I'd say the tuner would be risking it... might be good for the street but what if something happens on the dyno for it to reset/ reengage or anything like that...
As on the dyno it will want to put torque to the front wheels as it thinks the back end is completely "slipping" out at over 150km/h, thats why my tuner will only put my car on without the front shaft to be sure.
Where are you reading these faults from? the attessa computer in the rear of the car has its own little L.E.D on the unit that flashes when there are faults, it wont flash on the cluster like a RWD skyline does, it will only turn the 4WD light on which is basicly telling you to look in the boot at the module and count the flashes there. The series of flashes you are talking about wont output from the unit in the boot. If your reading them from the cluster then its 77 for rear heated oxygen sensor circuit and 43 is Throttle Position Sensor but i dont know what its doing if your reading the flashes from the unit in the boot.
Reading form the ECU in the boot mate, on the very odd acasion the AWD will not come on, or will come on a while after start up, it will buzz and flash likes its priming up then just stay on. its got me stupmed.
p.s i recoreded these codes about 10 times jsut to be sure i was reading them correct, its pain staking.
Your lucky i work for Nissan and had time to look today :thumbsup: . This is the error codes for ALL r33's with 4WD so its legit and i found it in some old book which has more info than the net.
43 = ABS actuator motor , motor relay and circuit
77 = ET-S/ABS control unit ground and circuit
It obiously points to a break somewhere in your circuit so i would check all fuses/relays then conectors then earths and lastly wires or maybe the interal wiring is worn in a moduel/motor just check everying.
i had a problem with my car idling at 1500rpm and my 4WD light came on and my ATTESA ECU flashed 75 for TPS, when ever i used anything electrical and that includes my brake light or headlight or wipers etc etc and i was stumped for 2 years and spent ($6000 COST PRICE!! probably $12000 retail) on work just think i might fix it one day changing things and found the other day it was a earth cable from the starter motor to body just under the black fuse box in the engine bay, it needed a bit of sand paper and tightening. Most likley wiring..........
Edited by central coast person
haha mate thanks for taking time to find that out, aswome info, i thoguht it was my Main ABS so i had that changed ages ago, lucky i got a cheap one, ive taken it to a auto elec, i think i need a specilist nissan auto electrition. any ideas?
Where are you located?
    • Well, in 2007 he must have been charging about $1800 an hour. He only looked at the car for 5 minutes. And another 4 to write the report wrong, and another minute to correct it. Mind you, this was for a car that was: Stock engine, fmic (hole in drivers guard), all alloy intake and custom air box, 3 inch turbo back exhaust, lowered, and a set of 17" Advans (255/40/17 rear and 235/45/17 front). It was nothing crazy. The blue slipper wanted the "hole in the guard" engineered. But that was because he got the shits that I wouldn't "relocate the battery from the boot, back to the factory position in the engine bay"... In an R33 GTST...     Also for emissions, E85, and don't go wild on timing. It's amazing how the closer you get ignition timing towards max torque, the last couple of degrees really throw NOx counts right up. And for the huge increase in emissions, it's only a small increase in torque.
    • He'll be looking down and swearing about "the damn apprentice" for trying to convince Duncan to use percussive maintenance... 😛
    • I swear at my GKTech ones every time I have to take them apart and replace a spherical. But I wouldn't swap them for anything else. They absolutely slay every other option, at least in terms of how they actually work. You sure you don't want to live with bearings? I mean, they don't have "ball bearings". They are rod ends and sphericals throughout. Tough as nuts, even though I have found more than one way to wear them out.
    • From when I was looking at getting the 86 engineered for the turbo, the joint said to put in a few euro 5 or 6 cats, then tune the car on a nice clean E85 tune When I was looking at a turbo for the MX5, it was basically the same thing, a couple of cats and a nice clean tune Although, it will depend on the year of the Jeep IRT emmisions standards required, and what mods are done, especially if it has a newer engine installed that requires a higher Euro
    • Yeah - but it's not actually that easy. There are limits for HC, CO, NOx and particulates. Particulates shouldn't be a concern in any petrol engine unless trying to comply to the very latest Euro standard. But getting a tune right so that all the others stay within limits AT THE SAME TIME is not a trivial exercise. You couldn't possibly get it right by just guessing at the tuner's dyno, unless he had a 4 gas analyser up the pipe, which is not often the case these days. It used to be. Every decent shop that did "tune ups" (as opposed to tuning) would have a 4 gas analsyer. Perhaps there's still quite a few of them around these days. But most "tuners" are only watching O2 and power readings.
