Gt35r Vs Garrett T04z - Discussion (just Post In This Thread To Create A Database)
why all the hate on abit of lag, get it in the right gear and the thing will never come off boost. The t04z would be fine around a track as long as its not super tight. The t04z will make upwards of 650rwhp so its no where near the limit either. People under estimate an extra 80hp top end :)
pretty much the same engine/turbo but one has 6-boost twin scroll and one has china manifold and a dodgy gate
shows what a well set up manifold/gate/boost controller combo can do...
So top graph is brockaz & another setup - both GT35's yeah?
If so, first graph is very interesting in that brockaz setup comes on noticeably sooner than the setup with much better parts.
I wonder what the reason behind that is... interesting
sorry should have explained
top graph
gt26wa = brockas gt35r 0.8x t4 rear on china manifold
1bxx056 = my old gtr t04z divided .084 housing 6-boost
bottom graph
builtr = brockas same setup but t04z instead
Using the same boost level is i dunno, arguable.
Remember the turbo's have different areas of efficiency and so on.
Best of running them both where they both perform best and comparing off that IMO.
Indeed arguable. Effiecent range on the GT35 is probably 28 - 30psi and 35 + on t04z.
Brockas like most probably not keen to push to those levels.
top graph
bottom graph
All your graph comparo proves is that brockas china manifold / setup is crap compared to 6boost and your setup.
GT35 on your setup would have rocked.
ps. nattalotto get the f**k out of this thread unless ur car is going to be on the road before 2056
LOL coming from the guy that never raced his 26 !!! Simon N has times you got wannabe ......
Final word
IN PERTH GT35 smashs the t04z on RB26. Best single t04z time is like 10.8 on a fully built motor ??
There is more then one GT35 RB26's quicker then that IN PERTH.
that was my point... he need to get daddy to buy 6-boost and tial gate :-)
we dont think silvias are worth mentioning :P plus run a decent mph in your stripped out drag car when the street cars monster you top end ;)
top graph
bottom graph
Ah ic ic - makes more sense now :P
Would be interesting to see the GT35 on a good setup i think, one thing that's missing from the comparo's haha ;)
so whats the best result on roller dyno (no happy hubs) for a gt35? like 530rwhp (dcieve)? and best t04z is 625hp?
big difference, some like medium power and some like more power than that its the way it is :P
Nert.
We pushed the 35R as far as it would go. We put 28psi into it and a couple of degrees ignition timing, it made 4hp more.
510rwhp on that dyno is as much as the GT35R will make on my car.
586rwhp is as much as the T04Z will make.
Both setups will not make any more, no matter what we do.
The T04Z should come on a lot harder but thats the fault of the shitty wastegate. Having said that, the wastegate was exactly the same on both combos.
Same could be said for the GT35 as well don't forget
Interesting. Wonder were the restriction is. 510 does seem towards the limit of a gt35 on a 2.6 with pump.
Not sure how many 26's go over 586 with a t04z either.
so whats the best result on roller dyno (no happy hubs) for a gt35? like 530rwhp (dcieve)? and best t04z is 625hp?big difference, some like medium power and some like more power than that its the way it is smile.gif
Peak power does not determine how fast a car is, sure its a good indicator but its not everything. In brockas case the car could be faster with the less HP. The lose of over 110 hp through the lower range is a big difference too :P
Nice result Paul, you should be pretty pleased. As you've already mentioned both your 35r and t04z are laggier than they 'could' be (comparing to the results of others) be so some tweaking of the boost control etc should beef up the 4-5000rpm area nicely.
All the talk of which is quicker would be quashed if someone has the time to plot both of pauls plots in excel then calculate the average power over the usable rev-range (say 5k - revlimit).
big difference, some like medium power and some like more power than that its the way it is ;)
So comparing my straight fit cam, stock head rb26 with your all out jun 2.7? :P
all im hearing is waaa waaa waaa i can't crack 130mph in my lightweight drag car with a 35R tongue.gif
Lol.
Big MPH and slow time just shows how poor the car is setup or how bad the driver is :P
I could wheel spin the track and run bigger mph, what does that prove ?
Much rather perfect use of power, fast time with low mph !!
Also quite confident my "low mph" light weight car would be quicker then the 130-135 mph GTR's in the top end as well ;)
If you can't run into the 140mph range with a GT35R, you aren't trying hard enough ;)
The 600+hp dyno plot isn't relevant to the comparison we are seeing here... a before and after with the same car and same dyno, run to the limit each turbo will make with that setup has to be the most fair comparison you can get - surely?
It represents 15% more power with 19% more revs needed to reach 20psi (to rule out the boost controller differences, and make a bit easier on the T04Z). Far cry from earlier in the thread where people were implying the T04Z is comparable to a GT35R in spool! I'd love to see a GT4088R compared with these things :P
    • Update: I got the magnet out. I bought 3 different flexible magnetic reach tools, but none of them worked. The magnet on the tip was all less than 2lbs of force, so i had to buy a special cylindrical magnet that had a pull force of 9lbs.  The magnet finally came in the mail yesterday, so i got under the car to get to work. The super strong magnet isn't that long, so i only have about 1 finger pinch lengths to hold it. I was so scared when i was going in the hole, that the 9lb magnet would just fly away inside the oil pan never to be seen again, but i had my butt cheeks clenched and finger gripped on that thing so tight, i managed to get it to suck the other magnet out.  It was a victory for me last night.
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
