Cheap R32 Skyline Gtr Look A Like $5000
By CanadianGuy · Posted
Finally had some time after working on other projects to jump back on this thing. Pulled all 4 wheels to check the brakes over and lucked out, only needed to bleed them/change fluid to get everything working! Took it for its first quick spin (around 2km) up the road and ran great! Sounds like I have a left rear wheel bearing that needs replacing and there’s a shake in the steering wheel but the tires are absolutely junk on this thing and had been sitting flat when I went to first look at the car so we’ll see if that’s the cause. Tach randomly started working but I notice if my hicas light comes on the tach stops working 🙃 yay for electrical gremlins -
Bunnings car park it is! if you buy the kind of dampers with the adjustable top on the strut you can see it, red, purple? So many options.
Yeh a meagre benefit, what strut tower brace are you using? Eventually all the suspension and tyres are done and you get to ... meagre benefits. Narrow end of the wedge, all that stuff.
Yeh not doing anything with spacers at all, ty for the info
Indeed. Mitsuoka always did their magic on various Nissan models, but because the Nouera was going to be in the medium sized sedan class, they decided not to try and modify the 2004 P12 Nissan Primera because it looked too modern combined with the 1940's styling. It would contrast way too much so they went with the more suitable CL7 Accord... 😆
