With the ignition off I'm looking at the fluid bottle in the back and this is what I see.
Is this normal? notice that it is pretty far above "max" and also it appears to be two
colors of fluid. This is with ignition off.
The manual says "turn ignition ON make sure that oil is within max-min lines on the
tank.. if the ignition switch has been turned off for a long period of time oil in the
attesa e-ts pro actuator might return to the reservoir tank, causing oil to exceed
max line. Be sure to turn ignition switch on before checking oil level. Always use genuine
nissan power steering fluid .." (etc)
I've got an attesa ecu error of some kind, so perhaps the oil is returning to the reservoir
and not being pumped into the system, but why is it two colors like that?
Edited by r34nur
https://www.sau.com.au/forums/topic/246361-attesa-fluid-level/
  • 2 years later...
I had attesa 4wd light\limp home issues with my Stagea, I found that checking the level after start up got the real picture of where it's at. Seems to bleed fluid back to bottle when parked up - maybe why so much headroom above level marks. I changed the fluid by loosening off bleed valve at back of trans & draining about 100mls at a time then top up the tank, with the ign turned on pump did not start but found that starting up motor then after several seconds the attesa pump would cycle up to pressure and draw the fresh fluid in. Rinse & repeat until the fluid turned red where I was draining it.
Probably better ways of doing it but it worked & all is at peace with the 4wd light.
With hindsight I didn't have to change fluid, just learnt to check level after startup.
Dunno 'bout the tequila sunrise effect in the pic but the level looks about where mine is when parked up for several hours.
Caveat: I'm new to this stuff & learning my way around my car.
    • The max they would go for me is 50.
    • That cannot have been a fun set of drilling. The stock "baffle" looks identical to rb26, I just cut fuel cell foam to fit the full length under the baffle.
    • I understand your sarcastic exasperation. But to be fair - the baffles do indeed fit OEM cam covers. They did omit to say that you need to do a bunch of stuff. But they do fit them.
    • Got started on the modification to make these splash plates fit over the long weekend. First the surprisingly time consuming task of swapping all the cam cap bolts to Tomei cam cap studs. I did the method of removing one bolt at a time, applying loctite to the stud, double nutting to torque as the manual described. Then carefully unlocking the nuts without disrupting the torque of the stud (and going back to re-torque a few times when it slipped). Finally applying the nut and torquing to spec. Repeat x28 Next up I went about removing the stock cam cover baffle so I could ensure it was fully clean after drilling for stud clearance.  As the blind rivets holding the baffle on were domed I used a punch to mark the center then used 4mm drill bit to carefully drill out the rivet without going too far part the baffle. As seen in other thread here is what is inside the stock baffles I decided on M4x6mm bolts to bolt the baffle plate back on with. I used a 3.3mm drill bit with some tape to mark the depth at ~8mm. Next was to tap the threads using a cheap bunnings kit M4x0.7. With the baffle removed I also drilled out the spot welds holding in the baffle plate oil returns. Unsure whether this was the best option or if I should have cut holes in the Hypertune splash plates to allow the oil drains to still function... time will tell. I then removed the the Hypertune splash plates so I could rest the cam cover on top and use a dab of grease to mark where the studs impacted the oem cam cover baffle. The most obvious spot was on the hump from the stock mesh is held. Using this hole as an anchor I bolted the oem baffle plate back into the cam cover and lined up the Hypertune splash plate. Marked the rest of the holes for the studs and drill those out too. Total 32 holes drilled and 12 threads tapped on the passenger side cam cover alone for this bolt on part that totally clears all OEM cam covers.. Drivers side next as well as some E85 safe fuel foam to fill the space behind the behind cam cover baffle plates. oh and some lock nuts for the splash plates of course.
