Gt35r Vs Garrett T04z - Discussion (just Post In This Thread To Create A Database)
i was comparing simons 625hp not my own setup nick.
cerbera thats something i expected from you on a forum, just your style lol
borg warners are where its at :P
come on its a matter of personal preference i think, everyone has there own ideas of lag/power/fast.
pretty much the same engine/turbo but one has 6-boost twin scroll and one has china manifold and a dodgy gate
shows what a well set up manifold/gate/boost controller combo can do...
Would it be possible to overlay a stock curve for those following at home?
Ah ic ic - makes more sense now :P
Would be interesting to see the GT35 on a good setup i think, one thing that's missing from the comparo's haha ;)
Here is a graph of my GT35 with .82 rear on a decent manifold setup
also i plotted it on brockas graph to compare, its the black line.
diff ratios dont seem to be the same and isnt yours a RB30 therefore totally useless comparison?!?
lol ye exactly - twice in as many days... stand back george :)
Thanks sky30 - but kinda... not really relevant unfortunately :(
Didnt realise that its a RB26, for some reason i thought brockas was a RB30det, That would explain why it seems so laggy to me. Oh well interesting comparison between rb30 and rb26.
Its a r32 gtr diff, 4.11 ratio, what are the ratios in the other graphs?
Car should be running in a week or so. And i'll head to the plex again see if it can go decently into the tens on street tyres. To4z has the top end to get decently into the mid 130mph's. With the small things its had done to it this time round 650rwhp should be enough for mid tens on street tyres.
I'd love to see a GT4088R compared with these things :D
lol give my bank balance time to recover after this change in setup first!!
I've now taken 2 people for a spin in my car. They both saw the graphs before going for a drive, and said the exact same thing. "It doesn't feel as laggy as it looks on the dyno plot".
Would love to have it snapping on boost hard, but I don't think my gearbox would like that...
Just looking at Pauls Graph compared to mine as a t04z to to4z comparison seems to be quite a bit of difference in response. They are both roughly based on speed vs hp and at say at 130kms pauls is making 220hp ish and mine is making almost 400hp at the same speed. Just an interesting comparison as mine didn't really feel laggy at all and should be better with the new setup of bigger valves and bits and pieces. As a comparison mine was running 27psi and i think pauls is 25psi so pretty close.
Edited by R32-GTS
I think you can put it down to the boost control.
You can see in your graph the boost comes on hard where as Brockas is a bit lazier. A good boost controller makes all the difference.
LOL
no chance you will have it running in a week or so!!!
Indeed arguable. Effiecent range on the GT35 is probably 28 - 30psi and 35 + on t04z.
Brockas like most probably not keen to push to those levels.
All your graph comparo proves is that brockas china manifold / setup is crap compared to 6boost and your setup.
GT35 on your setup would have rocked.
LOL coming from the guy that never raced his 26 !!! Simon N has times you got wannabe ......
Final word
IN PERTH GT35 smashs the t04z on RB26. Best single t04z time is like 10.8 on a fully built motor ??
There is more then one GT35 RB26's quicker then that IN PERTH.
RockoGTR's 10.4 on Nexan Radials is a GT35 and China manifold. We are going to put it on E85 and MT Drag radials and try again.
I now have one of the best boost controllers on the market, the Blitz Dual SBC Spec R.
Unfortunately, it's my wastegate which is letting me down.
Simon, we overlayed yours versus mine and yours destroys my setup everywhere. It's on earlier due to the head porting, but yours snaps on boost so much harder. I think once I sort this wastegate issue it will change the midrange dramatically and also carry a few more HP to the top.
For now though, I'm going to see how long this $300 2nd hand box lasts... the fact that it lasted the dyno run means it's been good value so far...
Natto it will be interesting for me to see if your car can repeat the 627. That is a 4 year old dyno graph your clinging on to. Dyno's get worn, software updates and re-calibrated over that time.
    • There are a few different ways of doing it. I'm currently running two 1000cc pre-TB nozzles and PWM the pump for control. I'll be moving over to a constant pressure system and direct port. I'll run the pump off a regular relay, have it cycle on roughly 5psi before I start injecting to build pressure and then PWM a WMI solenoid (It's basically an injector that can take a lot of pressure and not corrode with water and meth.) The solenoid feeds the 6 direct port ~200cc nozzles. I'll also keep one ~250cc pre-TB nozzle to help keep IAT's in check.  Safety will be a little different as well. I used to use a pressure switch but will be moving over to a pressure sensor between my solenoid and nozzles. I'll trigger my solenoid and if I don't see specific pressure within a specific timeframe (e.g 100psi within a second, 175psi within 2 seconds), I kill it and revert back to non WMI maps the same way I did it before with 4D in Haltech. I was just figuring out the timers in my ecu last night. They made that a little more complicated than I would have liked... I wish Haltech offered a larger set of logic/math functions like other ecu's do. I can't do very much with just AND's and OR's.  I've been asked to do fuel/ignition mapping on a medium bore engine at work in May (192L V16). Being the only programmer in my region and having went and opened my mouth about knowing the ins and outs of fuel/ignition mapping, I have now been deemed an expert. Fun fun. The entirety of the logic and algorithms are programmed in C on a PLC. As I spend more time figuring it all out, I like what I see and eventually I may consider doing the same as a pet project to replace my ecu.
    • This would be interesting, would you feed it via a 2nd row of injectors? Or just usual WMI nozzles?
    • Cut sump up and extend. Win win 😂
    • All, What's the recommended torque for the 1/2 head studs for RB30 twin cam conversion with RB26 head?
    • also, we need to know which solution worked....
