Hehe.. it sounds like it's going to be a skyrice australia meeting at Gavin's next week.
My cars down their the whole week (because I can't do down during the week and my b/f can't get time off) so Sinbad (car) is having a sleep over at Aunty Manda's and Uncle Gavins :uh-huh:
  • Replies 181
well, i got my last service at the new nissan service depot at wooloongabba and i couldnt be happier with it
they were cheap, went way above and beyond (they greased every lock and hinge in the car, i aint never seen that done before)
did an awesome (4) wheel alignment and was still cheap as (as well as they let me know a few things i need to do next time (leaky gasket, missing bonnet rubber))
maybe they cant do all the hitech stuff gavin woods can, but screw driving all the way down the coast every 5000k
ill be back there for my next service for sure (props to woman for finding them)
yeah i was wondering why you added the last comment ;P
dont read qgl much anymore, mainly because its full of shit now and the flamewars dont exist anymore. The funs gone and the nazis reign.
I was going to ring today but rang outta time being sick. But I have to find someone taht can fix the air cond fan in the dash to work again it died and if I get this fmic shortly I would like someone to put it in, as I'm short of time. Mainly just want the odds and ends fixed and the car tuned up and service. I was planning on doing it at the same time,a nd getting it dyno'd and running smooth, just wondering if gavin would be able to do all this, or would I have too take my car to like 10 different car shops?
yeah i read your dash read me, its pretty easy to take apart, but the thing is I dont ahve much time these days. tadoy I wasnt felling 100% so I went out and got some cash and hunted around to see where i could get teh air cond fan checked and working. The turbo timer is just I have weird the wires to the wrong one, optput 2 is on the igition and not the other wire. fix weekend.
intercooler and piping shouldnt be too hard just need grinder, drill and a coping saw/jigsaw. but first have to see what piping i get with the kit. the bar and lights are easy to take off, but its a pirck to get the bar back on.
I restored a hj ute from 3 write offs,a nd painted it, so I do know a bit about handy work. Learnt most of it as a kid at dads work. Just atm Its cheaper for me to get someone else to do it while I earn the dosh, and if its all put together and serviced then tuned and dyno'd I get a car thats got the works done in one go. None of this every weekend drop off and check crap or get it serviced then next week tuned.
Time is the main issue I have, its a problem to get stuff done when 14 hrs of the day your at work, and 12 on the weekends. just been lucky lately to be able to have sundays off beacuse the dollar is up and not much coming tinto australia atm.
yup, time is money.. i wasn't really implying you were lazy ;) just that its not too hard to do if you want to put in the time. The dash took me about 2 days work so i can see why you'd want to do get somebody else to do it if you didn't have the time!
i took the dash out and tried to get the air cond fan working onthe weekend, and i put the turbo timer in, but connected a wrong wire at the key harness, so I ahve to fix that this weekend, just have the timer off till then. the steering wheel was the hardest to realign, took about 20 minutes to get the wheel on perfect. gotta get a plastic horn bit as the one in mine was broken and need a horn.
went to all jap at virgina, $20 for the plastic bit wher ethe door opener is. and thats second hand. just the plastic not the lever. nad its worn a bit.
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
