Beach To Burger Crusie Wrap Up 27/11/08
LEANBAC
 Share
Just want to say thanks for everyone that made the night what it was. Lucky for us the weather was on our side. We had 20+ cars, an around 25+ people turn up $ ching ching $ now lets WHORE THIS THREAD UP an show them what they missed out on! :P
special thanks to the camera men:
RCHOO, BASTI, GAZAL
thanks to PAT AND KRIS that helped put it all together
hope to see you all at the '' show N shine '' this sunday 30/11/08
  • Replies 129
haha was good cruise, glad that it turned out all good. There were a couple of times we got split up, but the cb walkies helped us keep it tight :P
It was nice to see that we could squeeze 7 skylines through a green turn signal haha, if only every driver on the road was that alert, there would be no traffic :)
Burger's were awesome and lucky us for it being empty when 25+ of us rushed the little store haha
The waitress that AP smooth talked :) asked us how we formed such a large group, whereby dezz replied it was a skyline car meet and surprisingly she knew what type of car they are hehe
Nice photoshoot to end the night and a possible st.kilda motorkhana plan :D
Same time next week? :P
cheers
 Share
    • People still have Skylines? I thought they're non-existent now.
    • Harness update time have had great fun and learnt so much already so far with this project. I started off making both the ignition and injector sub harnesses in the hope any mistakes i made here aren't as hard to undo and learn from as the main harness.  A cool comparison of the old harness using presumably TXL wire and the new which is using Tezel. Also opted to use DTM plugs to keep the whole setup as neat and tidy as possible and tucked the wiring under the coil bracket to try and keep it all from sticking out too much. Although the injector harness, I'm not overly happy with as I'm still using the rubber boots that are supplied with the type of plugs it just looks ugly and sticks out like a sore thumb with the white identifiers so a slight redesign may be done.   Then it was main harness time and most importantly trying to route it nice and away from the heat it will use the OEM heater hose routing which is no longer present to keep the harness up high and secure. it's amazing how much smaller this harness is able to be compared to the old one. plugged everything into the emtron and with the help of the tuner again attempted to start it up and instantly fired up and running smoothly on all 6 which was a big shock to myself. So still some routing and adjusting to be done for the final fit up and installing a knock sensor harness plug which is in the post all has gone surprisingly well.     The old harness for shits and giggles.
    • They do that at random every now and then, with almost no detectable cause. Mine has done it a couple of times (over 25 years!!). Never worked out why.
    • I don't post on here and have been lurking for some time now. Many of the topics have helped me out more times than i can count. I was racing yesterday (11/9) and blew a front right CV shaft. I have spares so I popped a new one in. A thread i read previously said to check the engine mounts if you blow a front CV. Upon inspection, the front right mount was completely separated from the upper plate. This discovery saved me time and money, because i would have blown another CV if i went back out. Just wanted to thank you guys and wish everyone luck with with their builds. (Now if we could only come up with a solution for my power steering belt flying off after hitting the rev limiter, lol)
    • Either way he still need those style of spacer to go into the manifold because the photo he currently has is not going to work
