Hi there,
After getting my NEO turbo hi-flowed (GCG), the turbo specialist at the shop I went to told me I needed to do an oil flow test, with the oil feed line to the turbo, with the turbo off.
Has anyone done one of these before? Surely the flow of a standard RB25 oil feed must be known? Only been done about a million times before...
Still I thought it best to test my specific situation...
Only problem is, I can't get higher than 250mL in 15 seconds, which works out to ~1 litre per minute. I was advised I needed minimum 1.5Lt/min (so 375mL in 15 sec) and no more than 2Lt/min. This is with an unrestricted banjo bolt in the engine end of the feed tube, no banjo bolt in the "catch end" (in the bottle which represents the turbo), and one of the banjo's has a restriction.
The line is new by the way; I had Pirtek make up a stainless one using the original banjos from the original oil feed line.
Does anybody know if 250mL is right, and what sort of flow I need? What can I do - spend another $100 to get another line made up, and then try that in the hope that I've gotten the restriction right?
thanks
DaveB
https://www.sau.com.au/forums/topic/246540-turbo-oil-flow-test/
You need to drill out the banjo bolts to get the desired oil flow - I had this issue with my RB30E+T, I think I ended up with 400ml in 15 seconds which was bordering on high-ish, but never had smoking from the exhaust due to excessive oil intake.
This has had the ball bearing CHRA replaced with a bush bearing core as I understand happens with GCG highflows, yes?
easy fix if your worried about your oil issue and the GCG turbo, ring the boys (GCG) on 02 9708 2122 they have never let me down and offer spot on info to customers, they also do ALL our turbo work (hi-flows, rebuilds). They are only Hiflow guys i can use reliably without fear of boomerangs.
Edited by URAS
Thanks a heap for the replies guys, that puts my mind at ease a bit more... for the record the GCG hi-flow of the stock turbos is a complete new Garett core, and is ball bearing.
I was told I needed between 1.5L and 2L per minute, I got ~400mL in 15 seconds. Glad to see yours was similar crayman; I'm sure this info must be known for the stock RB25DET engines - I mean it's only been done about a million times before. Still, I guess I know that my setup specifically is safe.
For the record I have found, that the stock line is fine for flow if you just drill out the banjo *bolts*; they have about a 1mm restriction in *both* of them. If you drill them out on an RB25 (NEO in my case) you should get around 400mL/15sec at idle.
PS Thanks URAS, that number may yet come in handy :)
Edited by DaveB
    • Damn it, I was at work last night, and stayed in a room there during the storm with the car outside, but undercover, I just went downstairs and well....there was a large steel locker that has come from some place last night, it wasn't anywhere I could see yesterday, and yeap, it landed on the fraking car....of course it did..... LOL So, I'll need to take it back for paint and panel, luckily it was only the boot that took the hit, so it could have been worse Serves me right for staying at work and getting on the cans with some of the boys
    • Yeah, really happy with how it all turned out As for aftermarket lip, nah, I'm not really a fan for practically reasons on a street car that gets driven everywhere  I did have the full lower kit on my 2015 STI, but found the front lip scrapped alot, even at stock 4x4ish ride height As the NC sits now, with the lowest point of the car at 110mm, so just legal, some steep driveways and steep speed humps will still "just" scrap those little plastic OEM air dam thingies on the undertray just before the front wheels
    • Here's one I help build and tuned a decade ago, Garrett  GTX3071R Gen 1, T3 twin scroll 0.83 rear housing. Went from larger 272 cams down to smaller Tomei Poncams to help with the low end. S13 non VCT motor. Car was purpose built for the track, hence low down was the focus. Note the actual dyno chart shows lower boost, however the EBC and boost gauge showed 1.9Bar (Ignore the torque, I was young and didn't know how to set derived torque)
    • I’m doing some side developments on SR20det S13 engines, its one my hobby cars used it to compare flow capacity of some smaller size wheels. SR20det is one of another JDM legendary engines I'm sure there are plenty of SR enthusiasts on this forum, I will share results some common turbo configurations here. a quick run down of what the car is: Wide body 180sx Type X with black top engine (blue). It has: Stock bottom end Haltech 1500 ECU 5-0 motorsports trigger kit Kelford SR20DET Beehive Spring with Titanium Retainers Kelford Cams SR20DET S13 188-B 268/272 Cams G25-660 Turbocharger in T2 .64 rear housing internally gated ARP Head studs MLS head gasket 1000CC ID injectors Walbro 450L Fuel pump Front mount cooler kit JJR’s 3 inches turbo back exhaust (its too short for the 180sx it had to be extended) Pump 98 fuel Hub Dyno tune So far made 270rwkws at 22psi full boost by 4500RPM. Engine is very knock limited hence a pretty bad looking top end. From previous experiences it seems like SR20dets are happier with bigger size turbine, some thing like a GT30 would make way better top end, but on same time response is lost. It won't be a problem with S15 VCT engines. I'll be testing alternative turbine housing, turbine wheel and possibly dump pipe options for extra flow to resolve the problem and of course E85 would resolve all the issues.
    • Awesome writeup and details. Thanks for sharing the story so far. I can relate to parts of it with my previous car and some of the issues I had to deal with.
