Gt35r Vs Garrett T04z - Discussion (just Post In This Thread To Create A Database)
Cerbera's car has been parted out for about a year, so the T04Z run is a little old.
We're stumped as to why it's restricted. The only thing we can think is the head I'm using (off a 34 N1 motor) has a few imperfections in it which is causing turbulence. I'm using a china manifold, but the same type on Natalotto's car did 630hp with a T04Z. Exhaust is fine, intake is free, plenum is stock, cams are pretty big (270x10.8).
Disco, I'm using the GCG T04 rear for the 35. It's a T4 flanged 0.84 housing. I don't think the rear housing is the issue to be honest.
I would assume that a R34 N1 head stock would be better than or at least on par with my 89 shitter standard head, i'm still thinking it is the manifold. I remember back in the day Natalotto had heaps of problems with his china manifold and they did extensive modifications to it to get it working right. I dont know if Brockas has done anything to his?!?
I agree the boost is all over the shop, ramps hard then creeps and then falls over... which to me points at a manifold issue!!!
my t04z run is about 2 years old, still same dyno, same operator etc etc
Manifold hasn't been touched yet. Simple china shitter ceramic coated and bolted on.
It has a gasket leak on the exhaust side anyways, so the manifold has to come off. May see about modifying it while its off.
i was looking into the to4z with a 3litre bottom end on a 25, personally i think its a bit too large for track, big turbos tend to be slow on track cars, leave larger turbos to the drag racers is my advice. Go Hks GTSS, fantastic turbos for track and relatively tight courses....
I had the pleasure of driving a T04Z'd 25/30 in a 32 GTS4 a couple of weeks ago on the skidpan. Bit laggy compared to the GT30'd R33 I also got to drive, but, when it comes on boost.. HOLY SHIT.
Edited by bubba
that mikes new settup?!? how much power did he end up making?
Just got back from the workshop.
Compared my GT3582 setup (blue line) with a Cerbera's T04Z setup (green line), which were both run up on the same Dyno Dynamics dyno in shootout mode.
Not sure if Simon's had any issues, but my setup is strangled HARD in the top end. So much so, that adding 5psi and 2 degrees ignition timing gained me a whole 1hp up top. Did gain about 30hp through the mid range though, but I obviously have a large restriction in my inlet/exhaust which isn't allowing any more than 500hp flow.
Anyways, enough ricers excuses, here is the comparison:
Thats a perfect comparison.
You gain up to 60 hp more through the low - mid range. For a top end trade of of about 70hp.
I actually think you would find the two cars down the 1/4 would be very simular in times.
You have the big advantage though as your car would be more driveable on the street / track.
Be interesting to see once you have the issues sorted out.
How the top end power would compare on the same boost levels.
If you end up only trading 30 or so top end HP for a midrange gain of 60hp you will be well ahead.
Yup, but after 6 months of the car being off the road, I'm not touching it again for a while, so will have to make do with that comparison.
If I get the motivation I will fork out for a 6boost manifold and see if that makes a difference.
The manifold is the cheap solution, the head is not so cheap. I'm hoping that with the boost dropping off, that indicates a manifold issue.
yeah 3.5-4.5k about a average of 35hp more but from 4.5-8k about a 50hp average more
i dont know what crack you have been smoking butters, but when do you have revs less than 4.5k down a quarter mile :(
i remember the difference in speed of my car on lowish boost (19psi 510rwhp) and high boost (24psi 574rwhp) was not even comparable... 510 was fvcking fast, 574 was just scary :)
  • 2 months later...
Reviving this one once again. Looking for some opinions on the following, given the choice of a 3582 1.06 twin scroll or the equivalent sized borg warner s300sx (83/75 I think) both on a proper twin scroll t4 flanged manifold - which would be the more responsive while aiming for ~500rwhp.
nick have a look at nytsky's engine build thread
he is using a 3076r on a built 25 and making 485rwhp with e85 and an amazing power curve, i'd imagine your motor could make a little more...
i would be thinking along the lines of a 3076r with a 1.0ish split rear
Edited by Cerbera
I would be going for the TS Gt35R, definitely. I am not convinced on the BWs yet - they COULD be really good but there are contrasting results for them, while the GT35Rs are a very known quantity.
That was going to be my next question, full race are the only ones I've found so far - and at 6-700 delivered (exh housing only) it's looking like buying a whole new turbo will end up cheaper.
Edited by DCIEVE
i think a 3076r with a 1 housing would be pretty awesome suited as simon suggested. With correct setup in a lightweight r31 it would be nuts, mine seems to be abit better now with new exhuast and in a lighter car i could see it be pretty damn good (ill find out soon enough). Ill have to take you for a spin and show you how it goes and response and then u can decide for yourself and mine isnt even sorted properly. Surely a 450hp setup with awesome response would beat a 500hp setup with a fair bit more lag on a track.
on another note, the sloth (scradly) just made 430(allstarhubberlovehp) the other day on a stock neo with cams and a 3076r 0.82 with only around 17-18psi boost with awesome response
surely a built 26 with another 6psi could smash out 500+
DOOOOOOOOO IT
    • Had another look at the car and I noticed the fuel pump isn't priming on ignition. I'd taken out the pump from the boot to siphon out the old fuel, so maybe I've knocked something loose or broken a wire putting things back together. Will go back with a multimeter and try to work out what's stuffed. Kinda hoping it's the pump itself thats gone so I can upgrade it
    • Yeah agreed, you can't assume that shop are they only people who ever had to work on it. It was just a guess on the mods based on how things were done back then. You can check the Air Flow Meters by the part number on their tags, they are likely either Z32 or Nismo ones (both read about the same but the Z32 one is a little larger while nismo is stock size but supports the higher airflow like a Z32). And yes, all that would get you to 450hp / 340kw To tell what is happening with the turbos, you want a photo of the tag on the core, that will say what it was made out of  (they can retain the front and rear covers to make the plumbing easier)
    • I'm selling my personal race car. 1992 BNR32 Skyline GT-R About eight years ago the engine developed the dreaded low oil pressure problem. I removed it and found the issue. However shortly after I moved half way across the country, moved my work shop, bought a house, got married, then moved my shop again to it's permanent location for the time being. in turn I do not have the time to race this car as it should be. In turn the engine I built for this car will end up in my street car and this car I hope finds a home with someone who can use it to it's full potential. The roll bar was built by Jason Noren Fabricaiton in Pomona California to SCCA and NASA Specs. The car used to compete in redline time attack and global time attack enthusiast class. It also has a fire suppression system.  The car is with me at my workshop in Kyle Texas, USA. Shipping it is no problem, I can personally deliver the car to the port of either Houston or Los Angeles. Any other port depending on where it is may require transport but we can always work that out.   The chassis itself is rust free, rear quarters and under fenders are free of any rust so it's a very solid foundation for anyone who wishes to move forward with it. As posted and at the asking price of $20,000 USD the car includes all of the following;   All OEM Body panels, front fenders, rear bumpers etc.  OEM Nissan Projector headlamps (Pictured N1 lamps were removed) OEM Nismo Side Skirts / Extensions OEM Rear Spats  Front & Rear Subframes are installed car is full roller Rear Subframe has Cusco Camber Arms, Whiteline HICAS Elimination Front Subframe has Whiteline tension rods and whiteline Sway bars w/ endlinks.  Buddy Club N1 Coilovers All chassis wiring and engine wiring is in tact. Attessa System is fully in tact and was functional before engine removal.  BCNR33 GT-R Brembo Brakes F+R with Endless MX72 Plus Pads, DBA Rotors & Stainless Steel Brake lines Billion Racing Radiator Billion Radiator Hoses Fluidyne Engine Oil Cooler Accusump System (trunk Mounted) 5 Speed Transmission w/ Transfer Case F+R Prop-shafts Rear Differential With rear Axles.  Nismo Gauge Cluster Nismo Clutch + Flywheel   Essentially what is needed to make this car running and driving again is as follows: A working Engine, an ECU, and time to put it together. The price posted is or best offer as I am willing to remove some components to accommodate price to a certain extent. If any serious buyer wants full detailed pictures, videos, or any questions I'll be happy to answer them. I believe this car is priced to move quickly considering it's a rust free and very straight chassis but always open to fair negotiation.  I can be contacted via phone or email. (+19517081648) email is juan@bardabe.com
    • So...to my (and my mechanics doing the swap) surprise...the oil pan from NEO engine does not fit 100% and needs to by modified like this: It is not a huge problem but in the future i want a "proper" oil pan. So question is...what different oil pan can i get to fit without any problems and modification? Thanks!
    • Some more info I found.  These are the last entries Yoshikiyo Fujii made on his blog before he passed away in 2009: http://blog.livedoor.jp/fujii_dynamics/ And finally this is where the workshop was situated:  https://maps.app.goo.gl/HhTPtHzt3WVcBTiEA
