Hi everyone!!!
I've just signed up on the site so I'm not sure what am doing and if I'm in the right section.
I had the R33 S-II for about a year and got an Interceptor fitted. Eve since I had it I have issues with ignitions around 3.5 - 4K RPM.
being through 3 different tuners and spent a fortune but same story.
Just wondering if anyone’s successfully done this before?
the car is converted to Manual and got a high flowed turbo , greddy ele. boost controller
Thanks in advance !!! :P
https://www.sau.com.au/forums/topic/246615-haltech-interceptor-on-rb25det/
try give my tuner a ring, he's in WA and will point you in the right direction. he is a haltech guru
Aaron
in tune performance (bibra Lake)
(08)94346608
Eric
Thanks Eric... Will try first thing tomorrow !!!
I was thinking if this is useless, then get Nistune done. Has anyone done Nistune on a R33 series 2 before. because ignition/ coil packs are different in series I and series II ???
Any ideas pls????
i don't think nistune do a board for the R33, S1 or S2. also having the ignitors in the coils doesn't make a difference to the ecu. you've converted to manual, there are better options for engine management out there.
Thanks for the reply mate !! I know there are few different options out there but it all comes down to the cost of goods and installation then of course tuning. Nistune works out cheap even if I did it using a RB20 ECU, but the question is does this setup work on R33 S-II. I heard it works fine on series I cars coz the ignition is same in RB20 and RB25 series I.
Other option would be to find a 2nd hand PFC…
shouldn't be a problem, just have to check all the pinouts and match them up. all that comes from the ecu is the ignition signal, in 32's an S1 33's it goes to an ignitor pack which then fires the coils, in the S2 the signal goes straight to the coil which has a built in ignitor. the signal is the same from the ecu, just handled differently at the engine side of things.
mmmmm that explains a lot and makes sence. !!!! :ninja:
Had a chat to Andrew from Hyperdrive today and also Sam from Dr Drift who's got a daughter board for R33 ECU ($1100). So I guess I can either use RB20 ecu and Greddy MSS(for VCT) to do Nistune or get Sam to install the daughter board onR33 ecu and make it tuneable. I'm wating to hear back from Andrew coz after all he the tuner. I'm paying for not consulting a / the tuner and buying an Interceptor which cannot be properly tuned on a R33. I spoke to Aaron from In Tune today, he's willing to check the wiring and do few test ot see what's wrong but I think it's best to just remove the Interceptor and get a fully functional and well tuneable ECU rather than a piggyback..
    • The smart thing is to actually locate the pump at the right point down the hanger, so that the strainer can stay sticking out at a right angle, but near the bottom. This is the perpetual hassle with retrofitting any different pump to the factory hanger. Some just go where you need it to, some need fiddling and faffing, and modifying of stuff.
    • Some updates. After a lot of praying and some inspecting of crank threads, we've found that they were both kinda munted but nothing seemed terminal. The other option was drilling and helicoiling the crank. That is obviously the last option so we decided to at least try to get a OEM GM bolt in to GM Specs. So after honing/linishing the balancer from it's .002" interference fit to a .0018" to .0015" to .0013" it eventually slotted on to the crank. ATI state the interference is nominally 0.0007-0.0009... so it's still snugger than ATI reckon and explains the issues we had to fit the thing to begin with. New GM bolt went in at 37 ft/lb then torqued 140 degrees after which was EXTREMELY   but it tightened up to 140 degrees and it was a lot of force. So all things considered, the balancer is secured to the exact specs that GM want with the OEM Stretch bolt, (that ATI say you can use..) and the balancer itself is seated and snug AF. So WOO. Engine is now back in the car with lots of swearing. Bellhousing bolts done up, driver side manifold is on, AC Compressor and hard lines are back on the car. Next step will be to connect various engine bits/wiring/intake/radiator etc. Then oil and coolant and ... test start it? And of course, looking into this issue... which actually doesn't look so bad - It looks like it can be twisted back into shape with a set of multigrips. Anyone wanna buy my bonnet? Boy it looks good over there and sunk cost sucks.
    • Also this may be a stupid question, but how would you recommend getting the strainer on a downwards angle ? as they tend to obviously clip to the bottom of the pump which usually sits level 🥴
    • Most of the R33 GTST S1 are all like "airbag? What airbag?!"
