Hi guys wondering if this is a just an r33 series 2 afm, inside appears to be different and there is no mesh can someone comfirm, if so why is "power intake" selected on my power fc instead of "r33 normal", car has heaps of power till 5,000rpm then kind of tapers, fuel is bad 300k's per tank...it does have a k&N pod filter and aftermarket intake pipe to turbo.
post-31991-1227875544_thumb.jpg post-31991-1227875579_thumb.jpg post-31991-1227875606_thumb.jpg post-31991-1227875652_thumb.jpg post-31991-1227875680_thumb.jpg post-31991-1227875757_thumb.jpg
https://www.sau.com.au/forums/topic/246829-r33-afm-or-power-intake-setup/
The guy before you may have had a z32 afm and so he has selected a different option on the power fc. If for some reason it was removed before the car was sold to you and the option wasnt changed back to r33 standard then that would explain why its running bad and getting bad fuel economy. Try setting the option back to r33 and see how it goes.
yes, was supposed to have "230rwkw", confusing me as has the following mods, trust fmic, 3" mandrel bend exhaust, 3" split ces dump front, k&n pod filter and intake, blitz ebc, apexi power fc, stock series 2 turbo (max 200rwkw?)
is making 11.3psi on 80% injector duty, not sure if standard injectors, they are purple so assuming they are standard.
had a worked r32 gtr with 300rwkw and that was almost twice as fuel efficent, this rb25 got around 270k's to the tank to be exactly and thats with fuel at 99cents a litre
Edited by FOOLBOOST
