Gt35r Vs Garrett T04z - Discussion (just Post In This Thread To Create A Database)
i just brought a new gt35r 1.06 rear from Gcg $1500, ill be using this turbo for my rb2630det..
(hoping to push close to 400rwkw then straight to wsid to crack a 10.99 1/4 mile) lol
Any of the merge collector manifolds are a good bet, just make sure the scavenge for the wg is on a reasonable angle (ie not perpendicular) and a decent size.
Have any of you guys debating between the two of these turbo's considered Borg-Warner's? They have a few that would fit right in between the power ranges of the GT35r and TO4z.
T04z RB25
Some mess about fun on the way back from work,
The video car (S14 SR20 running my old GT35 @ 1.5bar) and myself just mucking about, fueling still quite heavy from the drag event on Saturday (run with a 100mm turn down for drags and 76mm for street (legal rubbish))
As ive said earlier in this post, I have ran both turbo's on the same car with the same setup, everyone likes somthing different, I prefer the power delivery of the T04z.
I was running 1.8bar in those clips.
Edited by Rezlo
heard good things about that turb'- would like to see a before and after dyno chart for an engine that swapped a T04Z for one with no other mechanical changes.
yeah, a bullseye s362 would be my pick. the fact they can run over 50psi is good to :D
I wouldn't even consider one unless someone/a few people actually got some tangible results from them in a street/track car which indicated they are even half up to the hype. At least here they are at least as expensive as a Garrett equivalent and nothing I have seen so far indicate they do anything more than at best compare with the Garrett ball bearing. They seem good at high boost levels, but considering most people with RBs tend to lean more towards 1.4-1.6bar tops on street cars thats a complete waste of time.
Bullseye piss me off as they do interesting turbos but then do completely biased comparisons to make their options look better than Garrett ones by using two turbos which are in fact completely incomparable specs and then draw strange conclusions from it. If they just showed things as they were I'd probably be less dubious of them, though perhaps if they did then the turbos wouldn't necessarily seem as viable.
Well a mates R32 GTR just came off the dyno with its .82a/r GT3582R. Its running mild upgrade cams (~260deg I believe), a home made exhaust manifold, and an old GTRLink which was proven to start wrecking the party as the revs and power levels started going up. The crappy old link has a 2.5bar map limit so tuning was finished at 21psi.
The car made 379kw @ wheels on 21psi with full boost reached around 4300rpm, sounds fantastic - hoping to go for a drive in it later on today. The car will be getting a G4 Link and a retune in a couple months time, hopefully that will liven things up a bit :P
None at all that I am aware of, just bolted the cams in - they haven't been spun or anything. In a couple of months time when it gets a decent ECU there will probably be more work put into squeezing every last hp out of it, at this stage it was to get it running and running with respectable power.
Can someone please post up some websites of where i could get a new T04z for a good price that will come relatively quickly..?
Im new at this and don't really know where to shop.. thanks in advance
Have a look in the traders section of this site.
  • 4 weeks later...
I have GT35 with .82 exhuast on my R32 GTS4, ran 6.8 seconds @ 170kmh on the 1/8th mile, which is 10.4-10.5 sec 1/4 mile, Im pretty close to maxing out the .82 exh at 20psi- 397rwkw ,
a very old quote but im slowly getting through the thread.
not that i dont believe you sky30 but i find it extremely hard to believe your making almost 400kw with a .86 rear......especially only on 20psi. that sounds like something a 5L motor would do.
im running a rb30 gt35r .86 @ 20psi only made 335rwkw. no head work as such but still....
do you have something to back that up? i do hope you prove me wrong because it gives me hope for my setup lol
Edited by Jap_Muscle
The car made 379kw @ wheels on 21psi with full boost reached around 4300rpm, sounds fantastic - hoping to go for a drive in it later on today. The car will be getting a G4 Link and a retune in a couple months time, hopefully that will liven things up a bit :)
Nice work - would like to see a plot if you have one?
    • Structured text and other high level PLC programing languages are not allowable in Functional Safety. They are very difficult to audit. My PLC stuff is almost exclusively oriented towards Burner Management Systems which are a particularly pernicious form of Safety Instrumented System, when implemented in an SPLC. Even the part of the code written to work in the non-safety logic part of the PLC, like with a Siemens S7-1500 series, still needs to be treated as if it was safety code, with access restrictions, code fingreprints and the like. And Allen Bradley can go EABODs. They ae full of shit. They have this whole lie going on where they say if you use a ControlLogix controller and its IO, and then just duplicate the IOs (ie, run in series or parallel depending on type, to try to make it "fail safe") and "use these programming styles and place these restrictions on what you do" that you can achieve SIL2. What a load of crap. They just get away with it because no-one in the US seems to understand the first thing about Functional Safety and carries on as if all they have to do is buy only SIL2 rated equipment and hey presto, it's a SIL2 system. Idiots. /rant
    • If you're really considering leaving it, a great question to ask is, is the magnet going to stick to the sump? The answer to the above is the same answer towards if I'd have any level of comfort leaving it... Personally, based on the cost of a motor if the magnet were to cause damage, I'd be fishing it out either way. Use the methods in here. It fit in through the plug hole, it'll come out.   PS, get a small actuatable claw for a bore scope. OR if you know a vet, they have really cool controllable scopes with hooks on the end. Supposedly they're like playing a video game. Ask if they can acquire you one of their scopes... Engine oil after all is just a different type of lube right? Will only make it easier on the next dog or cat...
    • All other (Boolean) logic functions though, are just built on those blocks above. Which does give you a lot of functionality in logic. It is basing that on using thresholds with analogue signals like GTS alluded to.   Not having things like timers will make it less useful for some of the ramp up logic you'd want, and again, on Haltecs capacity specifically, I'm not across anymore what you can / can't do with different tables.   I'm assuming, with your logic you want to implement, not only do you want your timing safeties, you're wanting to be able to derive the duty cycle for your solenoid, to maintain I'm assuming 175PSi? Or are you using a standalone WMI controller to maintain the DC correct, and you just want the Haltech working out which fuelling maps you should be on?
    • It doesn't seem to follow revs. Oddly it seems to follow TPS a little bit from what I can see, but with some delay a bit. IE end of the graph, when he lets off throttle fully, pressure drops a lot, then slowly builds back up, but rpm is on a nice cruisey drop off. I do agree though, it seems very electrically.
    • I just try to entirely stay away from ladder now unless it's something basic maintained by electricians. Even then and to your point, it mostly ends up being blocks I wrote in structured text.  PLC's are slowly going towards C, C++ and C#. I just wish Allen-Bradley would jump on the bandwagon.
