I havnt blocked mine, nor will, But i always wondered wether the turbo stress is just people guessing.. RB20 Cefiro's dont have a BOV from factory, nor do most Diesel Hiaces etc.. So if it was a problem, why did Nissan not put one there on the Cefiro?
it does not spin backwards
the physics do not support the compressor or exhaust wheel or both spinning backwards with a blocked bov
the noise comes from a mid air collision of pressure that occurs in the pipework
its called compressor surge as the pressure spikes well past what the compressor can supply when the throttle body is closed and there is no BOV (or its blocked)
the excessive pressure makes the wierd chop chop tuutututu noise and places stress on the compressor wheel
True, but they are also running low boost........the higher the boost the greater the air density, the more need for a functioning BOV.
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
