nah got it through a local performance shop
i have sold my car last week and never got around to putting it on
should spool up at about 4rpm
and give a pretty solid kick.
Needs an ext gate and adaptor.
price is nego. make an offer
Originally posted by DISZ-IT
bump,
i suggest try another forum i tryed selling mine on here for about 3months! Alot of people ****ed me around too, not mentioning any names....anyways...goodluck with the sale mate.
I'm thinking If you don't like our Forum then you should leave and go post somewhere else. We don't really care if you are here or not.
Goodbye and Good Luck.
Neil.
kkk are actually used on mercedes and saabs, this type of turbo was designed for a truck, but a petrol truck engine... if ur engine can create enough exhasut gases to make this baby spool u'll b laughing cause these are good to run 29psi all day.
NDR - i have nothing against the forums, just jerks like Al, ive sold and bought many things on these forums. when i said to jizzmo to try another forum it was because the item he was selling was more suited to rotary engines and i knew he'd have a hard time selling it...
    • Sell it and buy something newer? 😛
    • Better then PooPooG... or is it PeePeeG?
    • The steering wheel on my 97 s3 gtr is a little bit worn out, so im on the hunt for something mint. I notice that this type of steering wheel is on several other nissan's of the era.  Does anyone know if their all identical, or are there slight differences? I feel like gtr tax applies to anyone selling one, but if it comes from any other car the price is much less, even though its the same design.  Chat gpt says the material for the gtr is slightly different and it says gtr on the wheel, but every pic ive seen it just says nissan.
    • I might have to say it.
    • Ahh... it's an early RE5R01A box, that means the pinouts I gave are wrong (they were for the RE4R01A 4-speed box)... I'll have to dig around in my docs to see if I've got that schematic (they used the same gearbox plug, with the vacant pin wired to the direct drive clutch solenoid)...prolly hidden away in a supplement somewhere... ...there were 3 variants of the RE5R01A ~ this early schema was what we called the 'dumb' 5 speed ; it's what jatco called a 'medium duty' box, with torque holding up roughly ~200ft/lbs or so, which was good for NA from RB20/25DE and up to around VG30 output spec. With the RB25DET (and VG33/35 mills), the only options they had was the 4-speed 4AX00 box, which had been beefed up to handle the extra torque (primarily for the VG35, but it also suited the RB25DET mill and others)...and the RE4R03 box in large 4WDs a lot of the time... ...the next variant of 5-speed was redesigned, stronger, and 'smart'...first ones had external TCU with internal (on valvebody) Shift Control Unit, pressure switches, and 2 x TSS...and the last ones had internal TCU+SCU setup, with CANbus control etc etc. @DRoc81 On the RHS of the box towards the rear, there should be a stamped silver ID tag -- what's the model number? Oh...and with the early 5-speeds, the torque converter control solenoid assembly should be replaced as well (31940-60X00)...it's a bit Murphy's Law ....if one has failed, bet on the rest not being far behind ...
