Hey guys i just got a new head unit installed into my car and since then my battery keeps going flat.... also when i turn on my lights my head unit sometimes restarts and the car loses alot of power.
what could be causing this i was told that it could be the alternater or that the head unit is not earthed properly.
the car is at about 14.25volts and can drop quit a bit
r34 GT-t
also wondering if any one knows if they came with stock splits and if so where they could be.
https://www.sau.com.au/forums/topic/246832-voltmeter-going-crazy/
r34 GT-t
dose the head unit turn offf with the ignition or do you have to turn the unit on manually.
if you can pull the deck out and change the earth to some metal in the dash. some people will wire the earth up to an existing wire that looks like a black earth wire but turns out to be a control wire for your headlights.
to check your alternater start the car and turn everything on lights(high beam) stereo, then check your
volts from the alternator it should still be up around the 14v. check your battery as well that should stay firmly around 14v if the battery loses power the alterantors not doing its job and will probly need new bushes(about 12 bucks) or new module.
when you say the car loses alot of power, do mean engine power or volts. cuase if its engine power
it most probably because of the lack volts not being enough to supply a desent spark. so if its running of the battery it aint going to last long.
