Hi, this has happened a few times now,
This time it went on for about 5 minutes straight,
I dont know what it is but its really loud and its coming from the engine bay some place....
It only happened when i turned it on, and when i drove for a bit it went away..
it just stops randomly
anyone have any idea what it is and how much it costs to fix? :|
Thanks
Thanks
ok regardless what car it is...
its most likely either the belts for the power steering, altenator, water pump, air condition or watever.
i think the reason everyone is asking is that some cars have just 1 belt to drive them all....and some have seperate 1 for each.
try tightening it, each belt should have about 1/2" play/slack in movement after tightening.
and if that doesnt do it...it could be the pulleys for each of the mentioned above...the ball bearings may be worn.
a good way to test that, is get a long screw driver, a flat one preferably... put it on the big nut that holds the pulley to the motor...then put your ear on the end of the knob on the screw driver and you will hear excessive vibration on the faulty one. a good pulley will have a very smooth, feint grinding sound...
perhaps try it when u start ur car on cold...especially
yeah belts
i got greddy light weight pulleys and the squeal like a pig. have tried washing detergent and belt grip with not much success.
Might give the WD40 a go thou.
yeah happens mostly in the rain, is my car drivable or do i really need to get it fixxeD?
yes it should be drivable.
like we said, do some DIY before you go to your mechanic.
thats how people get ripped off that way.
say he tightens the belts, hes gonna charge you for service fee and his time.....1.5 hours or whatever.
look i would say do this;
1.) Use your finger and push down in the middle of the belts and push down and up... see how much movement is in it. (should be .5 of an inch)
2.) if it is lose, tighten it...if you car has a tensioner bolt. Check the belts with a torch, see if there is cracks.
3.) if it is tight to start with & is in good condition. do what i said with that screw driver, listen to each pulley and find the source of the problem.
4.) if one of the pulleys is noisy, you may want to get that replaced in the near future, spray some WD40 in the gap of the pulley pivot.
5.) there is a special can of "belt spray" if you go to super-cheap, repco or autobahn. it apparently should minimise noise in belts.
but personally i believe in replacing faulty parts, when things like that rattle or squeal, its a first sign of required attention rather than bodging things up with that spray.
try that and keep us posted.
im clueless about cars :sick:
you in melb you can help me out? :)
Save my piggy bank :D
gee dude......i typed all that and u didnt understand
lol
nah unfortunately im not
in sydney australia.
    • I believe Unimog is the only vehicle that has it (from the manufacturer). I haven't seen aftermarket permanently connected kits, but I haven't looked either.
    • Ha ha ha, can't overthink when exhausted... Oh how I wish I had that power! I can be absolutely dead set shot, and my brain will still go "we need a good 3 or 4 hours to just think about everything and anything before you may sleep... My biggest thing is making sure I give myself enough sleep. I don't operate on even 7 hours of sleep! I attempt to give my body 9.5hours sleep a night to be able to function. I don't sleep the whole 9.5, but I need to make sure I offer a big window. I also take a single supplement, which is to help with long term health, and fighting inflammation, and I notice it helps massively. Especially me sleeping, and just less "achey" in the body. Have also kicked sugar, and gluten. A majority of people with ADHD don't go well with gluten. It causes a really interesting natural opioid overdose in the brain, which causes bodily issues and sensory issues.
    • Yeah that's what I meant, permanently connected not manual
    • Yep. But typically that's just run a hose down to the tyre while stationary.   Oh and the Unimog will automatically air up and air down tyres from the onboard computer for you too.
    • There was a good video somewhere, maybe Kurzgesagt that linked physical activity to ADHD/Anxiety/Insomnia etc. Basically the body WILL spend energy doing something if you don't spend it doing anything physical. It isn't fun, but I personally have noticed I've never been overthinky, or unable to sleep if I'm physically exhausted from doing a lot. The musings around it seem to indicate that this is one of the reasons/mechanism that physical activity improves mental health/wellbeing etc, by more or less not using that 'extra' energy to overthink, be anxious, inflammation, etc. There's also the fact that every obnoxious exerciser ever says it's great and helps which is extremely annoying. Like people who say the same thing about travel being the best thing ever. I mean, they clearly are, but blah. I started doing a LITTLE myself (think 3x15min per week) and honestly did notice the benefits, aiming at life quality when older. Which is sooner than you think. Getting something into your routine that you can actually make a routine has helped me at least. This post brought to you by procrastination between sets.
