Hiyas,
I've read and searched through the forum numerous times, but I'm unable to find anyone with the exact same situation I am with my HICAS - so I figured I'd try a post.
Back in July whilst driving between Adelaide and Melbourne - on the highway I would find that as my speed increased from about 60 that my steering wheel would start to roll to the right until it was quite turned by approximately 100. When I hit the 110kph stretch, the car lurched violently and the rear-end started wobbling crazily and settled down until my speed came back under 110. This was obviously a pretty crazy experience and not one i wanted to repeat. I had some intuition that it might be HICAS related, so I pulled over and ripped the HICAS fuse out. Sure enough - the steering was now dead straight and no craziness on the 110 marker (where I can only assume HICAS was turning itself off).
On returning from my trip to Melbourne, I took the car into a Nissan dealer who hooked my car up CONSULT and told me that apparently my car thought that when the wheel was at about a 60 degree angle to the right that the HICAS computer thought that the wheel was straight. As this Nissan dealership had no aligning equipment, he then proceeded to give me a written set of instructions to take to a wheel aligner to try and remedy this situation; Basically along the lines of:
a) Straighten steering wheel to 0 degrees as per CONSULT / HICAS (not too sure how an aligner is gonna do that without CONSULT?!)
b) Take steering wheel off and put it back on straight
c) Do something with steering rack to make the wheels straight as per the steering wheel
d) Get a complete wheel alignment to ensure everything is now spot on
Now this just seems nuts to me, and I honestly haven't had time to track down how I'm supposed to fix this. Right now I can either drive with the fuse in and find the car difficult to drive above about 60 or take the fuse out and find that the rear end is loose because there's no HICAS. I do have a CONSULT cable, but obviously none of the free software I can find seems to have any of the HICAS diagnostics. Some of the posts I've read seem to suggest the system should be 'auto-straightening' or something, so I'm not entirely sure here too. A few other posts I've read suggest you have to be very careful with removing the steering wheel otherwise you can potentially set off the air bag or make a light go on in the dash that you can't reset without going to see Nissan.
Anyways - any advice anyone can give on what the hell to do - I'd love to hear it. I'm sure I'm compromising my handling and probably my tyre wear by driving it as-is and I just want it fixed.
Please - no suggestions about rear-steering rack lock-bars - they would require engineering approval, etc and I get pulled over enough now without adding more woes if I get dragged in for an inspection or somesuch.
Jenna
https://www.sau.com.au/forums/topic/246577-r34-hicas-issues/
Just a mention.. Why would a lock bar require engineering?
Secondly they dont have a hoist on the road, they will not note it is there... they care more for pods, strut braces and BOVs..
I dont think its true it would require a engineers ..
I have had a similar experence.. I doing 140 with bald tyres (bad alignment, weather and 2000km trip to qld caused this - to new tyres) when the ass end went out .. have not had an issue since I replaced the tyres and got a good alignment done perhaps this should be done first mine was way off!
Edited by DECIM8
From what I understand of South Australia (where I live), getting sent to Regency to have your car checked over is fairly common - especially when the car is obviously modified (mine is - lowered with bilsteins and 3" exhaust are the obvious ones). At that point, they're going to check over the entire car - see the HICAS lock-bars and tell me to fix/replace it - or ask me where the engineering certificate is.
I don't really feel like dealing with that situation, I'd rather just have the HICAS system working. I don't really drive on the track or hard enough to justify removing it for those reasons, and I actually find in 'normal' situations it helps with ease of driving than being a hindrance.
I'm kinda disappointed with anyone having any useful responses or caveats or *anything* on how I'm gonna go about lining up the front steering/wheel tyres without CONSULT or any issues related to removing the steering wheel with an airbag....
Jenna
    • What can't be done with a little bit of decking board or similar timber bolted to a hub flange via 2 wheel nuts is not worth talking about.
    • I noticed something. On the tps sensor and the sensor behind the adjustment screw is adjusted towards the far left. Are these screws supposed to be centered? (this sensor was in the same position before the tune as well)  Also attached a photo of where my car usually idles at when warm (sometimes a tiny bit above that). I think I might have screwed up the calculation and it might have better than I thought lol at 750rpm still not 650rpm though.
    • So for both general interest of engine health, and to rule out any coolant/oil issues, I organised an oil analysis done on the 125,000klm oil Results below, all good, just a bit of fuel dilution which I'm not too worried about
    • This is actually a really good way of measuring what wheels fit. If only there was a similar measurement between hub face and suspension :p That said, it's probably pretty simple to actually measure it all with the wheel off the car for the rear. The front is a bit more complex but..
    • Being the top Google search result for R34 wheel-related inquiries, lemme throw down my experience. I calculated that 100mm from hub face to wheel face is about the perfect fitment for my ENR34 sedan.  I've been running 18x8.5s, ET35, with a 1" spacer. So, 8.5in to mm = 216mm. 216/2 = 108mm. 108-35 = 73mm. 73+ 25 (1" to mm) = 98mm.  If you wanna get close to this on dif widths, here are the offsets you'll want: 9" - ET around 15mm 9.5" - ET around 20mm 10" - you're crazy, but ET around 30mm All these should fit perfectly on a non-widebody, non-GTR Skyline. Note that it's probably the absolute max, and you're probably better off running a couple degrees of camber in this config, but it looks great, super flush.
