just cruisin along in rain the other day and all of a sudden my charge, brake, door, & fuel lights all came on at once. and they're still on!
there is nothing wrong with any of those things on my car, it's just a freak lol...
https://www.sau.com.au/forums/topic/246783-danger-will-robinson/
There is a little black plastic pack on the back of your alternator. It is full of diodes. Diodes that are usually broken - causing all manner of electrical mayhem. Have a look inside and make sure they are still in one piece. Cheap to fix though - give it to an auto electrician to sort, or look for another 2nd hand one in better shape.
That will be the bulb-check relay turning on, due to a charging fault.
That relay gets it's earth via the alternator, so once it starts charging, the earth is lost.
If you get a 'xmas-tree' on the dash with the engine running, you can consider that it's kind of a BIG charge light!
Yep, all the dash warning lights come up when the alternator is stuffed.
Wouldn't bet on being able to repair this "black box" on the back of the alternator, alot of nissans have an internal regulator which involves disassembling it to have it fixed.
my battery finally ran out of puff lol. just gotta wait till pay day argh!!
any ideas what other cars share the same alternator?
what car you got? L Series i assume. 200b, 180b, 280zx, 240 & 260z, even r31 skyline RB30 alternator can fit
  • 3 weeks later...
forgot to follow up on this sorry...
found a brand new Hitachi FN 50A unit for $75 new from a wreckers. took me a record 20 minutes to swap! easy as :)
"wham bam thank-you maam"
cam
    • Which manifold mate? Meanwhile......Mark is wondering how bonnet vents would look on the NC 🤣
    • Actually,  just remembered there should be info in the threads (somewhere) about swapping to a manual steering rack and deleting power steering all together.
    • Also had a look at the Nissan JP website looks like the 400r has a slightly shorter ratio than than the regular V37 3.133 VS 2.937 which from a guy who has driven both 3.69 vs 4.11 ratios in the S15 is bugger all. Seems that the AUTO Z runs the same ratio as the 400R but can't find any info as to if its an open or LSD? More often than not the auto LSD is open
    • Do not replace the power steering lines with this stuff. If it's anything like the Chase Bays stuff it will leak and be worse than stock. The reason why the reservoir is on the LH/passenger side of the car is because that's just where the reservoir was most convenient to fit. Don't overthink this stuff. The intake/cold side of the engine is pretty busy on these cars. And again, the hardpipe is designed to be a janky power steering cooler. In theory you can replace it with a real power steering cooler but that's really only for track use where boiling the fluid is a distinct possibility. Start with the low pressure lines feeding the pump from the reservoir. Make sure there isn't a bunch of junk in the reservoir filter. Be careful to not get ATF all over the engine bay. I hate dealing with ATF spills, you can clean it up and the slightest crevice will still release more oil that can still drip over time. You also want to inspect for leaks before you make a mess and can't tell what happened. Most likely you have a leak somewhere that is allowing fluid out and air in. Failing that it's allowing air in but not fluid out. Only place I can really see that happening is on the low pressure side because the pump will pull a slight vacuum to draw fluid in. Everything after the pump is high pressure or lower pressure, approaching atmospheric by the time it returns to the reservoir.
    • I did a skidpan night at SMSP this week, it was much cheaper than $350. But yeah, you need to slap an LSD in that thing.  I put an OS Giken in the 370Z and it's f**king MARVELOUS even compared to Nissan's viscous LSD. So you're saying it's free now that it's a housing estate? 😂
