Hehe.. it sounds like it's going to be a skyrice australia meeting at Gavin's next week.
My cars down their the whole week (because I can't do down during the week and my b/f can't get time off) so Sinbad (car) is having a sleep over at Aunty Manda's and Uncle Gavins :uh-huh:
  • Replies 181
well, i got my last service at the new nissan service depot at wooloongabba and i couldnt be happier with it
they were cheap, went way above and beyond (they greased every lock and hinge in the car, i aint never seen that done before)
did an awesome (4) wheel alignment and was still cheap as (as well as they let me know a few things i need to do next time (leaky gasket, missing bonnet rubber))
maybe they cant do all the hitech stuff gavin woods can, but screw driving all the way down the coast every 5000k
ill be back there for my next service for sure (props to woman for finding them)
yeah i was wondering why you added the last comment ;P
dont read qgl much anymore, mainly because its full of shit now and the flamewars dont exist anymore. The funs gone and the nazis reign.
I was going to ring today but rang outta time being sick. But I have to find someone taht can fix the air cond fan in the dash to work again it died and if I get this fmic shortly I would like someone to put it in, as I'm short of time. Mainly just want the odds and ends fixed and the car tuned up and service. I was planning on doing it at the same time,a nd getting it dyno'd and running smooth, just wondering if gavin would be able to do all this, or would I have too take my car to like 10 different car shops?
yeah i read your dash read me, its pretty easy to take apart, but the thing is I dont ahve much time these days. tadoy I wasnt felling 100% so I went out and got some cash and hunted around to see where i could get teh air cond fan checked and working. The turbo timer is just I have weird the wires to the wrong one, optput 2 is on the igition and not the other wire. fix weekend.
intercooler and piping shouldnt be too hard just need grinder, drill and a coping saw/jigsaw. but first have to see what piping i get with the kit. the bar and lights are easy to take off, but its a pirck to get the bar back on.
I restored a hj ute from 3 write offs,a nd painted it, so I do know a bit about handy work. Learnt most of it as a kid at dads work. Just atm Its cheaper for me to get someone else to do it while I earn the dosh, and if its all put together and serviced then tuned and dyno'd I get a car thats got the works done in one go. None of this every weekend drop off and check crap or get it serviced then next week tuned.
Time is the main issue I have, its a problem to get stuff done when 14 hrs of the day your at work, and 12 on the weekends. just been lucky lately to be able to have sundays off beacuse the dollar is up and not much coming tinto australia atm.
yup, time is money.. i wasn't really implying you were lazy ;) just that its not too hard to do if you want to put in the time. The dash took me about 2 days work so i can see why you'd want to do get somebody else to do it if you didn't have the time!
i took the dash out and tried to get the air cond fan working onthe weekend, and i put the turbo timer in, but connected a wrong wire at the key harness, so I ahve to fix that this weekend, just have the timer off till then. the steering wheel was the hardest to realign, took about 20 minutes to get the wheel on perfect. gotta get a plastic horn bit as the one in mine was broken and need a horn.
went to all jap at virgina, $20 for the plastic bit wher ethe door opener is. and thats second hand. just the plastic not the lever. nad its worn a bit.
    • It can't be some stupidly proprietary video signal coming out of it that only Nissan's can understand. Surely you can just find some generic camera to stuff in there and use hot melt glue/blu-tac/gaffer tape to hold it in place if need be?
    • Update: Tunehouse looked into the problem and identified a wiring issue between the camera unit and the connector. They managed to get it working , but did warn me at some point it will stop working again. From their perspective it is unserviceable and will need replacement. They did some research and found that the new replacement camera would be Approx $1400 supply only (their fitting cost would be $190) . They did provide the part number (28442-JL05B) and a quick google of the part number shows that these are rather expensive brand new (seemingly no longer in manufacture) for the places that still have them in stock, with the used option potentially presenting  the same issue down the track at some unknown point. They are happy for me to supply the part so that they can fit it. Decisions, decisions... I can definitely recommend Tunehouse (thankyou Vee37!). Cost for the diagnosis was as quoted  ($190) , car was ready on time and communication was top notch. Their workshop is super clean and modern, and there was plenty of car candy parked out the front on the day I went.   Would definitely go back.
    • to fix the voltage drop issue I swapped out the old 150amp alternator which turns out is a brand known for having issues and replaced it with the black 180amp alternator beside it
    • For anyone interested, the Way Back Machine has that Japanese website archived with pictures, etc: https://web.archive.org/web/20051023225805fw_/http://www.a31cefiro.com/air_con.htm "Simply swapping the wiring of the harness will not allow it to function properly. For the outdoor air sensor and sunlight sensor, disconnect the wiring connected to CN1-11 of the air conditioning harness from the harness and connect the sensor side wiring to earth. For the indoor air sensor, disconnect the wiring connected to CN2-3 of the air conditioning harness from the harness and connect the sensor side wiring to earth. The connector PIN numbers listed here are the genuine A31 PIN numbers. To avoid incorrect wiring, check with a tester before wiring. Also, disconnect the wiring in a location close to the sensor. The disconnected harness side wiring will not be used, so be sure to insulate it." Wish someone sold a conversion harness to just plug-and-play a Kouki 180sx digital climate control into C33/A31. I'm decent with wiring but feeling kinda lazy about taking this on. Edit: Did some more digging and found a helpful Minkara blog post about the conversion as well: https://minkara.carview.co.jp/userid/1831116/car/1360568/2284209/note.aspx "After installation is complete or the battery is replaced, you need to go into self-diagnosis mode and set the internal air recirculation. The way to do it is to "hold OFF with the key on for more than 5 seconds, set the number to 5, then press 卍→C." ↑↑↑It probably won't make sense unless you actually try it (・∀・)." Lol wtf
    • Maybe SAUNSW could see howany members would do a motorkhana day if Schofield's is still available for a reasonable price...
