Hi guys.
I'm selling all the bits off my 205rwkw R32 GTS-T as a whole package because i want to make my car stock again. I'm doing this to get out of debt, as i paid for all these mods with credit cards. Yes, I'm an idiot. Fun wile it lasted though!
For the price of $8600 you'll get
-Garret gt3071r good condition
-Dr.Drift standard ECU remap
-standard air box with k&n filter (modified to suit Z32 AF meter)
-Z32 airflow meter
-4" mandrel bend intake pipe
-RB26 standard intercooler and piping to suit
-bosch 040 fuel pump (internally mounted)
-440cc injectors
-38mm external wastegate, plumbed back
-3" dump + front pipe (i kept the standard cat back to keep it a bit quieter- full 3" can be arranged)
-Oil catch can
-braided stainless oil and water lines
-Adjustable cam gears
-splitfire coil packs
-excedy 5 puck clutch (strong yet street friendly)
-greddy EBC profec II
More stuff that i cant think of :)
All of these things cost me well over $9000 for the parts only.
It would take 1 weekend, maybe 2 for me to put all the mods onto your car.
I have dyno sheets to prove.
The mods are still in the current car, and I'd be happy to take you for a spin.
I will set the cam gears to suit your engine on a dyno.
This will include a dyno printout.
RB20's are capable of handling more power, and all the mods could easily support more power, all it would take to get 230rwkw would be more tuning at DR.drift which i would be more than happy to organise.
ANY (and i mean ANY) more modifications that you would like I can do at a decent price.
ONLY CONDITION OF SALE: As i want to make my car stock again, and i don't have any stock parts i would require to keep all the standard items that i remove from your car.
CONTACT DETAILS: my name is James. I'm located on the Mornington peninsula. My phone number is 0423 043
Call, sms or pm me anytime.
Thanks.
https://www.sau.com.au/forums/topic/246847-205-rwkw-r32-gtst-package/
should be able to make way more power than that out of those mods man...
i made 205rw kw on my rb20det with just fmic, full exhaust, gtr fuel pump and 480hp turbo, stock ecu, stock injectors..
well yeah, it has the potential to support alot more power, but A- ive got stock internals so i wouldnt push it past the 230rwkw mark, and B- when i got it tuned, Sam (aka dr.drift) didnt want to turn up the boost any more until i put new head bolts in. apparently he's seen heads lift off the gasket from high boost on old head bolts
and no, at this stage I'm not willing to seperate.
cheers. James.
So $8600 gets you those mods but an extra $1400 gets you the car and engine aswell? - http://www.skylinesaustralia.com/forums/vi...ts-t206318.html
Edited by Bennett
bahah, someone buy the parts and i'll take whatevers left of the car for $1400 then :banana:
rice me up- like its not a bad setup but man to tell you the truth your kind of dreaming for that kind of figure your asking mate, that price can probably get you 260+rwkw, i think around 5k installed is pretty good as its all second hand stuff aswell
cheers tony
cheers. James.
this dr drift always seems to have an excuse when his tunes don't make power... which is pretty often i've noticed
cheers. James.
how much boost are you using to get 205rkw? and how much do you think the rb20 can take before the heads start lifting?
you must be talking +25psi???
nah, it only needs 16 pounds to get 205. no idea what it would take to lift the head.
Christ I'm getting burned...
In my defense: admittedly it's not a massive power figure, but if you were to put all that equipment on an engine with forgies etc, you'd be able to get heaps more power. id say over the 300rwkw mark maybe? couldnt work it out exactly.
  • 1 month later...
To clarify it the head had been off the car, and was put back on re-using original stretched head bolts. On every single occasion I've seen head bolts re-used they have stretched more and blown head gaskets.
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
