WELL UP FOR GRABS IS THE GTIR
LITED IS MOST OF THE ITEMS THIS BABY HAS
YELLOW IN COLOUR DOES STAND OUT!
12 MONTHS REGO
THIS LITTLE BABY HAS A LOT OF GOODIES ON BOARD
HAS TEIN SUPER STREET COIL OVER SUSPENSION
HAS STRUT BRACES FRONT AND REAR
HAS A 3 INCH EXHAUST TURBO BACK NEW KAKIMOTO REAR MUFFLER
BRAND NEW DAIKEN HEAVY DUTY CLUTCH
APEXI POWER FC COMPUTER
APEXI AVCR BOOST CONTROLLER
Z32 AIR FLOW METER
WALBRO FUEL PUMP
SARD FUEL REG
JVC MP3 PLAYER REMOTE CONTROL ALSO 6 BY 9 IN PARCEL SHELF
BOOST GUAGE
SAAS SPORTS STEERING WHEEL
CLEAR SIDE INDICATORS
MONZA BLOW OFF VALVE
NEW MONGOOSE ALARM AND CENTRAL LOCKING
BATTERY RELOCATED TO BOOT
CAR HAS SOME SCRATCHES AND A FEW LITTLE DENTS EXPCETED FOR A CAR THIS AGE
CAR IS AVAILABLY FOR VIEW MOST DAYS
EMAIL IF YOU HAVE ANY MORE QUESTIONS
https://www.sau.com.au/forums/topic/246600-nissan-pulsar-gtir-8500/
    • That ring thing is interesting how it's holding everything together
    • Hey guys. I have a 400R on its way to Australia from Japan currently and have a few questions I’m hoping others may be able to help with.   Wondering if anyone here has had any luck getting the Sat nav unit to work in Australia!? Assuming the Stereo is as simple as a band expanded and tv won’t work?  Seeing as they’re based off a Q50 which is Aus delivered is there any way to link that system to the nav? Nav modules and head unit are different part numbers and appear slightly different at the rear with plug ins etc. can I put my xtrail sd card into the rv37 and will that convert the maps or update to Australian? Has anyone got any advice here?     also has anyone fitted the factory remote start and Security system once it’s landed in Australia? I put an enquirey to Nissan Japan in via a third party, and they suggested it needs a Nissan Japan dealers device to setup and couldn’t guarantee if one here could do it or not. They can supply and I can physically fit it but to setup I would need a dealers device. Any information here would be appreciated also. I’ve seen one here with it fitted already prior to leaving Japan at a dealer/inporter, so clearly passes compliance and works when fitted Japan and doesn’t need changing here.      also, does the tyre inflation sensors work here? Does anything change with them when the vehicle arrives? Where are they actually situated? I’ve read they have batteries and they need to changing at times and seems like resetting involves the nav system?    any help here would be appreciated and any other aust specific information to help would be great. Looking forward to see what the current generation skyline is like and eager to see how many of the gadgets can be utilised here.  Thanks in advance
    • Do need to take it with a pinch of salt. One of the adapter failures, they clearly had setup issues with the flywheel.  One of the slipping ones I spoke to and it was pretty clear the throwout was riding, rather than fix, just swapped to a new clutch.    These clutches are being put in anything from 5k offroad 4x4 beaters, GR yaris, 500hp commodores to 1200hp barra monsters. Bound to be some issues in some of them when they are not a simple bolt in affair due to the changes in height.    There is a lot going on in this picture and unless I did the job myself no way to tell what really happened.
    • I did this mod in 2019  You just have to modify the top bracket of the ABS/TC/Fuel Pump Control ECU so it sits more upright and closer to the back seat and run a good quality positive battery lead from the engine bay, the negative lead i just bolted down to the body in the boot.
    • Damn... Not the feedback I want to hear.
