Looking at purchasing a motor for a build and would like to know if there is any differences between
R33 RB25 Series 1 & 2 Turbo and non turbo motors
I plan on going to town on the motor so turbo manifold isnt a must have as il be changing it anyway, im more concerned the outputs and boltups are still the same, and wondering if NA blocks & heads are still gunna work and if there are any advantages of any of those motors above.. I dont want a neo, just hte above stated.
cheers for ya helps
I believe there is some variation in the gallery where the water pump bolts up so depending on which hi po pump you want to use it may or may not be a problem .
Someone recently had an issue fitting a new pump to a S1.5 GTS25T block , I don't know when the pattern changed but someone here probably knows .
I'd be checking to see if the R33 RB25 DE block had oil squirters because they are fiddly to fit if they don't .
The heads not sure but if turbo/NA are anything like FJ20's the NA type may have smaller exhaust manifold studs I suppose because they're not suporting a turbo .
Someone who's used to building up RB's should know the where's and why fors .
Cheers A .
    • If you are keeping the current calipers you need to keep the current disc as the spacing of the caliper determines the disc diameter. Have you trial fitted the GTS brakes fit on a GTSt hub or is this forward planning? There could be differences in caliper mount spacing, backing plate and even hub shape that could cause an issue.
    • Hi there I have a r33 gts with 4 stud small brakes, I'm going to convert to 5 stud but keep the small brakes, what size rotor would I need?
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
