Hi All
after some advice
I just got a defect for having an oil leak at the back of the tappet cover on the right hand side of the engine (looking from the front)
Know this is a common skyline thing but i dont believe it to be classed as a leak
i want to contest it as i only have one point left and this defect will lose me that one point
Someone told me if i take it to a mechanic and get them to OK it that its not leaking then i can take it to qld transport and probably get out of it
What is peoples advice, i really cant lose my license right now
Cheers
Callan
https://www.sau.com.au/forums/topic/246839-defect-oil-leak/
is it dripping on the ground? techically an oil leak is a roadworthy item. depending on the severity a car can be defected for this. it is up to the person writing the rwc or in your case, the officer, as to whether it passes or not. what do u have to do to clear the defect? get a roadworthy? present it for inspection to the officer? or is it self-clearing where u have to fill in a declaration stating that the item has been fixed? i don't think u can actually get out of it u just have to get it cleared and wear the loss of points and fine.. sorry
https://www.sau.com.au/forums/topic/246839-defect-oil-leak/#findComment-4290583
its not dripping out, im not sure its even a leak. Its been there since i bought the car off a dealer. The oil is old and dirty.
Hopefully i can get someone to see that and have the charge dismissed. Ill see what happens anyway.
Anyone else had something simliar?
still open to advice/similar cases
https://www.sau.com.au/forums/topic/246839-defect-oil-leak/#findComment-4290607
i challenge anyone to find a car more than 5 or so years old that doesn't have a little oil weeping past the seals on the tappet covers. ridiculous. it's not like you'd be leaving a massive oil-slick everywhere you went :)
just get the engine bay steam cleaned, take it to the inspection site, and tell 'em to shove it
https://www.sau.com.au/forums/topic/246839-defect-oil-leak/#findComment-4290613
what i want to do is go to qld transport say 'ill clean it then u can come outside and watch me rev the car and see if any oil comes out' i think if oil is not leaking under normal operating conditions then it shouldnt matter. Its not really a leak, i think it may even be just spilt oil from a serice, will get a photo up for better judgement
but yeah rather petty really
https://www.sau.com.au/forums/topic/246839-defect-oil-leak/#findComment-4290619
instead of just cleaning it down and whinging tighten the phillips head bolts too and u won't have that problem for a while. also its not spilt oil from the service its your rocker cover gaskets leaking because the screws are loose...
https://www.sau.com.au/forums/topic/246839-defect-oil-leak/#findComment-4290837
took it to someone who does roadworthies today. He said he wouldnt fail it, and that the law surrounding it is open to discussion really. So I'll see how I go
if anyone has successfully contested this i wouldnt mind hearing from you.
Ill leave it how it is for now anyway, take it to another roadworthy guy monday and see what they say. After everything is cleared or not then ill probably replace the seal
Cheers
Callan
https://www.sau.com.au/forums/topic/246839-defect-oil-leak/#findComment-4291296
Ok i went to DOT on monday morning and spoke to one of the people at compliance and she went and got some info for me. She told me to get together some evidence and send it away to Queensland transports office in Brisbane and the guy there has the power to overturn it without having to take everything through court
so I've just written a letter up, have 2 statements from roadworthy approved examiners and will get some hi res photos to send along as well. At the end of the day thats all i can do and if thats not enough then at least i tried.
One thing i had someone say could be bad another say could be good is that the officer only wrote 'oil leaks' on the notice and didnt specify where. One of the people I saw said that could be used against me as I could just state a completly diferent place to what was shown and say theres no oil at all there
The other said that the officer failed to be specific and this could be argued against him
anyways
I will let you know what happens
Cheers for all the help guys
Callan
https://www.sau.com.au/forums/topic/246839-defect-oil-leak/#findComment-4297994
  • 5 months later...
Ahh digging this up, it was ages ago.
What ended up happening. I got 2 letters from roadworthy inspectors, wrote a 2 page letter and printed out some photos and sent it to qld transport brisbane. Waited a month or so and then got word i should hae sent it into Mackay Traffic Dept (or whatever they are)
anyways they forwarded it to them, get an email sayng they have recieved it etc.... at this point im thinking no way am i getting let off for this...
about a week or so after that get an email with a letter attatched to it saying they have reviewed the details and taken into consideration the comments from the roadworthy inspectors and decided to withdraw the fine
Happy as
So bottom line is.... you can win lol
Thanks for everyones advice and comments. Ive cleaned the oil up afte i took photos (back in january) and its still clean today. But ive got polished rocker covers in the works so will replace the gaskets and screws when im finished with them
Thats my story anyway. Sorry it took so long to finish it off :(
https://www.sau.com.au/forums/topic/246839-defect-oil-leak/#findComment-4599334
    • No worries at all 🫡 I think the most satisfying things to make are the little bits that are just impossible to find or they're no longer manufactured. Generally I always try to replace parts with OEM wherever possible. This little project is also great because it'll never see the light of day, but strengthen these brackets so it's not just relying on the little standard screws in the headlight plastic. As soon as I saw the standard brackets and screws I thought, "well I'm not going to install with just the screws, the plastic tabs will just snap off". It's crazy how expensive everything has become yeah. But I suppose that's supply and demand; granted it's a lot easier to get brand new genuine parts these days which is fantastic 😊, I don't have to get totally reamed at the local Nissan dealer ha ha We sure are lucky we have all these manufacturers making parts these days, a few really great Australian companies too like Platinum Racing Products and Fit Mint Automotive, what a time to be alive ❤️ . I've got my eye on the RB26 head by PRP as mine has a very fine hairline crack, so that'll need to be addressed some time in the future. If you have any requests or odd things to make feel free to let me know and I can have a crack at making replacement parts ✌️
    • Thanks for sharing this, and BTW if your headlights are in good condition they are worth thousands....you might want to consider replacing them with brand new LED ones like this (https://www.nengun.com/78works/full-led-headlights-r32-skyline) and making enough profit to buy a house in Sydney
    • I'm not sure what sort of shops are nearby, but I'd expect any reasonable exhaust shop could put a cat in it that will not restrict the power that engine makes. Otherwise, if you want to remove it, short lengths that replace the cat are readily available online, search for "de-cat pipes" or "test pipes"
    • Howdy friends, So another weird one today, I was looking into replacing some broken clips holding the front grille for the R32 GTR (part number 01553-03831), and noticed the brackets which are supposed to hold the grille in place were also missing 😑. I do recall seeing this issue many years ago, but didn't fix it at the time. A quick look on eBay and I was able to find the genuine brackets, along with all the screws which suited the headlights (part numbers 26042-08U05,26092-08U05). Happy days!....  Once they arrived however there was an extra nut in the packaging which implied that there should also be a bolt or a stud, and sure enough, after a bit of searching I found this thread from 2013, and @Ants clearly shows a stud should be present. Reading around a bit more, it's possible the headlights on my car are the "povo pack" headlights as mentioned by @funkymonkey in this thread way back in 2008. This could explain why the studs are missing on my set of headlights. Looking at the headlight diagram I wasn't able to see a suitable part number for the stud itself. The headlight did indeed have a recess that looked like it would accept a stud, but interestingly no thread or anything obvious how the stud would be affixed to the headlight, I suspect it may have been glued in, press fit, or melted into the plastic at the factory. Another member may be able to clarify if they happen to have a genuine set of N1 headlamps. The only thing we have to work with within the recess is a keyway which likely is there to prevent the stud from rotating within the recess. In any case, back to 3D printing, I put together a model which acts like a pug with a friction fit inside this recess, making use of the keyway so it doesn't rotate while tightening a bolt. Printing in TPU will allow it to slightly swell making a nice snug fit without cracking the part. I've designed the adaptor it to accept an 20 mm M6 bolt (stainless with a cap head in my case), as opposed to the standard M5 stud and I made use of the standard galvanised split washer that came with the genuine brackets from Nissan. Once the bolt and screws were all in place, giving the bracket a gentle shake gave the classic "shaking the car" feeling, very solid, which gives me confidence this is going to be able to hold on much better than the janky solution which seems to have been here for the past decade or so. Overall I'm really pleased with how this turned out and maybe there are more people out there running these headlights without a centre stud at all! Link to the freely available model on Printables: Click here Regards, Sean
    • Hey everyone, This is my first post apart of the introduction. I tried searching a bit on the forum but couldn't really get a straight answer. I got the car to my mechanic as I felt it being weak. It seems that it was missing on two cylinders due to the injectors. I had all my injectors clean and the car runs much better. The mechanic also confirmed my suspicions that the cat is clogged and needs to be tackled asap. The cat rattles a bit and the hot exhaust warning frequently lights up when driving after getting the injectors clean. In my introduction I was asked about what modification I might be interested in and mentioned a cat delete. From what I was told, this is not really beneficial on the RB20DE and there are more cons than pros.  Could perhaps anyone give some suggestions on what the best course of action would be since the current cat is toast and needs to be removed/replaced anyway? I can also sometimes smell a strong smell of fuel, but I'm not sure if this is related.
