205 Rwkw R32 Gtst Package
Hi guys.
I'm selling all the bits off my 205rwkw R32 GTS-T as a whole package because i want to make my car stock again. I'm doing this to get out of debt, as i paid for all these mods with credit cards. Yes, I'm an idiot. Fun wile it lasted though!
For the price of $8600 you'll get
-Garret gt3071r good condition
-Dr.Drift standard ECU remap
-standard air box with k&n filter (modified to suit Z32 AF meter)
-Z32 airflow meter
-4" mandrel bend intake pipe
-RB26 standard intercooler and piping to suit
-bosch 040 fuel pump (internally mounted)
-440cc injectors
-38mm external wastegate, plumbed back
-3" dump + front pipe (i kept the standard cat back to keep it a bit quieter- full 3" can be arranged)
-Oil catch can
-braided stainless oil and water lines
-Adjustable cam gears
-splitfire coil packs
-excedy 5 puck clutch (strong yet street friendly)
-greddy EBC profec II
More stuff that i cant think of :)
All of these things cost me well over $9000 for the parts only.
It would take 1 weekend, maybe 2 for me to put all the mods onto your car.
I have dyno sheets to prove.
The mods are still in the current car, and I'd be happy to take you for a spin.
I will set the cam gears to suit your engine on a dyno.
This will include a dyno printout.
RB20's are capable of handling more power, and all the mods could easily support more power, all it would take to get 230rwkw would be more tuning at DR.drift which i would be more than happy to organise.
ANY (and i mean ANY) more modifications that you would like I can do at a decent price.
ONLY CONDITION OF SALE: As i want to make my car stock again, and i don't have any stock parts i would require to keep all the standard items that i remove from your car.
CONTACT DETAILS: my name is James. I'm located on the Mornington peninsula. My phone number is 0423 043
Call, sms or pm me anytime.
Thanks.
well yeah, it has the potential to support alot more power, but A- ive got stock internals so i wouldnt push it past the 230rwkw mark, and B- when i got it tuned, Sam (aka dr.drift) didnt want to turn up the boost any more until i put new head bolts in. apparently he's seen heads lift off the gasket from high boost on old head bolts
and no, at this stage I'm not willing to seperate.
cheers. James.
rice me up- like its not a bad setup but man to tell you the truth your kind of dreaming for that kind of figure your asking mate, that price can probably get you 260+rwkw, i think around 5k installed is pretty good as its all second hand stuff aswell
cheers tony
cheers. James.
this dr drift always seems to have an excuse when his tunes don't make power... which is pretty often i've noticed
cheers. James.
how much boost are you using to get 205rkw? and how much do you think the rb20 can take before the heads start lifting?
you must be talking +25psi???
nah, it only needs 16 pounds to get 205. no idea what it would take to lift the head.
Christ I'm getting burned...
In my defense: admittedly it's not a massive power figure, but if you were to put all that equipment on an engine with forgies etc, you'd be able to get heaps more power. id say over the 300rwkw mark maybe? couldnt work it out exactly.
  • 1 month later...
 Share
    • Hi fellow SAU members, I want to put coupe tail lights on my R32 sedan. I have been told it was as easy as changing the boot lid and the tail lights and possibly the rear bar. I have since found out that this is incorrect after buying the lights and boot. The coupe boot dosnt allow the boot to oprn on a sedan and the tail lights won't fit either. Has anyone done this or seen it done and could help me out with some guidance or instructions to get it done.
    • Noice one 👍 I've done a 1:16.300 at Watkins Glen, will keep at it. Still have to knock off half a second at Suzuka in the Roadster
    • Two golds! Struggled to get silver on Gran Valley.
    • Interesting that it has 2 to the USB stick. Are the ones to the USB stick different? Or labelled anything at all? Telstra 4G is Band 28 is the long range one you want, it's 700mHz. I'm trying to do some reading on the Cel-Fi stuff, but I can't find any decent info online that makes me feel comfortable being able to work out the sort of antennas we could get away to swapping it over to. The antennas I'm starting to do some stuff with at work, are a transparent antenna. They're designed to stick onto the window. Which means you wouldn't even have the antenna outside the car. Volkswagen have just started using the exact same types of antennas on some of their new cars (And from the same antenna manufacturer). But, RF stuff is a bit of a dark art some days, and getting it wrong in your car could make for a terrible waste of money trying to swap antennas :S
    • I'm not going to lie Duncan, Saturday and Sunday were pretty rough days. The sort of work I was doing would previously have ended up with me spending about an hour and a half chatting with Neil. Firstly about something I had a question about, and then both of us rambling off on tangents.  I think how Neil did things, and his attitude to getting it done is helping me in part to get this stuff done. Then I can actually do the things I enjoy more easily
