So im getting a fuel pump and regulator installed on my car. Just need to decide which one im getting, I've had an extensive chat with Mark at godzilla motorsports and have been told that the bosch fuel pumps are quite noisy, the walbaros have a bit of screwing around install wise to get them to fit and that in his opinion the smart way to go would be with a Tomei. There a straight bolt on, little noise but are quite pricey.
Anyone got any other suggestions, or any knowledge from personal experiance that would help?
Cars a R34 GTT btw.
Cheers
Sammy
https://www.sau.com.au/forums/topic/246516-fuel-pump/
i fitted my walbro with a mate, who helped out coz he has done one before and we had to modify the bottom rubber to make it fit but that didnt take too long, it was pretty much a straight fit besides that. i have never fitted one before and it only took me about 1 hour, having never done it before. wasnt too hard at all.
https://www.sau.com.au/forums/topic/246516-fuel-pump/#findComment-4285361
personally i'd rather go a bosch, but depends on what you want out of the car.If you want just manily bolt on and say 260kw, then go a walbro, if you want more go a bosch, but once again just my opinon and from experience.Id rather have more leeway and more fuel then not enough.Also why other with a fuel reg unless you run big boost and bigger turbo, plus then alot of other high HP cars that i see are still running there original fuel reg.
https://www.sau.com.au/forums/topic/246516-fuel-pump/#findComment-4285415
Ah ok very cool. Well Im having an emanage ultimate installed at teh same time so I think I will just have the pump installed by godzilla at the same time. But from what I was told I just gathered there was alot more screwing around involved with the walbaro as appose to the tomei but apparently not...
as for the regulator. its for future modifications, Id rather have it installed when im doing the Fuel pump and computer than later on when im having the turbo and injectors installed.
https://www.sau.com.au/forums/topic/246516-fuel-pump/#findComment-4285554
Make sure you do something with the intank reg as well, it's a crappy piece of violet plastic inline with the hose, they're not so great. If you can get one from a GTR they're better. Even an R34 GTR fuel reg on the rail is a straight swap :blink:
https://www.sau.com.au/forums/topic/246516-fuel-pump/#findComment-4286943
+ 1 for either the Tomei or Nismo items, i went through the same thing you are going through and decided to bite the bullet and i am glad i did, no noise except when priming for a second, even then it is not bad at all. Your call though i cant comment on the bosch or walbro pumps but i can give a massive thumbs up for the Tomei and Nismo pumps, IMHO definatly worth the $$$.
https://www.sau.com.au/forums/topic/246516-fuel-pump/#findComment-4293279
INCORRECT.
recently installed a walbro into a mates r34 gtt. kit came with a new harness, plug, and pickup filter.
now bosch, i had to mess around with that to install it.
bosch FTW
Edited by r33cruiser
https://www.sau.com.au/forums/topic/246516-fuel-pump/#findComment-4294218
+1 for the tomei/nismo
Quiet and has good pickup right down to near empty. Good flow rate to and easy to install
have heard nothing but bad things from a mate with a walbro in his 32 4 door and have limited experience with the bosch. Hear its noisey and has a bad pickup
https://www.sau.com.au/forums/topic/246516-fuel-pump/#findComment-4294241
I've got a Walbro in tank and a bosch 044 after the surge tank. The bosch is quite until you start driving hard then it starts to make a heap of noise like a buzz saw cutting wood. It goes back quite again once all has cooled down. First time I heard it I thought the pump was faulty but the second one does the same thing.
Make sure you have a good gaws on the in tank pump as well.
https://www.sau.com.au/forums/topic/246516-fuel-pump/#findComment-4296318
I reccomend the Nismo pump high flow rate and easy to install comes with everthing down to the mounting bracket. Contact Dan from Elite racing he will hook you up. :D
+11ty
I have a Nismo 600HP one...awesome item. I had to shorten one tube that is all.
https://www.sau.com.au/forums/topic/246516-fuel-pump/#findComment-4298958
ur mums awesome tbh ro .. ALSO got a bosch 023 (biggest intank puppy) 700HP pump :D got it on special.. was the same price as the 040 so meh.. just got it.. its loudish i spose.. i love it tbh.. but with a straight through zorst and drift pipes doesnt bother me :) was pretty fun to install too :).. just re-fabed the cradle thing ftw its simple.. stuff..an works sweet.. also.. got a malpassi rising rate reg.. seems fine :) been going fine for a 220kw rb20 for ages.. GL man, but in the end if you got the coin.. geting nismo an tomei shit is gonna be quite good ay :)
Edited by 32JEZ
https://www.sau.com.au/forums/topic/246516-fuel-pump/#findComment-4299207
ur mums awesome tbh ro .. ALSO got a bosch 023 (biggest intank puppy) 700HP pump :thumbsup: got it on special.. was the same price as the 040 so meh.. just got it.. its loudish i spose.. i love it tbh.. but with a straight through zorst and drift pipes doesnt bother me ;) was pretty fun to install too :P.. just re-fabed the cradle thing ftw its simple.. stuff..an works sweet.. also.. got a malpassi rising rate reg.. seems fine :) been going fine for a 220kw rb20 for ages.. GL man, but in the end if you got the coin.. geting nismo an tomei shit is gonna be quite good ay :)
I had that pump on my old R32 worked well for me at a shade over 300rwkw
https://www.sau.com.au/forums/topic/246516-fuel-pump/#findComment-4299908
All good advice here- I am runnin a walbro 255 rated at the mo and have no issues with it at all.
little bit of a buzz-not a prob there but-will flatten battery if ignition is on really quickly
I have also got a nismo one in the cupboard just in case, when this one craps itself that is goin in muahahahaha
https://www.sau.com.au/forums/topic/246516-fuel-pump/#findComment-4300023
    • Incidentally, I also put v3 of the tune on the car and did an oil change from 5w20 to 5w40 to see how it affected oil pressure in the mid to high end. I'm still happier with the thicker oil and will stick with it, but clearly the system is happy with 55psi even if I'm not!
    • So the other thing I got sorted over the weekend was Z1 oil catch can install. https://www.z1motorsports.com/z1-products/z1-motorsports/z1-q50-q60-30t-baffled-oil-catch-can-kit-p-23546.html It was a good kit, most importantly it came with preformed silicone hoses in the right shapes rather than trying to bend/join regular straight rubber hose. It did come with crappy spring clamps not proper hose clamps so I ditched them On the down side, it is made for LHD cars and RHD cars have the main ECU harness running straight through that location, I ended up bending 2 mounting brackets so the loom is up against the brake master cylinder compartment wall to make room for it....otherwise everything fit without modification Intercoolers off on both sides, but there was enough room to get everything done without disconnecting (and therefore having to re-bleed) the coolant lines. Each is mounted with 4x 12mm headed bolts, plus in and out side hose clamps (7mm headed, nice) and 3 electrical connectors on the navigator's side which were a real pain to undo (probably for the first time in 13 years).   Also one of the mounting bolts on the driver's side was cross threaded, thanks Infiniti/Nissan workshop mechanics. On the navigator's side, the catch can plumbs into the factory hose that goes from the cam cover PCV back to the intake.  This is the 2 new hoses in place. All simples and direct fit On driver's side, there is a bracket provided that mounts to the throttle body, they even provide slightly longer bolts to allow for the bracket thickness which is nice (although, they don't have captive washers like the factory bolts of course) In that pic the main loom brackets are not in place, once I had "adjusted" them across it now sits up against the panel and just clears the OCC The remaining problem with this is emptying it; currently you have to remove the 3x m4 bolts that hold it to the bracket and both banjos to remove it (probably dropping the banjo washers at the same time) pull it apart to empty then replace. I do have some fittings coming for a remote drain from underneath that will also add a little capacity...it is very small and will need to be emptied every oil change to be sure.
    • Noise sounds to me could be either wheel bearing related (have had similar from bearings going) or that tail shaft is still loose. Or something like a heat shield touching the tail shaft.
    • You wouldn't get away with saying the opposite, if you were there.
    • Do some wool fluff testing on the vents
