Booked the car in last week to have the timing belt and water pump changed...
Have to say I couldnt recommend these guys enough, they did it all with ease, even fitted a GTR n1 pump...
I went off to a confrence in the morning and picked it up just after 5 in the arfternoon... They were extremely helpfull and i'll be getting all my work done there in the future...
They can do pretty much anything I think, so give them a call next time your in the market for some mech work!
https://www.sau.com.au/forums/topic/24652-gavin-woods-auto-tech/
  • Replies 181
Agreed.
I recently had a heap of mods installed by Gavin and his team.
He also found other issues that I got him to fix too. It cost me, but in the end better than something major happening, and relieved that he found them at all.
I had my Apexi PFC installed by another mob in Brisbane - and apparently they left it a base tune. Grrr.
After Gavin properly tuned the ECU, the car feels great.
They get my business from now on.
here here...
I've owned my car coming on 3 and half years and Gavin is the only person other than me to have worked ondriven it.
We've been through exhaust sensors reading 4000 deg to cracking an exhaust manifold in half...I also, can't recommend him enough and am sure there will be many a good post to follow.
Well I travelled 30 hrs down and back from Townsville to see Gavin and he definately gets my vote the guy and his team were fantastic. He accomadated us very well taking the time out when i arrived to go through all the gear i had (quite a bit) for him to fit to my car and he understood that i was pushed for time and had to get back to townsville for work so just concentrated on my car for two weeks so it would be finished, he is definitely a dying breed in the auto industry where customer satisfaction comes first . :D
Oh, here we go.. Now everyone wants to blow his horn eh?
I've been saying for over a year that Gavin is the man for Nissan + tuning + service and people have said "no go to this place".
Meh, they are more friends to me now than a mechanic :)
Christmas card buddies.. you know the story :)
Best. Mechanic. Ever.
Still no one understands why I drive to laborador to get my car fixed/serviced. Now you all know why.
And if it wasn't for me sitting here saying "GO TO GAVIN... GO TO GAVIN" no one would have known about him :)
You all know how much I baby my car, and for me to trust him or any of the other mechanics in his workshops says a lot :)
We also need to give recommendation to the other guys in the workshop. They seem to be forgotten when people say "Gavin Woods" yet the other guys do most of the work while gavins off in other parts of the country doing tuning :)
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
