Basically im asking this just to get a general opinion of what to look at
Car: R31 Skyline Sedan
Engine: RB20DET
Purpose in life: Drift / Circuit Car
Current dash arrangement:
Factory cluster
Apexi RSM on steering column
JJR Autogauge Oil pressure, oil temp, water temp and boost gauges in cups hacked into the centre of the dash
Problems encountered
Speedo doesnt really get used (as im not that fussed)
Tacho gets glanced at but is rarely accurate (resistors wired to tacho line to cluster to make work with RB20)
Fuel gauge is the only one that really gets any look at in the factory cluster
Autogauge gauges are the defi style backlit, which is alright at night, but a prick during the day to read
Planned dash in new car
Remove factory cluster and cups, no dash loom being run at all to save weight
Aluminium / fibreglass panel across dash area housing:
RSM in centre (purely so if i want it i do have tacho/speedo displayable)
Boost
Oil Temp gauge
Oil Press gauge
Water Temp gauge
Fuel Level gauge (as i will be running a fuel cell instead of standard tank)
My only preferences
Gauges are easy to read day and night
Electric gauges only (dont really feel like running mechanical gauges in cabin)
Preferably all the same brand / same look
Dont want to spend a bomb on gauges (its only a drift / circuit car, so i dont want to spend 2k on 4/5 gauges if avoidable)
I have had people tell me to look at autometer, and ive had people steer me away from them.
Opinions?
https://www.sau.com.au/forums/topic/246513-what-brand-of-gauges/
Autometer for sure, I run their eletric gauges and they're so easy to read at day and night.
No idea why people would steer you away from a brand that has a great reputation and is widely used in motorsport and street. Autometer ftw. :sick:
i was looking at the autometer cobolts one's untill they told me the price of the full sweep electric boost gauge ($450+) but the mechanical one's are like $160 - $180 i had the full set in my old onevia and i wouldn't use anything else :)
atm im tossing up between the autometer cobolts
or the drift iridium gauges
few of my mates are running these, They are electric aswell only problem they said they have is when it get's really sunny inside the car they are a lil hard to read
if u want cheap there are calibre gauges white background greddy copy ones. 60-80 bux. dunno about accuracy but ive also seen some articles saying autometer arent that accurate either.
they look pretty nice. ill prob get me some of them but im cheap lol.
I had Trust/Greddy SM Integrate gauges in my old S13, oil temp/oil pressure, with a Pivot water temp gauge. The SM Integrate gauges have a memory function so you can record and replay like 30 seconds of readings, or just a plain old peak recall.
Pivot had a peak recall function as well.
Anything that's white face will prove really really easy to read at day time, and are good at night time as well depending on how they light up. The Pivot lights up with a white light behind a cover on the glass of the gauge, the Greddy would light up green, from behind, with the needle showing up orange.
Easy as anything.
I've seen on a few US sites lately that alot of people are happy with STRI guages.
Here's the japanese site, but do a google search and you'll see some demo's. I'll more than likely go with these.
http://www.stri.jp/
Yeah, into next yeah I'm looking at replacing my voltmeter, oil temp, oil pressure, air/fuel, boost and maybe even water temp gauges..
I really like the ones that go black, and also, in regards to my boost gauge, I'd really like it in PSI, I'm sorta a bit old fashioned like that! :)
    • yeah I've never understood that either.... And to answer an earlier question, I write the date on open bottles and throw them if more than 12 months old (which they almost always are, because I don't need to bleed them unless I'm changing lines/calipers etc in between)
    • Nah, the one that hit the boot was a big steel locker, around 6 foot height, 4 foot wide and 2 foot deep, empty it weighs about 15kg and had about that amount of stuff in it The photo didn't give a good representation of the actual damage, the large ding on the passenger side was about a inch deep, the one on the driver was about 1/2 inch deep, right on the curve, where the inner boot frame doesn't let you get behind it with a dolly Basically the same issue with getting behind the damage on the centre of the boot We could have filled it all with bog, but my OCD would be triggered every time I looked at it, knowing what hides beneath  As for the locker, I did get the shits with it and put it in the scap metal bin, but, I pulled it out and it is now sitting in the garage at home full of car servicing stuff, cleaning gear and random tools, it's going to pay for it's indiscretions
    • Whilst I typically don't cheap out on things, if I can save some money, like $1000, on a clean straight panel, that gives me $1000 to spend on other stuff, basically free money really 🤔 🤣
    • Is the toolbox that damaged the boot seal the same item that fell on the car during the storm a while back?
    • Who are you to deny yourself? I’ve said this many times to myself and apart from getting what I really want, I go quiet for a while whilst working out what I just did to my savings and how will I afford what it cost, then, next payday…
