Gt35r Vs Garrett T04z - Discussion (just Post In This Thread To Create A Database)
Turbo characteristics are gonna be different on the 30 than 25 or 26 setups. what about the hybrids. im throwin up ideas at the moment of ideal setups to maxiumize HP within scope of tracking and some street. and so far ive scaled down to these 2;
GT35R X82 S.S 25/30 Final 3.9
To4Z x106 T.S 26/30 Final 3.5
Oh ps. the TO4Z in the Equation will be the HKS item.
My mate has a T04Z on his 25/30 and I am in the process of putting a GT35R on my 25/30, I guess I should use the same dyno/tuner to keep the intrawebz fanbase happy ;)
The fact that one is 4wd and the other isn't, shouldn't make much a difference?
This will be interesting - do you have a dyno plot in storage somewhere which could be overlayed with the T04Z one to see how much more lag etc you get on the same engine spec?
Any reason for going the T04Z over something like a GT4088R? Shame the GTX-series turbos aren't out for a bit, I have a feeling if Garrett do a GTX3582R T04Zs will lose a bit of their edge
Yup, dyno plots are saved and engine combo isn't changing, so it's literally just going to be a bolt off bolt on situation.
0.84 twin scroll T04Z ordered... will be here Friday, fitted Monday, tuned Wednesday.
My mate has a T04Z on his 25/30 and I am in the process of putting a GT35R on my 25/30, I guess I should use the same dyno/tuner to keep the intrawebz fanbase happy :D
um Drivability wise sure it would, but i think main emphisis on power output wont be much different if the 4wd has only 2wd engaged at time time, and they both share the same Ratios.
Id be keen to see the results from both.. and ofc. supporting mods also.
Obviously drivability would be significantly different! lol
Maybe it won't be so direct a comparison then.. my final drive ratio is 3.9:1 whereas I believe his is stock gts4 (4.3:1?).
He is also running HUGE cams (280s & 10.5 lift I think) whereas I'm not :wave:
what did it make bubba? mine on 18psi has made 585rwhp with the 0.81 t04z on 98 pump fuel (Not on a happy hubber either lol).
Brockas gt35 isnt exactly the same as what everyone else is running so dont know if his comparision is gonna be that clear, he is using the t4 housing on the 35 which surely effects results.
But none the less will be good to see the difference.
Edited by unique1
yeah but 70deg of timing helps with power :P
Anybody here ever thought of switching to a Precision Billet 6765? Its a 67mm like the T04Z but has a redesigned billet compressor wheel which is lighter and made more aggressive to outflow any of the old 67mm turbos. A guy here in the states has one on a RB26 and he put down 763whp @ 32psi. Some 2JZ guys have it putting down 800+whp and one Evo guy i know of did 900+hp @ like 40psi with it. I didnt believe the 900hp thing till he ran it down the track and trapped 153mph.
yeah but 70deg of timing helps with power :happy:
lol just because yours couldnt even crack 575hp on 25psi+ boost :P Put good quality bits in the motor and some good headwork/big cams and you will be suprised. Wait till its in a car again and new ecu with no misfire problems and then things will be alot different.
haha thought that might stir you up...
mine went 574 @ 24psi thank you very much!!!
plus it also went 560rwhp at 20psi but yoda backed off timing so it was nice and safe :down:
brockas should make anywhere between 560-600rwhp i would imagine, hopefully 573.9 so I can give him shit for years to come :)
Edited by Cerbera
Mikes gts4 made 580hp at all 4 hubs on only 1.3bar as Sean didn't want to lean on it right away. Pretty sure there's no headwork other than what was required to fit the huge cams.
All I can say is 3L + T04Z + 32GTS4 = insane!
cerbera.. who is this yoda you speak of?
I will need my 26 to4z tuned shortly and trying to decide who i am going to get to tune it.. was previously tuned by mick at ovaboost
Have you had problems with Mick's tuning in the past? From my experience he is the bomb and wouldnt think you would need to change unless something went wrong. But then again, there is no harm in trying someone else!
Looking forward to results Brocka's.
i have not used mick, but i have been there when he has tuned a few mates cars and i thought he did a good job (dyno is a bit ancient nowdays haha) and i have only heard good things about his tuning ability
yoda = ant scali at xspeed
if your looking for suggestions i would suggest ant @ xspeed or sean @ allstar!
ant has tuned all my cars in the past and done a great job, sean did the run in tune for my gtr and is going to be the one tuning my new car :thumbsup:
Edited by Cerbera
best results seem to be from 270/272 types with between 10.2 and 10.8 lift
edit: just realised your running a rb25 woops sorry, the ones above are for rb26
Edited by Cerbera
    • Had another look at the car and I noticed the fuel pump isn't priming on ignition. I'd taken out the pump from the boot to siphon out the old fuel, so maybe I've knocked something loose or broken a wire putting things back together. Will go back with a multimeter and try to work out what's stuffed. Kinda hoping it's the pump itself thats gone so I can upgrade it
    • Yeah agreed, you can't assume that shop are they only people who ever had to work on it. It was just a guess on the mods based on how things were done back then. You can check the Air Flow Meters by the part number on their tags, they are likely either Z32 or Nismo ones (both read about the same but the Z32 one is a little larger while nismo is stock size but supports the higher airflow like a Z32). And yes, all that would get you to 450hp / 340kw To tell what is happening with the turbos, you want a photo of the tag on the core, that will say what it was made out of  (they can retain the front and rear covers to make the plumbing easier)
    • I'm selling my personal race car. 1992 BNR32 Skyline GT-R About eight years ago the engine developed the dreaded low oil pressure problem. I removed it and found the issue. However shortly after I moved half way across the country, moved my work shop, bought a house, got married, then moved my shop again to it's permanent location for the time being. in turn I do not have the time to race this car as it should be. In turn the engine I built for this car will end up in my street car and this car I hope finds a home with someone who can use it to it's full potential. The roll bar was built by Jason Noren Fabricaiton in Pomona California to SCCA and NASA Specs. The car used to compete in redline time attack and global time attack enthusiast class. It also has a fire suppression system.  The car is with me at my workshop in Kyle Texas, USA. Shipping it is no problem, I can personally deliver the car to the port of either Houston or Los Angeles. Any other port depending on where it is may require transport but we can always work that out.   The chassis itself is rust free, rear quarters and under fenders are free of any rust so it's a very solid foundation for anyone who wishes to move forward with it. As posted and at the asking price of $20,000 USD the car includes all of the following;   All OEM Body panels, front fenders, rear bumpers etc.  OEM Nissan Projector headlamps (Pictured N1 lamps were removed) OEM Nismo Side Skirts / Extensions OEM Rear Spats  Front & Rear Subframes are installed car is full roller Rear Subframe has Cusco Camber Arms, Whiteline HICAS Elimination Front Subframe has Whiteline tension rods and whiteline Sway bars w/ endlinks.  Buddy Club N1 Coilovers All chassis wiring and engine wiring is in tact. Attessa System is fully in tact and was functional before engine removal.  BCNR33 GT-R Brembo Brakes F+R with Endless MX72 Plus Pads, DBA Rotors & Stainless Steel Brake lines Billion Racing Radiator Billion Radiator Hoses Fluidyne Engine Oil Cooler Accusump System (trunk Mounted) 5 Speed Transmission w/ Transfer Case F+R Prop-shafts Rear Differential With rear Axles.  Nismo Gauge Cluster Nismo Clutch + Flywheel   Essentially what is needed to make this car running and driving again is as follows: A working Engine, an ECU, and time to put it together. The price posted is or best offer as I am willing to remove some components to accommodate price to a certain extent. If any serious buyer wants full detailed pictures, videos, or any questions I'll be happy to answer them. I believe this car is priced to move quickly considering it's a rust free and very straight chassis but always open to fair negotiation.  I can be contacted via phone or email. (+19517081648) email is juan@bardabe.com
    • So...to my (and my mechanics doing the swap) surprise...the oil pan from NEO engine does not fit 100% and needs to by modified like this: It is not a huge problem but in the future i want a "proper" oil pan. So question is...what different oil pan can i get to fit without any problems and modification? Thanks!
    • Some more info I found.  These are the last entries Yoshikiyo Fujii made on his blog before he passed away in 2009: http://blog.livedoor.jp/fujii_dynamics/ And finally this is where the workshop was situated:  https://maps.app.goo.gl/HhTPtHzt3WVcBTiEA
