hey guys.....sooo..today was the day...went to pick up my baby after an awaited time.... she got 249.2rwkw :( BUT!... tuner tells me i have an exaust leak... which i assure you was not there when i took it to em'.. so i bring her home and sure enough on the way home its like driving a tractor...now i have had this once b4 and it was my high mount manifold... but i just jacked the car up and i dont see any holes on the manifold at all.. i noticed that the gaskets for the ext. gate are lookin kinda burnt... so guys can everyone (its within the engine bay) just tell us the more obvious spots for it... could it be turbo to manifold gasket?? if so how can i check without pullin the hole lot out...
any input is awsome... thanks everyone
https://www.sau.com.au/forums/topic/246670-r33-exaust-leak/
Same prob for me yrs ago, same spot.
The 4 bolter gasket between the turbo and ex manifold.
Only takes a little to drop out and you have a leak, and it's hard to see all 4 sides properly
Get a genuine Nissan one too if that's the case, not a soft ebay job, cause they are soft...
https://www.sau.com.au/forums/topic/246670-r33-exaust-leak/#findComment-4287772
when the car is dead cold start it and feel around for the leak.
You have about 1 minute before it gets a bit too warm
With a high mount you have the manifold-turbo gasket, manifold-gate and turbo-exhaust.
It'll be a big leak so very easy to find.
https://www.sau.com.au/forums/topic/246670-r33-exaust-leak/#findComment-4287917
soooo shortly after posting i went hunting for the leak.....found it at the manifold to wastegate join.... gasket was blown to shit and back... i have a JJR ext. gate..and man they are the worst design ever... like... you cant even get the bolts done up properly cause they rub agaist the body of the gate...stupid..any way... replaced them with some nice metal gaskets :D:)... took her for a spin... and sure enough.... the tractor returned...both gaskets blew out... so i bring her home and pull off the gate again.. (worst four bolts of the car) chucked in some metal gaskets again from an exaust shop... just finished then...started her up and can feel leaks again :ninja::)... i think the flanges are either warped or there is something on the flanges that leakin it...so ill give her a drive but can almost guarantee that it will blow out again.... junk junk junk....
thanks for the input guys.... champions
https://www.sau.com.au/forums/topic/246670-r33-exaust-leak/#findComment-4290074
Thats the 38mm gate?
The genuine hks is no better. I've forgotten the number of times i had that bastard of a thing off and on and cursed the design. I actually had issues with the outlet though, never the inlet.
Get the faces machined flat and install some studs on the manifold. Get some narrow nuts (12 max, 11 preferably) and a 1/4 inch drive socket set with wobble attachment. I ended up buying a sheet of exhaust gasket maker and made my own as the thing was off so often. I never had leaks. But the head/manifold and gate outlet leaked after every track day....
https://www.sau.com.au/forums/topic/246670-r33-exaust-leak/#findComment-4290096
    • Come to Eastwood, you'll get plenty of that 馃ぃ
    • Oof, I will forevermore have those shredded gears in mind whenever someone talks about showing mechanical sympathy towards their car. Thanks for the photos, fascinating stuff!
    • Curious to see how the SpeedTek stuff holds up
    • The holdups last year were drivetrain related. I had the car out right after getting the bearing issue resolved. Third launch and the car didn't move after releasing the clutch. It had sheared all the engagement teeth off the 1st gear.    Thankfully no other damage was done. I set an aftermarket gear beside an OEM gear and found that the engagement teeth on the OEM gear were much larger and better supported. Looking through my bin of spare transmission gears I found that there are two types of tooth on the OEM first gears - the larger tooth and the smaller tooth. It looks like most aftermarket gearset manufacturers base their design on the smaller tooth. OEM large tooth left - Speedtek, OS Giken, etc or OEM small tooth right Decided to give that larger engagement tooth a try. Pressed the ring off an OEM gear and sent it to a transmission manufacturer here in the States. They did their "faceplating" operation with my synchro ring on the Speedtek gear.   I reassembled it, took it back to the track and promptly destroyed the gear itself.  I'll rebuild this and use it as a spare - thankfully just first gear and the countershaft are damaged beyond repair. Definitely disheartening but my welded on engagement tooth ring held up!  Moved to Speedtek's dog engagement design as the gears appear to be much stronger. So far they have taken much more abuse at the track. Also scored a Stillway lockout from the Netherands for super cheap. It's for some other RB transmission so it took a bit of fabrication to fit but honestly a very easy job. I also had to heavily modify the gates as they were very different.   Then for some reason at the last test and tune a silicon coupler below the throttle blew off and took out the radiator and fan. Thankfully it was in the burnout box and not down track. This car is really beating me up - I still haven't made a pass in it. Ran it through the gears many times on the street but it keeps biting me at the track.  Currently in the process of replacing the radiator and remaking the throttle pipe to remove the coupler and use a cast 90 and a vband. I WILL get this thing down the track...
    • Covers most of the above points really. There's a few exceptions but most just see driving as an irritating but necessary task they must complete if they want to get anywhere on time. Also see it as a good time to show their awesome multi-tasking abilities on their mobile and/or doing their makeup.
