Hi
Wanting to upgrade fuel pump in my R33 GTR, I want something that sits in the factory position and clips in like the stock fuel pump does
Besides the Japanese pumps, TOMEI, NISMO, SARD etc which are like $400 + is there any other pump that can use the standard mounting bracket, in maybe a BOSCH model?
Don't mind if it has to be modified 'slightly' as long as it sits as the factory fuel pump does and flows like a NISMO/TOMEI etc
Any help would be appreciated
Thanks
https://www.sau.com.au/forums/topic/246782-r33-gtr-fuel-pump-upgrade/
the japanese pumps, nismo, tomei etc are well worth the money. in both of my heavily modified GTRs I used japanese pumps and couldn't be happier. they fit straight in in about 10mins. sure you can hack up your cradle to fit a bosch pump, but the number of times I've seen people fit an aftermarket pump to the stock cradle and then get fuel surge due to improper mounting is insane. considering how important good fuel supply is I would spend the extra few bucks and get a nismo one.
out of the japanese fuel pumps, which do you beleive is the best choice?
they are all much of a muchness. i've used nismo and tomei and hks. if I had to buy one now, I think i like nismo the best. dunno why, I just have an image of them being slightly nicer quality. but in reality there is bugger all between them.
Probably the best thing about Nismo is that 99.9% of the time is going to fit perfectly.
well i just fitted a gen. walbro fuel pump..rated at 550hp..
its like half the size of my stock fuel...
it was the BEST fit...and i didnt think it would..but wen i saw the pump..i was lik wow!...lol
which is way smaller than an bosch 040!!!!!
but i drive a gtst...
But i was gona buy a tomei one..its lik an extra 100ish bucks...
but its really up too u..
it fix a lot of flat spots after installed too.. :P
Thanks for that Adam
Anyone put a BOSCH 044 into an R33 GTR tank?
I put one in a 32 GTR tank; I don't know how different they are internally to the 33 tank.
I wrote a tutorial on it and someone was kind enough to take photos, you'll find it in the DIY section
It may be of some help, I don't know.
In a 32:
* It is not a drop-in replacement (cutting/fabrication/adapters needed, but the work is pretty simple).
* It is as quiet as the standard pump was.
* It flows more than enough fuel at ~65psi (something that walbros seem to struggle with).
If you can verify that your aftermarket pump of choice:
* flows enough fuel at the target pressure
* is a drop-in replacement
I'd go down that path. Drop-in replacements are always that much easier to deal with and you can always go back to standard anytime you want to.
Regards,
Saliya
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
