  • Replies 56
Hm, yeah that's 2 pro against 2 con opinions already....
Originally I wanted something larger as the 18" kinda look small on the shape of the V35, but even with 19" it doesn't look big at all.
I think if I'm ever going back to 18" again I want to restore all the horrible gutter rashes on all 4 rims before putting them back on...
In the 640x480 pics they didn't show but the scratches were really terrible. That was how I got the car, most likely done in Japan (both side!). Had quotes $350 a piece to restore them back to the factory high silver finish.
  rs73 said:
After about 50-60km of driving I found that the ride is a little bit bouncy especially for mid corner bumps.
I wonder if the tyre shop has put too much pressure or is it the fact that adding 1kg of unsprung weight onto each corner is enough to upset the handling?
The std 18" was supposed to have 210kPa front and 214kPa rear. So i'm not sure going lower profile from 45 to 35 profile would translate to requiring more tyre pressure, or less, or keep it the same?
On the road the Nankang NS-II is not really a quiet tyre, perhaps being 245 wide at the front and 275 wide at the rear may contribute to increased road noise due to increased surface contact area. Also the wide tyre seem want to follow every undulation on the road surface during low speed manouvre (ie 30-40km/h) but doesn't feel any difference for speed over 60km/h... No vibrations though although only tested up to about 80km/h on the highway - haven't tested on the freeway yet.
Also using the tyre size calculator, I found that the new 19" tyres brings all overall diameter smaller.
Front is reduced by 5.6mm (from 579.7mm to 574.1mm) and the rear is reduced by only 2.6mm (from 677.7mm to 675.1mm).
Although I heard that reducing the diameter may allow faster acceleration (but lower top speed), however I found that during
acceleration the car felt not as powerful as before?
Any ideas from you guys if you're some sort of 'tyre experts'?
Not a Tyre expert, but I know how to wear them out a bit...
Pressure is Pressure, regardless of the tyre size and you shouldn't really change the value too much regardless of the size. Most tyres work better at 10% more than vehicle manufacturer recommendations too.
Does the V35 recommend those values, golly gosh!
210 kpa is way too much for any car tyre in my opinion, my calculations make that 44.9psi. I would never have anything more than 40. Currently I run 36-38psi on 225/40R18 tyres. 40-45psi, would see a bouncy ride.
As for 214kpa, that is only 45.5psi, which doesn't make sense, front compared rear.
Do you have the pressure figures stated above correct?
What are now in the tyres? I doubt the shop would have put in 45psi, unless that is what you asked for.
Reset them to 36psi and then try it...
I doubt that you would notice the 1kg difference in unsprung weight, all larger wheel/tyre combo's will weigh a bit more as there is more Alloy in the package.
As for the tyres, at that width they will tramline and some tread patterns and compounds will be noisy. Pressure will also effect this a little...
3-6mm smaller diameter is not much (1.5-3mm radius will not effect much), especially acceleration, gearing or speedo error being very similar across the board. How much do the tyres wear over their life? More than this I am sure...
As for tyre calculators, it is better to take a look at each of the tyre manufacturer's websites and compare the rolling diameter of each tyre, you will probably find they differ from your figures a bit. Look back at your old tyre too and check the tread depth figures too. Pressure will also change the diameter of the tyre too...
Edited by Stephen Thorpe
Thank's...
Interesting... my old tyres is Kenda. I can't find much info about them... bloody compliance tyres... where the heck do the RAWS come up with all these weird brands from???
I've got Infiniti G35 tyre label that I purchased from USA (although they have english/spanish bilingual and doesn't look like the same with what Nissan and RAWS uses over here in Aust for tyre labels).
They are 240kPa front and back, but they are not 40+ psi as you indicated, they are 35psi.
So the one on the Japanese label 210 & 214 I would imagine they will be somewhere around 31-32psi.
So where did you get your calculation from, are the formula accurate?
  rs73 said:
Thank's...
Off the net, online converter...
Low 30psi is not enough and it needs to be high 30psi. I would imagine that would be some of your problem especially with low profile tyres.
Exactly what r they in psi?
Hi Rianto
Firstly.....accurate tyre pressure gauges at servo's do not exist.
Buy a good gauge and put it in your glove box. You will thank your self in the long run.
I took my car to get a wheel alignment by a guy in Sydney that is "old school" in wheel alignments and understands the geometry's and effects of changes. (SydneyKid also recomended him) For the M35 he recomended 36psi in the front and 34psi in the rear. He said as most of the weight is in the motor you want the front higher than the rear.
I like the look of the standard rim, very similar to the M35 rim that I took off my car and I still look at it 3 months later and wonder if the OEM ones would be better. But your car now looks unique to you and I am sure the 19's will improve performance overall. I am saving for my set of 19's.
Cheers
Andy
do you reckon M35 have the same weight distribution with a V35?
I thought being a wagon you may wanna put a bit more pressure at the back in case you need to carry some load.
Unless you are planning to just put your shopping/groceries at the back only...
Why do missus & large rims extremely incompatible :(
This is what she did in 5 minutes of driving 3 blocks from her office to mine...
Any recommendation on good repairer? Prefer someone who is open and can do it on SATURDAY or weekends only...
Man that is not good, but it is bound to happen at some point...
Is the woman now only allowed to drive shopping trolleys?
Go to your local Bob Jane outlet and they have a place in Melbourne, but it isn't a Sat Morning job.
So take a pair of your old wheels and swap that axle over...
BJ's are normally open till 4 on Saturday.
Yes, I would think it is pretty close. A M35 is 52/48 front to rear. Maybe the V35 is not quite that good :) .
When doing trips with a load I put more in the rear.
PS. I don't do the groceries. That is why I have a wife. :laugh:
And thank god my wife does not like my car and does not drive it.
V35 sedan is 52/48 as well, V35 coupe is almost 50/50, I think something like 51/49... i have the JDM brochure lying around in my living room, but I'm a lazy ass to dig it out. It was written in there.
    • I'm not sure the diode only will give the desired result. I'd probably approach it with a couple of relays (And you still might need a diode too!). You need to be able to break the constant feed from the headlight to the orange corner globe when the indicator is flashing. Not knowing which Skyline we're talking about specifically here too (And it may not matter, but I don't know the R34 column switches) you'd likely need to rewire the stalk, so that the indicator power itself no longer runs through the stalk too, as now you need it able to trigger a relay that will break the constant supply from the headlights to the indicator, then you'll need a separate relay to trigger the indicators to come on (Replacing the internal action of the indicator stalk).
    • Weird story from me My Toyota 86 was with Commbank comprehensive but for market value (who they use to underwrite is unknown) When I munted it beyond financially viable repair in 2020, rear end smashed in to the point it bent the rear quarter and roof, they knew I paid $31k cash for it because I told them, they still paid me out $38k, as all the 2017 limited edition variants with typical Km and condition were going for between $36-41k, so they did weird math and came up with $38k I never officially mentioned any of the mods that I had done, but as they were not the cause of the crash they were not fussed at all, the insurance inspector actually asked if I wanted to replace all the mods with the OEM stuff if I still had it laying around before they took the car I still came out of it behind though, because I had probably dropped $20k in it with the suspension (bent after the prang), wheels (bent as well) and "other" mods, that the inspector asked about But still, as the market value was higher than what I initially paid, and they paid out market value To say I was surprised with the outcome would be an understatement  Weird, but true, but probably just lucky with the inspector on the day I guess  Sadly, I don't think if I munted the old NC1 MX5 I would get the same result Meh, pay to play
    • Well, the car is back, all straight and shiny, for how long for is anyone's guess  After picking it up we went for a bit of a drive, Jebus I really enjoy driving this little thing, hopefully the weather let's us go for a nice long cruise this weekend as it will be out of my hands for at least a few days next week when it heads back into Mania on Monday It's weird, whilst I do always enjoy going for a drive, the NC makes me feel like a kid who has just got his first car, and they just want to drive wherever and whenever they can I really need to look into the MX5 Club of NSW
    • wow that is some seriously JDM original credibility there!
    • Selling hks rb25 cast manifold and waste gate.   Never going to use as don't have Rb powered car  Unknown condition of waste gate diaphragm  $900 Pick up only Ipswich Qld
