BUMP-UP! still heaps availble, check posts for the BC web link to pics and heap of parts. NEW PARTS WILL BE ADDED THIS WEEK, R33 parts, rb20 Motor parts and some aftermarket goodies!! Hame
  • Replies 101
hey mate, you got the rear baffle plates off an R33 at all?
there the plates that sit behind the disc, they have all the handbrake assembly
PM sent to you man
NEW PARTS:
6x Rb20 standard injectors 340cc
Item Condition: used, standard injectors, includes o-rings if need be.
Price: $60.00
Item: 1x Rb20 standard fuel rail
Item Condition: used, painted black
Price: $40.00
Item: 1x Rb20 standard throttle body
Item Condition: used all in fine condition
Price: $40.00
Item: 1x Rb20 standard intake manifold/plenum
Item Condition: used, no leaks, comes with coolant lines (painted red), injector o-rings, unit is blanked black.
Price: $65.00
Item: 1 x R33 rb25det nose cut loom
Item Condition: used, connects to lights etc, has horn set up and bonnet release all connected
Price: $40.00
Item: 1 x R33 rb25det aircon condensor
Item Condition: used, no fins bend, comes with brackets, perfect condition
Price: $70.00
Item: 1 x R33 series I (one) passanger side headlight
Item Condition: used, in extremly good condition, not yellow like most others, no cracks, scratches.
Price: $70.00
PICTURES ALL ON THE BOOSTCRUSING LINK BUT CAN PROVIDE THEM IF NEED BE,
cheers hame!
r32 altornator sold
r32 smic with piping sold
r32 exhaust manifold heat shield sold.
have interested in the r33 intake manifold!
heaps left guys, hame!
hey mate r33 castor rods sold.
AS i said there is the most current updates etc on the boostcrusing.com add (linked earlier in here) there is about 5 x as many parts in there as there is here as u cant edit well in here. if u want something post or pm me.
Also have a bear rb20 block and head available (best offer is $60) thanks guys!!
Hame!
New Items to be added:
Item: 1x R33 Skyline GTS-T ECU (manual-turbo, Series II)
Item Condition: used, perfect conditions, reason for sale is upgraded for PFC!
Price: $90.00
Hi mate has this been sold yet?
pm me
No r33 turbo thats sold! have an r32 item with blow exhaust wheel, suit rebuild (taking offers)
Also manual r33ecu sold!!
Drift pod filter and adaptor sold also!
Heaps more stuff guys!! full r33 a/c etc..
Hey guys going to visit the r32 gtst wreck today witha trailor, if anything you want please text me on 0419761510 so i can pick it up for you thanks, hame
NEW PARTS!!!!!
Item: 2 x R32 doors (maroon)
Item Condition: used, comes with door trims, glass, power window motors, side mirrors
Price: $150.00 each (Front and rears available)
Item: 1 x R32 SMIC
Item Condition: used, no fins bend, comes with brackets, perfect condition, comes with plastics for CIA
Price: $60.00
Item: 1 x R32 rb20det aircon condensor (and all a/c)
Item Condition: used, no fins bend, comes with brackets, perfect condition, all you need, ac was working fine when in car just need re-gass
Price: $170.00 or offers (comes with the lot!)
Item: 1 x R32 instrument cluster surround
Item Condition: used, perfect condition, black no scratches
Price: $50.00
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
