I have not lost any power with blocking the bov in fact it feels better off gear changes and the same goes for putting a pod over the stock airbox
Your pod is unshielded?
If so I guarentee lower power for you.
Unfortunately, actual results are things not 'felt' but, measured.
Get a heat shield on and it should sort it out though. Blocking the stock BOV is the ultimate " look at me" rice-ness all the same.
This is pressurised air trying to go somewhere, boosted air you now don't require because you have backed off/slowed down quickly. The thought is that this air slows your spool up time when you plant the foot again. It might sound faster, but thats about all it is......sound.
And don't forget the damage... ...turbo going backwards = bad...
Mmm you would think that its bad for it, however there is no definitive evidence of damage (none that i know of anyway).
Lots of damage done is to your social image however.
How dare you stipulate my meaning based on my vagueness!!!... ;) ...Hahaha... ...Social damage is a given...
One theory I've heard is that because the front side and back side of the turbo turn as one... ...any backwards spinning of the turbo would also stop exhaust gasses from being removed from the cylinders... ...Causing bad detonation... ...and then loss of power...
As for physical damage... ...the stress on the turbo's internals may be minor... ...but over time something could break...
Either way... ...I think it is making the turbo lag greater... ...even if it doesn't feel like it...
Placebo effect???...
ahah social damage? u mean it will lift it everyone luvs it went they hear STUTUTUTUUTUT. I dont think it does any damage with the amount of boost running but even if it did so what it would prob take 10000 kms off my turbo life and thats a price i would pay to have a STUTUT but thats just me as i said some love it some hate it
  • 1 year later...
while were on the topic, where can i get a stock plumb back BOV? i have a 'turbosmart plumb back' & really not a fan of the sound, i want to be able to change gears & not be looked at by every person walking there dog. there hard to find i looked on ebay, nothing.. my 'turbosmart plumb back' is set up on the turbo side pipe from the intercooler, has a round hole where it slides on & a nipple with a tube running off it where the air gets released back into the system, can i put a stock BOV on there replacing it or would i have to do a bit of modifying? here is a pic..
http://viewmorepics.myspace.com/index.cfm?...imageID=3010801
i'll be selling the 'turbosmart BOV' as well so if anyones keen PM me >_<
Edited by azzafreddy
it does not spin backwards
the physics do not support the compressor or exhaust wheel or both spinning backwards with a blocked bov
the noise comes from a mid air collision of pressure that occurs in the pipework
its called compressor surge as the pressure spikes well past what the compressor can supply when the throttle body is closed and there is no BOV (or its blocked)
the excessive pressure makes the wierd chop chop tuutututu noise and places stress on the compressor wheel
If you have a a stock car and stock airbox. You can't really hear the bov, what if you have a POD in an enclosed box? Does it muffle the sound just as much as the stock airbox?
no, just as loud.
Hey mate... I've got a 1995 R33 GTS-T... I aint sure if i have a problem with my BOV... Usually when i rev up my engine and release it the valve opens fully and u hear the BOV go off at full.. But for the same rev it does not now... I also noticed that the cylinder tat moves n releases the pressure does not move much... Is somethin wrong with the blowoff...???
There is obviously a market for someone to make a cd with sucky induction noise and noisy bov sound for those who are that way inclined to amuse themselves without detriment to the car's performance.
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
