Gt35r Vs Garrett T04z - Discussion (just Post In This Thread To Create A Database)
Did Paul tune your car? Is that the Twin scroll or just a single entry? Have to let me know how responsive it is etc
yes, twin scroll...
Not super responsive, not that you can complain 400kw & 2.6L would never be. 4,***rpm (haven't been driving it much) until it starts pulling hard..
It's definitely use-able when you put in the effort & keep it at high revs..
35R mate :rant:
Getting greedy are we......35R is suited to a 3L imo, is yours 3L cant remember?????Altho my mates 25 with a 3582 is pretty awsome (top end to burn) i'm sure you will be more than happy.
Still a 2.5L.
It was a hard decision and something i thought alot about. Ill give away about 400-500rpm in response but will be close to making 600rwhp.
Should be finished with the swap (amongst other things) late Jan.
Good luck with it Nytsky, you have spent the money where it counts so i'm sure you will get the results your after.......Keep us all posted on the results won't ya.
lol there are so many things wrong with that dyno graph i dont even know where to start
lol wow... its like... a dyno run in reverse the graph is that poor... dear me. I'd be sacking that tuner!
Still a 2.5L.
Nice! Will be good to see how it goes, especially if you go the E85 path again. With a twin scroll T4 GT35R you'll probably lose very little response.... I'm kindof umming and ahhing about go that way :D
WOW is right...
I think we just agreed on something, it might be a merry xmas after all :D
Yeah well it's never going to look like a proper run when it goes on the dyno with low compression....
won't be pulling it down till January but..
Even with low compression - on all 6 cyclinders?
WOW is right...
lol indeed :(
Thats the way i wanted to go, TS GT35R. But id have to get a new manifold made and mod the dump a little. Would be a great combo though.
Due to cost and ease of change over i got the single entry .82 housing, with the new .70 surge slot cover :(
Basically a straight swap, using the same fittings and lines. And it will be on E85 of coarse.
Just for interest for those reading,
Max power per each of the below?
GT35 .63
GT35 .82
GT35 1.06
GT35 .78 TS
VS: T04z
T4_Divided .70
T4_Divided .84
T4_Divided 1.00
T4_Divided 1.15
T4_Divided 1.32
T4_Undivided .61
T4_Undivided .70
.81 A/R T4 Undivided with 3" V-Band outlet
.96 A/R T4 Undivided with 3" V-Band outlet
Well... here it is...
This is as even of a comparison as we could manage. Bolted off a GT35R (red line) and bolted on a T04Z (blue line).
Graph makes it seem like its a laggy bitch, and the T04Z setup is shit... to be honest I'm not sure yet. The Z is so much fun, but not sure if it'll be faster than the 35R on the track (I doubt it). May end up going back to a 35R at some stage, but going to enjoy the extra top end for the time being...
RPM limit was increase to 8500 to account for the extra 500+ rpm of lag.
Would be a lot better if the wastegate wasn't shit and ramped as hard as it should...
Edited by Brockas
Ye i was going to say it looks like boost control could use some improvements - but at least its using the same boost control setup through both runs.
You really should get that fixed, would make a very noticeable gain :)
GT35 FTW! :D
great to see the back to back result, would bee good to see the power the gt35 would make with the same amount of boost as the to4z.
Interesting to see it lost 110 HP through the midrange to gain only 80hp top end.
If the gt35 didnt taper off boost so much in the higher revs the top end power figures would be alot closer.
Edited by sky30
Would have been good if the boost levels were identical......and your wastegate woes fixed ..........for a true back to back comparo.
Great comparison anyway for the purposes of this thread.
GT35 Wins !
At the same boost level that top end power gap would be less.
Interesting that you changed the limiter too ?
I assume thats to give you a bit more power band.
Engine life would now be reduced.
Mind you, all that said. The top end power of the Z would be damn sweeeeet :)
Using the same boost level is i dunno, arguable.
Remember the turbo's have different areas of efficiency and so on.
Best of running them both where they both perform best and comparing off that IMO.
    • Getting Dangerously close to being ready to go back in the car. Rockers in with clearance castings now (and a quick check with the USA for the torque settings for the larger custom bolts) Covers and ported FAST Manifold sitting on there. Not fully tightened down as there's some clearancing required for the water pump with the earlier LS1 water pump styles. Example of the clearancing needing to be done: The body has to be ground a little but I'm struggling finding an actual piece of it. The later variant of water pump resolves the issue as the manifold was designed around it. It only came on the VZ LS1 in Australia, it got a different pulley for Gen4 motors. (it also costs $450... vs... $0).
    • https://files.fm/f/5atwkuvcjd
    • Doing some height adjustment on front suspension on a v35 and noticed this. The passenger side looks correct. So wondering what's happened to the drivers side?
    • Oh...I have the electric mirrors as well iirc ...they're in the same state as just about every other R31 door mirrors, with the 3 plastic screw towers broken/cracked in the plastic molding. All the interior is 'dry', so the mirror switches etc likely all work fine. Some pics below of the trimmer pieces ~ looks to me like previous owner, painted chrome finished trims with black paint ...ergo, the chrome underneath is likely a-ok... ...starts to look yukky posting stuff like this, how much did it cost in fuel on your last sortie up this way?...me just thinking aloud, borrow someone else's 4cyl to cut costs, come do your own pick'n'pull like before to save me some bother...hehe.. but whatever, I'll just earmark bits I know you want, because the way this is all panning out, I'll be able to retire the R31 from daily duty at long last, replacing it with a Subaru wagon I'm lining up in the wings...ergo, my attitude towards the donor pinny shell is starting to wane a bit, and I'm more than happy to help you out there... Like you say though, no rush...and I'll guarantee we won't be moving too far from this locale at any rate 😎
    • Cool, I’m just down Sydney today. Not much time to get online.
