twin high mount is only possible befor monday this wkend, i just need a definate by this wkend, otherwise unavailable.
Twin low mount is usually $1400 but now only $1100
Single low/high is $1000
  • Replies 92
yeah i'm in leon,
rb26 high mount single external gate
how much extra for split pulse
Edited by blockasR32
ah man it fits. External gate or wha they will make it to fit. Xmas part at work tonight hada couple of to drink but alritew haha. Yeah if want a rb26nt twin high mount monday is the deadline. otherwise high single or low twins.............. all good, boost will make manifold to almost suit anything
Okay i have messaged mods and no reply but i cant edit any of my posts, its making this group buy difficult, but here is the new list...
1.Choku_dori - RB20/25 high external, sr20 high external - deposit taken
2.Shilohr32gtr - rb26 single high mount - deposit taken
3. wisey18 - R34 RB25DET Stock location, low mount, internal gate - waiting deposit
4. Tamimego - (ns.com) low mount sr20det t28 internal gate - waiting deposit
5. blockasR32 - RB26 Single High mount External gate - deposit taken
6. bigadz - lowmount sr20det manifold standard flange for GT2871R internaly gated - deposit taken
hey
I'm after a high mount manifold with external gate for an rb25/30 (in an r32 gtst). It will have a reasonably large turbo and with the 30 bottom end, the block will sit up 40mm (approx).
I just want to make sure that i wont run into clearance issues with my bonnet with this setup.
Can anyone confirm or advise?
Cheers
What is the cut off dates for deposits?
Once work has started what is the time frame on delivery? Will need some time to scrape some cash together before xmas :)
same here if there is more people will the price go down
it looks like 9 item mite be bought try for ten for a better deal
can he make this
r33 RB25DET Stock location, low mount, internal gate 3037hks pro s turbo
Edited by WARLORD
Not quite sure what you mean by a balancer pipe. But Twin low mounts are $1100. If you want twin high mounts let me know and i can have that arranged, but must be BEFOR monday.
If anyone can help me out in editing my first post would be very appreciated :)
SR20DET High or low internal or external all $800!!!!!!!!!!!!!
The balancer runs from manifold one to manifold two, it helps prevent turbo shuffle by balancing the presure. Heres a pic of DirtGarage's old set up (hope you dont mind Paul)
If they can be added to the group run im interested.
any pics for 26, twin, low, internal?
Bought these from the previous group run.. they are low mount twin RB26 internal gated.
can he make this
Yes that can be done. Cut off date is 14 DEC. Will get manifolds hopefully befor xmas.
Its $40 delivery anywhere in aus.
Ill ask about the balancer pipe.
4age is $800 highmount only.
Once again any mods going to answer my plees for help, ive asked everywhere. How do i edit my first post. I NEED TO!!!!!!
Great thanks mate.
You wont be able to edit it, the mods intorduced it for accountablility (ie scum editing the first post to cover their tracks) the only thing you can do is hit the report button on the post and report it to the mods. In the dialogue box just type in the changes and where you want them to go.
Cheers,
Johno
are you sure he can do it in the stock location as this is the email i got from kyle two weeks ago
""I can't build anything in the stock location mate, there would definately be gains to be had, but there just isn't room to put anything in the stock location. it would require a new dump in either location. Build time would be 2 weeks.""
Kyle
I will call 6boost and talk to them, see what they say. ill pm you back and let you know..
cheers
hi,
Just wondering if you had a chance to ask 6boost about the clearance.
Thanks
Zac
Kyle
Hey,
Thats odd... I just text him and he told me low mount is stock location... He will be on here to reply a post soon, just keep an eye out
I actually met Kyle last night. A "cruise" was organized to Palm Beach.
Some very tough street cars in attendance as you would imagine. I was convinced to get on this group buy lol
So how do i out my deposit down?
Kyle told me i could give him my cheap highmount and he would match the location of the turbo so it would still fit my custom dump. And at no charge i might add.
do you want me to send it direct?
    • So, it's clearly an electrical problem. Either with the gauge itself, or the sender. It appears to be voltage sensitive (ie, alternator output affects the reading.
    • Yes, at this stage of SAU threads, I  automatically assume that anyone here knows that everything depends on each and every setup and its choice of parts and what an individual wants from the setup. I think your misunderstanding what I've said, I'm not saying your curve will move to the right.. I'm stating the opposite; that my setup has a much larger turbo than my last one, my current exhaust manifold runners are 2-3x longer than the last one, the intercooler is longer and thicker (hks 103mm thick), the itbs are now oversized from 45mm up to 49mm, and the plenum is now a larger Nismo plenum that's been port matched. As a result, I'm making more power, torque and boost 1000rpm earlier than my last setup. My curve moved left, in a big way. You guys with 800-1000+hp turbos should be considering hks v-cam or the other Japanese company Sakura who makes RB25 Neo vct adaptor kits for RB26's. they all make more power / boost / torque far earlier and higher peak numbers. Dahtone Racing modifies the Hks v-cam systems to his own specs and he also developed the worlds first and best dbw individual throttle body kits, to complement his V-cam. Every single car is 800-1200+hp and they all produce huge gains in response and peak power.
    • I have a 2008 Skyline 370gt with about 160,000 km on the clock currently. A while ago, I noticed the temp gauge would start climbing but it comes down when I give it some throttle. I took it into the shops. The technicians comments are transcripted below. Reported they couldn't find anything wrong with the vehicle mechanically and they pressure tested the cooling system. Funnily enough, the technician commented that the temperature dropped back down when the car is stationary but this is when I'd notice the temp gauge to be climbing. Just wondering if anyone else experienced anything similar to enlighten me? Cos at the onset, the temps were going up one tick and then comes back down when I step on it. Now, the temps are climbing all the way to the top of the gauge, and it's making me very nervous lol. It also doesn't come down to the neutral position anymore. PS I do have a small exhaust leak near the drivers side caused by when I got f**ked by a really steep driveway at a mall I never visited before. Not sure if this would affect the sensor. Technician comments: Check and verify Fan/Cooling system - ALL OK max 106*C and fans operating at 100% Cools down right away. Checked Fan Operation - 55%@101*C, 85% @ 104*C and 100% @ 105*C Vehicle did not exceed these temperatures with max load. Temperature recovered back to 99*C after fan operation while vehicle Stationary.
    • It really depends on your setup. Mine is 'accidently' more suited to revving higher. bigger cams, turbo etc. Plus my super long first takes donkey years to come onto boost, so if it will move my power band to the right, maybe i'll pass on this. i have a G45-1500 going on there soon which I suspect might make it more of a fat pig.
    • Yeah good call, I will endeavour to tuck that down when I rewrap the looms it’s pushed up by
