  • Replies 157
Posted Images
I shall be there and i will be in bored33's old car lol its going well so far
OH MY GOD!!! My carrrrrrrrrr. You have no idea how much I miss it. Were you able to fix the VTC solenoid? I can't decide what car to get at the moment!
It better be running fine :D
yeah man its running good and i dont believe its the vct solenoid and it has only played up when shifting from first to second and its just doey as but its going good so far i just havent had time to look at it probley. I scrap the idea of me coming on the curise i leave for the raaf on the 13th >_<
Cool
here is a list of ppls who have said yes, maybe, possibly
Gemma
Jeff
Andrew
Mitch- figjam
James- j4m35
Vicky
Eliiot- Palmer
Jason- Gizzmo
blk180
pete- sexy pete
shawn- darkon
anna34
shane
dave- wisey18
jay- Jay Stylz
scott- scottie
rafael- pbk1776
dale- silver bullet
michael-micor
Alien
Daniel- Punisher6942
76
Radz
Kaan
cool good turn out so far even with some of these ppl are maybes :P
hey guys i'm bailing sorry, i have blown my turbo and got like...50 HP so my car runs like a dog :D any1 got a spare R34 turbo? :(
sorry
Edited by J4M3S
Gemma!
has to be sometime in the next two weeks because im off to NZ after that!!
plan a date!
have not seen the krispy kremes gang for a while, and it looks like it has grown substantially!!
punisher (daniel) your car looks mean as man! I live in the area and always drive past your place.
GUYS!!!! i am pretty sure it is staed in the original post! But i have been wrong before. It is on Saturday the 17th!!! Shane, i already told u u have to come! its been forever since u have gotten out and about!!!
Am sooooooo looking forward to it!!! its been yonks!!!
    • I was under the impression the reason why OEMs are going with solutions like relatively thin "right-sized" cylinder walls with technologies like PTWA and open deck is because they care a lot about whatever marginal knock margin benefits they get from that vs the structural rigidity benefits of a closed deck block and thicker cylinder walls. I also see some weird stuff like plastic inserts in the water jacket around the cylinders to try and equalize cylinder wall temperatures. re: the PRP blocks and heads at the end of the day it's hard to know what is and isn't going to work there, just have to see what the initial buyers say about it.
    • Which is why I didn't mention that hardness testing, and specifically mentioned the bore and deck thickness testing. Yeah, not really. The bore temperature will be a lot more even around the top half inch or so, where the material distribution is dominated by the deck, and which is the only place where the bore surface temperature heating any gas in the cylinder is likely to have any effect on detonation. Think about it. Another inch or so down the bore, you might have a hotter spot. The gas there might get a bit hotter, then the piston rises squeezes that gas away from there at high speed and mixes it with other gas from nearby. Instant dilution of the problem. I'd be surprised if it was an issue at any time other than in racing engines or OEM dev engines being run at the ragged edge of tuning. Say what now?
    • https://dsportmag.com/the-tech/education/engine-tech-material-hardness-testing/ The PRP testing on block hardness I'm not sure how much it actually can be trusted. The thinner cylinder walls on RBs is a bit of a problem vs 2JZ but it really depends on the design goal. Siamesed cylinder bores like a 2JZ cause uneven cylinder wall temps too, which means a bit of distortion induced by that + the hotspot can affect knock margin. Something that actually gives me a bit of pause with the PRP block, whether super thick cylinder walls are going to keep it from being drop-in compatible on an otherwise OEM rebuild.
    • Yeah very valid point. I am waiting for one of the other tuners to come back from vacation so he can help me a bit when the cat is installed again. In the meantime I am going to finish up my polishing and ceramic coating that I have started myself.    N45 Dr Beasley product is highly recommended for a paint primer / polisher. Using this EXO Gtechniq also for the ceramic but next time might use the light serum before hand also. Looks great.
    • Running rich in conditions where it shouldn't probably won't do great things for catalytic converter lifespan. I would fix that sooner than later.
