement rod ends for them too!
    • I have a r34 sedan 1999 manual converted need some help with my speedometer it only reads upto 98km and then stops currently still running the auto cluster any easy fixes no speedo drive is connected yet, if someone has a video for wiring up the manual speedo sensor with the auto cluster please send through
