hey guys.....sooo..today was the day...went to pick up my baby after an awaited time.... she got 249.2rwkw :( BUT!... tuner tells me i have an exaust leak... which i assure you was not there when i took it to em'.. so i bring her home and sure enough on the way home its like driving a tractor...now i have had this once b4 and it was my high mount manifold... but i just jacked the car up and i dont see any holes on the manifold at all.. i noticed that the gaskets for the ext. gate are lookin kinda burnt... so guys can everyone (its within the engine bay) just tell us the more obvious spots for it... could it be turbo to manifold gasket?? if so how can i check without pullin the hole lot out...
any input is awsome... thanks everyone
https://www.sau.com.au/forums/topic/246670-r33-exaust-leak/
Same prob for me yrs ago, same spot.
The 4 bolter gasket between the turbo and ex manifold.
Only takes a little to drop out and you have a leak, and it's hard to see all 4 sides properly
Get a genuine Nissan one too if that's the case, not a soft ebay job, cause they are soft...
https://www.sau.com.au/forums/topic/246670-r33-exaust-leak/#findComment-4287772
when the car is dead cold start it and feel around for the leak.
You have about 1 minute before it gets a bit too warm
With a high mount you have the manifold-turbo gasket, manifold-gate and turbo-exhaust.
It'll be a big leak so very easy to find.
https://www.sau.com.au/forums/topic/246670-r33-exaust-leak/#findComment-4287917
soooo shortly after posting i went hunting for the leak.....found it at the manifold to wastegate join.... gasket was blown to shit and back... i have a JJR ext. gate..and man they are the worst design ever... like... you cant even get the bolts done up properly cause they rub agaist the body of the gate...stupid..any way... replaced them with some nice metal gaskets :D:)... took her for a spin... and sure enough.... the tractor returned...both gaskets blew out... so i bring her home and pull off the gate again.. (worst four bolts of the car) chucked in some metal gaskets again from an exaust shop... just finished then...started her up and can feel leaks again :ninja::)... i think the flanges are either warped or there is something on the flanges that leakin it...so ill give her a drive but can almost guarantee that it will blow out again.... junk junk junk....
thanks for the input guys.... champions
https://www.sau.com.au/forums/topic/246670-r33-exaust-leak/#findComment-4290074
Thats the 38mm gate?
The genuine hks is no better. I've forgotten the number of times i had that bastard of a thing off and on and cursed the design. I actually had issues with the outlet though, never the inlet.
Get the faces machined flat and install some studs on the manifold. Get some narrow nuts (12 max, 11 preferably) and a 1/4 inch drive socket set with wobble attachment. I ended up buying a sheet of exhaust gasket maker and made my own as the thing was off so often. I never had leaks. But the head/manifold and gate outlet leaked after every track day....
https://www.sau.com.au/forums/topic/246670-r33-exaust-leak/#findComment-4290096
    • Thanks again, really helpful chap from alpha omega wanted to speak to me, little concerned if this is meant to he aero alloy/ airospace quality and car sitting on drive has caused this.  Airplane are subject to much more changing temp and conditions than road salts! My caliper, many other components much older have surface rust but never eating part of the metal   Had I not seen it , could have been a disaster! specifically on rear part of bracket coming off like biscuit will update on what they say, helpful people so far
    • January or Feb is it booked in for turbo fitment?
    • The MX5 has had some annoying rattles in both front doors over bumps So I installed fancy pants door bushings, which stopped all of the rattles with the windows up, but........with the windows down there was still rattles, so after some googling,  and a chat with MX5 Mania, I got some new door to glass weather seals, all the rattles, windows up, or down, are gone now Shout out to MX5 Mania, the weather seals were on sale, and when I head to Dural to pick the up they even fitted them for me for free I did see a "really" nice Blue NA sitting out front   and this Black NC PRHT that looked like it has sat in the sun for its whole life and never had a wash, the clear coat was non-existent, an it looked horrible, really horrible, but, it had a nice turbo kit with over 200kw, the thing went like a cut snake, bagging the rears through the gears and dosing like a champ 😍 But, as I've always stated, I am keeping my NC na, I'm happy with the current power the car makes In other news: MX5 Mania do a drive in drive out turbo kit, the only minor additional part recommended for boosting my car, as it sits now, is a oil cooler, and that bonnet vents are definitely required for track use Aftermarket version look a bit to "racecar" spec I wonder how Focus RS bonnet vents would look?????
    • Paint is only structural when applied to the outside of Chinese and Indian cars. Otherwise it should never be present between mechanical joints that were intended to be metal to metal. Pain slips, slides, cracks, compresses, and add thickness that wasn't intended to be there. It comes firmly under the category of "just no".
    • appreciated it thanks   There are threads on the adaptor. I rear re anodising but didn’t know it will reduce strength   re mating services needing to be flat/ not painted, why would that be? I am devastated as car been off for a year, fixed power steering then installed bm57 master cylinder and just before driving it this came up. So annoyed   worried and afraid to drive it, no fun caliper coming off
