Stage 1 modifications complete and ready for stage 2.
Dynoed at 210kw at the wheels.
Stage 2 transmission kit fitted for 0.5sec gearshifts.
RB25DET NEO engine transplant from an R34 GT-T.
Why I chose an automatic:
- It is not humanely possible to change gears faster than 0.5s no matter how hard u try.
- More consistent results and less human error.
- Eliminate the need to rebuild your clutch every now and then.
- Being able to hold your partner's hand while driving is always a bonus.
It has never went sideways or touched a track.
Reluctant sale due to an urgent need to relocate.
Professionally maintained and cared for with no expenses spared.
Always fed BP Ultimate with no exceptions.
Enhancements on the car:
Mongoose 3-point immobiliser with windscreen impact detector.
Tinted windows.
White dash cluster up to 320km/h.
Boost, Oil Temp and Water Temp electronic guages with stepper motors
and smoked screens.
Blitz Front Mount Intercooler.
Calsonic radiator.
3.5" Turboback exhaust system with hi-flowed cat converter.
Cold air intake kit for pod filter with heat shield.
Stage 2 transmission kit.
Apexi AFC-Neo Engine Management System.
Greddy Profec B Spec II Dual stage Boost Controller.
Spitfire Coilpacks.
Apexi Rev Speed Meter.
Apexi Turbo Timer.
Tein Height and Damper Adjustable Coilovers.
Adjustable Front Castor Arms.
17" Rays Engineering Rims.
Front and rear strut bars.
Zero accidents and breakdowns.
Will pass any mechanical checks with flying colors.
Asking price: $15800 negotiable.
Priced for a quick sale. Will be sold to a dealer or eBayed if not sold soon.
Contact James at 0433 936 433 or at [email protected]
Vehicle is located in Victoria.
Update:
Rego is valid until AUG 2009. I made an error while creating the post.
I am willing to take $1500 off the final price if the buyer is willing to come up with the roadworthy certificate.
Price drop to $13000 with roadworthy certificate and $11500 without roadworthy certificate as I am relocating soon, and I need the car sold as soon as possible.
All mechanical inspections welcome.
Edited by shoebox
Price Drop: $10,500 without roadworthy certificate. Roadworthy certificate can be provided upon negotiation at an additional price.
The engine doesn't look like a NEO by the intake plenum, I guess its running the R33 ECU still? You can tell if it has a NEO head as the coil packs are a different bolt on configuration.
It's still running the R33 ECU, but the engine is from an R34 and comes with NEO head.
Receipts and engine number can be provided for verification upon inspection.
Edited by shoebox
It's now on eBay.
http://cgi.ebay.com.au/ws/eBayISAPI.dll?Vi...em=160304497493
Current value: $5000
8 days left.
No reserve price.
I need it gone by the end of the month as I'm relocating then, so make a reasonable offer and it will be yours.
Edited by shoebox
4 days, 10 hours left before the end of the auction:
Current value: AU$5,322.83
No reserve price.
Inspections and offers are welcome.
URL: http://cgi.ebay.com.au/ws/eBayISAPI.dll?Vi...em=160304497493
    • Wanting to avoid this if possible but kinda looking like I may not have a choice 😭
    • Ok awesome thank you. Just wanted to have them in case I can find some and need to compare part numbers!
    • All I can say Duncan is good luck and I hope that Neil did not run any E85 in Cheryl. I have recently experienced the full spectrum of fuel tank issues in my R33's that had been caused by E85 and contaminated fuel. When you take the cover off the top of the tank and have a look inside you will get an understanding of how easy it will be. Best case situation is clean fuel with minimal contamination. My GTR was like this and it was a very simple operation to just grab the fuel pump carrier bracket and slide it up and out of the tank. My three GTS_T's had different levels of fuel contamination that was probably caused by E85 in the fuel.  In the worst case all of the metal components in the tank had rusted to the point where there were pieces of rusted metal swirling around in the tank. This required the removal of the exhaust, the tailshaft, the complete rear cradle and the fuel tank. The components in the tank were that rusted that it took days to get the fuel pump carrier and the mounting brackets out of the tank. When the tank was finally cleaned, everything inside the tank had to be replaced. With the tank all back together I could then reinstall it in the car along with everything else that had to come out. Good luck and I hope that you find a clean tank.
    • It is a two door. It is black and also still has the OEM wheels and stereo. Exact model would be KR_R32RGFEL_SS According to GTR-Registry.com is a 2 Door Coupe; RB20DE; 2WD no HICAS; MT.F5; (11L) Projector Headlamps and Fog Lights; (12_) Electronic Active Full Auto Air Con (Climate Control); (13-14SS) V Selection -- Which seems to be accurate description of my variant. Will try to upload a few pictures soon. The OEM wheels look like the below image. Image is taken from the goo-net-exchange website.
    • Time: Saturday 18th January - 9am -10:30am Where:  Cafe By Lamanna 10 English St, Essendon Fields VIC 3041  - https://g.co/kgs/mhVKvAB Registration: So we can give the cafe a heads up on rough booking numbers please rsvp below Registration Link: https://forms.gle/wPtfj9Gp8bvCiouo8
