Gt35r Vs Garrett T04z - Discussion (just Post In This Thread To Create A Database)
Brockas mine will be being re-tuned in the next week or two aswell so should have another 26/to4z to compare too.
using a turbosmart 48mm and avcr.. so will be interesting to see the boost curve aswell, what wastegate are you running?
Good to see a back to back comparison there. Even though the setup could be improved, presumably the improvements would effect both dyno plots. the results are pretty much what I expected - 500-600rpm more lag, 70-100 more hp in the top end.
We are pulling the t04z off my car in the next few weeks and we're going to put on one of the new GT3788R's. Should be very interesting to see what it can do. I will try to get back to back graphs.
The graph of 1bxx056 looks pretty much identicle to mine. Would be good to see that overlayed against a really properly setup 35r on good manifolds etc.
That would be tops !!
Are the GT37 available in t3 rear housing ?
GT35 FTW !
Just got mine done, Injectors now all in and tuned up.
Was tuned by Andy at hyperdrive but run up at allstar due to some wheel spin fun.
Now 561 rwhp up from 450rwhp !!
20-21 psi boost.
Still a stock jap import RB26(including stock cams n cams gears) with just bolt on gt35 turbo and injectors.
http://www.youtube.com/watch?v=62ze0NXMWBU
This car has gone well over 600rwhp on an RB25 with GT35 and E85, Ultra reliable engine into its 4th season racing, we run it at 600rwhp as its a very basic RB25.
RB34 coming this season with a Housing change on the GT35.
Here's a copy of the graph.
With a built motor i'd be enjoying this all day every day :rofl:
Mmm is that more then Cerbera's Built 26 with T04z ?????
Edited by Butters
With a built motor i'd be enjoying this all day every day :)
SMD simmo!!!
but yes that shit is impressive, why did you abort run?!? PING PING PING PING :P
Thats a very interesting change to make - what motivated that, and what are you hoping from it vs the T04Z? Are they both T3 flanged? I've often wondered about the GT3788Rs but not been too sure on what to expect... a comparison I've always been very curious about is the GT4088R and the T04Z.
my t04z is a split pulse t4 flange - same as the GT3788. The 4088R is a bigger turbo than the T04Z (compressor and turbine) so it will flow more HP, with a tiny bit more lag.
Main reason for doing the swap is simply that the Z is too doughy out of medium tight corners around the track. IE: turns 3/4 @ QR I take at about 80km/hr. 2nd gear == massive tailslide on exit, whilst 3rd gear == LAG all the way out of the corner. Hopefully the new turbo is not only slightly more responsive, but a lot more linear in power delivery. I make 1 bar at 4100rpm with the Z and 24psi at 4500. Thats not too laggy, but as soon as you go below 4000 rpm there is absolutely nothing there. I wouldnt care too much if the 3788 only makes 1 bar at 4000rpm as long as 3800/3900 still had SOMETHING available unlike the Z which comes on like a lightswitch once you get over 4.
The only unfortuante thing is that I wont be able to directly compare how the 2 turbo's would have worked on the track as I'm making some other significant changes to the car at the same time. So wont be able to say if the 3788 is soley responsible for better lap times, but hopefully combined with everything else we are doing it makes a big difference.
Still probably a couple of weeks away from doing the swap - will see how we go.
    • Getting Dangerously close to being ready to go back in the car. Rockers in with clearance castings now (and a quick check with the USA for the torque settings for the larger custom bolts) Covers and ported FAST Manifold sitting on there. Not fully tightened down as there's some clearancing required for the water pump with the earlier LS1 water pump styles. Example of the clearancing needing to be done: The body has to be ground a little but I'm struggling finding an actual piece of it. The later variant of water pump resolves the issue as the manifold was designed around it. It only came on the VZ LS1 in Australia, it got a different pulley for Gen4 motors. (it also costs $450... vs... $0).
    • https://files.fm/f/5atwkuvcjd
    • Doing some height adjustment on front suspension on a v35 and noticed this. The passenger side looks correct. So wondering what's happened to the drivers side?
    • Oh...I have the electric mirrors as well iirc ...they're in the same state as just about every other R31 door mirrors, with the 3 plastic screw towers broken/cracked in the plastic molding. All the interior is 'dry', so the mirror switches etc likely all work fine. Some pics below of the trimmer pieces ~ looks to me like previous owner, painted chrome finished trims with black paint ...ergo, the chrome underneath is likely a-ok... ...starts to look yukky posting stuff like this, how much did it cost in fuel on your last sortie up this way?...me just thinking aloud, borrow someone else's 4cyl to cut costs, come do your own pick'n'pull like before to save me some bother...hehe.. but whatever, I'll just earmark bits I know you want, because the way this is all panning out, I'll be able to retire the R31 from daily duty at long last, replacing it with a Subaru wagon I'm lining up in the wings...ergo, my attitude towards the donor pinny shell is starting to wane a bit, and I'm more than happy to help you out there... Like you say though, no rush...and I'll guarantee we won't be moving too far from this locale at any rate 😎
    • Cool, I’m just down Sydney today. Not much time to get online.
