Turbo kit low mount to suit rb20/25 head
- Garrett Gt3040r (2000kms)
- Custom stock manifold ported and external wastegate pipe welded on
- Turbosmart 45mm pro gate 14.5psi spring
- Custom 3 inch front and dump pipe to suit.
was on a rb25/30 making just shy of 300rwkw on low boost!! Selling as I am selling the car with stock turbo.. will make easy 300rwkw+ on a rb25
$2200 ono
located in melbourne
leigh 0409556340
post-24129-1227599729_thumb.jpgpost-24129-1227599867_thumb.jpg[att
https://www.sau.com.au/forums/topic/246383-turbo-kit-garrett-gt3040r/
