Yeah they have similair if not the same caliper as Ceffy and s13.
I plan to chuck Z32 calipers on mine...
I know no one in Australia has probably attempted it but the Cima is heavy as and definately needs a brake upgrade.
I have seen GTR calipers on a set of Y31 cima front coilovers
do you reacon new rotors will be needed or is it possible to use the original rotors
https://www.sau.com.au/forums/topic/246744-y31-brakes/#findComment-4298357
I will need new rotors and the car is 5 stud
maybe i should go to r33 disc and calipers? or R32 GTST disc and calipers somthing along these lines sorry i have taken so long to get pictures just been working getting other car ready for weekend
https://www.sau.com.au/forums/topic/246744-y31-brakes/#findComment-4301622
  • 1 month later...
Bump well the brake rotors are off and there a Hub style disc like the r31 but there 5 stud so this has chucked me right off knowing what would match it
there 260mm and the hub itself goes in stages.
so disc witdh is 24mm MIN then the hub is 31mm then there is a extra bit on the hub that is 19mm
https://www.sau.com.au/forums/topic/246744-y31-brakes/#findComment-4363312
  • 1 month later...
  • 3 months later...
  • 9 months later...
Win.
Rear brake pads I believe are DB1144, had a look at my pads when they were out and also a look at a picture of them. they appear to be correct and are of the same era as the cefiro. Pads listed are for Nissan Cima (check your bendix cat's)
can confirm this tomorrow when they arrive.
100% Confirmed part number for New rear brake pads by Bendix. DB1144GCT.
WIN!
I'd assume the fronts follow the same fashion.
Likely listed in Bendix catalogues as Cima, same same as A31 Cefiro but I do beleive A31/C33 front is exactly the same as SR20DET ? (there is some arguement about this).
Regaring direct bolt ups, S13 calipers would bolt up directly anyway, as should any Nissan caliper, R33 GTST and Z32 being the favorites.
Otherwise just take the whole knuckle assembly with 5 stud hub off something else and do a big 5 stud brake upgrade.
Do these use the same rear cradle as A31/C33/R32, etc ?
Looks a tad weird to me...
https://www.sau.com.au/forums/topic/246744-y31-brakes/#findComment-5199410
  • 2 months later...
no these use a r200 long nose, same as a hr31..
brakes are basicly r33 na brak, havent checked padsyet, they are not sr brakes, they use the same size rotor but with a larger 2 pot caliper. i have been playing since last post. i am just about to bolt s13 front hubs and shizz in with s13 coilovers. these brakes are actually a really good upgrade for stock sr rotors. and bolt straight on.
woo go me,
https://www.sau.com.au/forums/topic/246744-y31-brakes/#findComment-5344917
  • 1 year later...
Hey E-Z,
I've got a cima Gloria same colour and req a front disc rotor and wondering on some sort of substitute without doing the whole coil over upgrade as my airbag suspension and all electrics are working fine and it's still 100% original including the crocheted cima embossed head rest covers.
Cheers Tony
https://www.sau.com.au/forums/topic/246744-y31-brakes/#findComment-6237490
  • 4 years later...
so just found myself with another Y31 Cima
By the looks of it has been upgraded to the R33 NA rotors and brakes but I was looking at going for 4 pots as my spare Cima is now likely going to be used for the track.
also wanting to do a 4 stud conversion on my new road car to fit some old skool Rays 3 piece alloys I have.
So am attempting to fit some 180sx hubs today
Will hopefully post pics soon, but just wondering with upgrading to 4 pots will i need an adapter if I use the 300zx rotors
https://www.sau.com.au/forums/topic/246744-y31-brakes/#findComment-7776388
  • 2 years later...
    • Just be warned that that turbo will not be a direct re-fit to the car. The exhaust housing is, of course, in the same place. It has to be - it's bolted to the exhaust manifold. So the dump will fit up. But the centre housing is not as long, so the comp housing will move backwards. This will affect both the turbo inlet and the outlet. There is fab work that needs to be done. Yes. it has one, it should have one. Paper gasket.
    • I only recently purchased the vehicle, it came with the flex setup but the current tune is e85 only, which is why im wanting to get the tune redone to enable a mixture.  First i need to get the exhaust redone tho. I was thinking of getting a varex muffler but it sems they dont fit well in the 33 (hang low because of the valve mechanism which sticks out on top) and generally dont sound good. So that leaves me with redoing the entire exhaust (more resonators and mufflers) so its not a menace when i come and go from home, and then have the aes dump valve somewhere along the line to really open it up. I was thinking of having it before the cat but after seeing how insanely loud it will be (on a vl turbo) im thinking of putting it more towards the rear of the car, after one of the resonators.
    • At this point I'm just 'hoping' it's the turbo seals. I did speak to someone who said it's normal for these turbos to have a bit of axial play? Not gonna lie I've never checked a turbo for axial play before but you could hear it tapping a bit as I moved it back and forth. Surely that's too much? My theory is (could be completely wrong), bad axial play, worn bearings, bad seals, oil into dump/compressor side, burns in exhaust = blue smoke. On a timing belt related note, my crank pulley was missing that front plate that sits in front of the timing belt. It's that metal round plate. It did have the rear one, and the woodruff keys are in the crank which was nice. Can anyone confirm if the NEO det engine has a front plate, im sure it would to protect the front of the timing belt or something. Water pumps...the pump I got was an NPW (yes grill me if I should've got a genuine one lol). It has a smooth mating surface, kit came with a pretty pathetic looking paper gasket. Do I need to use any RTV or just trust the gasket will work because its a smooth mating surface? Cheers legends have a good Easter break!
    • Cheers man, I thought the same.   Bit of an update on it all. It was definitely blue smoke, not grey after all. It didn't really smell oily but it was blue after all. Also puffing just the smallest amount on idle with no throttle.   I ended up pulling the intake and exhaust off and there was around 3mm of axial play on the turbo shaft. So I figured we'll that's buggered and sent it off to get hi-flowed at hypergear. Haven't got it back yet.   I haven't compression tested it yet. Had a look in the cylinder and cylinder 1 spark plug, looked a bit sooty but not oily. Then I've just started doing my timing belt because it's age is unknown.
    • In that case it is probably stock. It lives in the navigator side footwell behind the plastic trim just in front of the a pillar.
