hi i am going to be installing a pioneer radio this is the manual
http://www.pioneerelectronics.com/PUSA/Una...ANUAL.Protected
and i understand it all except for were to wire the orange/white wire
and also how to wire in the antenna so it can go up and down or is it powered by the antenna jack
need help like asap
thx
https://www.sau.com.au/forums/topic/246584-audio-instal/
need help like asap
thx
hey dude where u located? always willin to help what do u need to know
https://www.sau.com.au/forums/topic/246584-audio-instal/#findComment-4286019
need help like asap
thx
OK. I understand your predicament. Firstly, the connections that need to be made are:
orange/white - connect to any light source in the car that comes on when you turn your headlights on. In my car, I spliced this wire into the wire that illuminates my cigarette lighter. What this does is when you turn your headlights on, the head unit display turns down a little so as it is not as bright when driving at night. Not 100% necessary, but it does the trick.
For your antenna, I assume it is electric, you can utilise the blue/white wire coming out of the head unit. This is the same wire that turns your amplifier on, if you have one, but it can also be used to raise and lower your antenna.
If you do the connections like that, you won't have any problems with anything and it will all work the way that it should. Just be sure to solder and cover all connections that are made.
I hope this helps you out.
Good luck
Tony
https://www.sau.com.au/forums/topic/246584-audio-instal/#findComment-4288435
Solder the cables and also shrink-wrap them (shrink wrap can be found at DSE for about $2 a tube).
I find shrink wrap the best, because it doesn't tighten down hard core onto the solder job, it shrinks until it makes contact with everything, therefore is you have slight spikey bits from an ammeture solder job, the spikes wont break through the insulation and become exposed points.
I find that if you wrap in only electrical tape, there is 90% change of a sharp bit finding it's way though the tape and becoming a contact point, and this is what causes problems later on in the install.
Some headunits also have 2 remote wires, 1 is for the Amplifier, the other for the power antenna, because the power antenna is only used when you switch the radio on, otherwise if you use CD's, it stays down.
B.
https://www.sau.com.au/forums/topic/246584-audio-instal/#findComment-4288550
i ended up conecting the antenna to the ignition switch so when it is at the aac position the antenna goes up.
so when the car is on the antenna will go up
i did try connecting the antenna to the blue and white wire but it didn't work and i couldn't be bothered trouble shooting
and for the orange/white wire i just didn't bother i prefer it on full brightness any way but if i change my mind it easy to fix
thx for the help every body :ninja:
haven't run it with my speakers
i will tell u how it goes
https://www.sau.com.au/forums/topic/246584-audio-instal/#findComment-4290406
    • I would paint match the whole thing to avoid unwanted attention  I had a similar bonnet, paint matched, on my old R33 GTST, but mine was a fibreglass jobbie made by Blitz in QLD, they work extremely well for radiator efficiency and under bonnet temps
    • Does anyone run this kit with factory plenum? Does the adapter and bosch tb fit under factory strut brace? I wanted to get this setup before going forward facing manifold. Thanks
    • small update time, after always wanting a "cool" looking bonnet for my car and always struggling to find one for the series 2 that i liked and wasn't an insane amount of money. Saw one i liked on RHDjapan from D-speed in Japan the price was very good for a carbon bonnet so good infact i was a little unsure how much i trusted it, decided to bite the bullet and with the help of jesse streeter in not long at all it was at my door. Once it was delivered i ran in from work and quickly unboxed it and to my surprise the quality was actually pretty good i quickly removed the old bonnet and placed on the new one to test it out and even the fitment wasnt too bad at all. Then decided to paint the little grille in the bonnet black to stop it sticking out so much.   I decided to not mess around with the hood latch and just install some aero catch hood pins, having never installed them before did some YouTube university classes and i was good to go. fair to say it is not a fun job at all from making brackets so the pins sit nicely and actually cutting through the bonnet but also being very scared of cutting the holes too big it took wayyyy longer than i would like to admit but finally got it there. Then it was time for a quick test drive to ensure the latches actually worked and thankfully the bonnet looked very stable. I still think paint matching the bonnet and leaving just the part that sticks up as carbon would help make it all look alot neater as im not sure how i feel about all that carbon on a very fridge white car but will leave it as is and see how i feel with time.
    • I think it's bound to happen, you finally get it all perfect, and bam, something will happen. I took a while to get a Commodore rear quarter repaired where a P Plater clipped it. Two days after getting it back, Sarah wiped it out on a concrete pillar in an underground car park... This is why I take forever to repair them, it stretches how long until it gets bent again... 😛
    • Nah, not really responsible for that little fiasco, but I'm still pissed at myself for writing off my 86, or when I reversed my VX into a pole just before selling it, but, meh, 5hit happens to stuff, all it takes is a slight distraction, and life is full of distractions, and "dooh" moments
