Hi,
Anybody out there had mods engineer certified? or know where it can be done in QLD or NSW? EDIT: or in Vic:)
I was making some enquiries into getting mods engineers certified to comply with ADRs.
It would appear that an engineers report from any 'Chartered Professional Engineer' will be accepted, subject to inspection of course.
If anyone can help it would be greatly appreciated, I have done a couple of searches on the web, but information seems scant.
Thanks for your time
Steve
Just had a look at the vic roads site, a bit more helpful. Whilst it has signatories for vehicle mods, it is no longer an 'engineers certificate per say.
the crazy thing is it even lists several signatories for NSW, a whole 2 for SA and lots for vic. Might be worht a look if anyone is thinking of doing this:
http://www.vicroads.vic.gov.au/vrne/vrnint...nDocument&Area=
Sorry, VSI15 is the correct document - disregard my first post people.
This information sheet contains a list of people with experience in automotive design and standards who have indicated that they are available for consultation. They are familiar with vehicle construction requirements in NSW and, for a fee, they will provide advice to owners and vehicle constructors, undertake technical assessments and issue engineering certificates. However, in publishing this list, the Roads and Traffic Authority does not endorse their services nor does it take any responsibility for the quality of their work. Vehicle constructors and owners intending to engage the services of an engineering signatory, should establish the signatory's experience for the proposed scope of work and the fee arrangements before work is commenced. It is also advisable to ascertain whether the signatory carries “Professional Indemnity Insurance”.
An engineering signatory who certifies a motor vehicle as to its construction or modification will:
• personally inspect the vehicle;
• ensure that the scope and any construction or modification complies with the requirements of the Road Transport (Vehicle Registration) Regulation 1998 and the Australian Design Rules;
• Issue an engineering certificate in the form specified under the Engineering Certificate System(ECS) (see sample overleaf).
Note: Only an engineering certificate issued by a signatory who is listed will be acceptable to the Roads and Traffic Authority (RTA) for the purposes of vehicle registration.
Engineering signatories included in the ECS are full members of the engineering organisations recognised by the RTA for this purpose, namely:
• The Institution of Engineers, Australia (IE Aust);
• The Society of Automotive Engineers, Australia (SAE-A) - Automotive Signatory Group.
Other information sheets published by the Authority cover the circumstances under which a vehicle constructor or owner may require the services of an engineering signatory. In brief, owners are required to obtain an engineering certificate from a recognised engineering signatory, when performing any modification to a vehicle, which is safety related and affects the continuing compliance of the vehicle with the Road Transport (Vehicle Registration) Regulation 1998 and the Australian Design Rules.
A list of these signatories is attached to this information sheet.
Steve, I've got some info from Transport SA from a mate who work there.
Here are their approved chartered professional engineers.....you might probably know it aldready :D
1. Tonkin Consulting
2. Australian Technology pty ltd (Regency is a little bit iffy about this guy though...i think u know that toooo)
3. Rory Thompson Services
4. Forensic Engineering and Associates
5. Engineering analysis & software
Now not all of them are catered for our purposes. PM me ur fax no and I see if I can fax this to you if you want a copy.
    • It's kind of interesting - They definitely do builds that split the difference between what they like and what will generate views and engagement. The NC Platform always surprises everyone in a good way, in an uncomfortably good way some may say. They could throw a LS in there and arguably have the best (and best performing) car of the entire stable. But that isn't necessarily what draws views, because people viewing don't want to accept the vegetables of a LS NC MX5 being a superior vehicle in every way (including fun) than a RB26 240Z. This is also why there's not a lot of content about the GR Yaris (on the web in general). They're too good, yet 'only a Yaris' The community doesn't want certain cars to be as good as they are - to beat their hero cars, and I believe the NC MX5 is absolutely one of those cars.
    • Yeah - My key still does the chime thing. I followed the procedure but it didn't activate on the (identical) third set of keyfob that I had. I vaguely remember the alarm saying you can only pair two keys with it. Now that I've dug it up, it appears that you very much can pair keyfobs to the alarm system. (which are the fobs I use to unlock the car). I have successfully diverted the thread and can probably not use the OEM keyfob ever again unless I use the aftermarket alarm and attempt to pair the OEM keyfob to it. Which might just work, or not :D. I definitely used the nissan method and not the aftermarket alarm method.
    • What makes it worse is that Nissan made keys in the same style, for example R34 and Stagea, but they work at different frequencies or something like that. So they look the same but the remotes are not interchangeable. I learned that from some guy selling aftermarket blank keys.
    • Does your door chime work when you have the key in the lock and open the door? I've had that disabled because it's f**king annoying and it is one thing that messes with the pairing. Because now the car doesn't detect key in ignition anymore and the slide-key-in-and-out sequence does not trigger the pairing mode anymore. The service manual has a section on the various bits involved in doing the syncing. I presume it'll be similar between Stagea and R34.
    • Agree, but meh, I think is is based more on LOLS than actually apples to apples, like, who would have thunk a turbo 4 cylinder would not beat a NA 4 cylinder  I think with just basic N/A mods, like a exhaust and tune, it would be equal to the Mini in its current form, maybe I know my current 2.5 would "chop the mini" as the midrange now has a night and day difference in power delivery compared to the tuned 2.0, by around 20kwatw and 30nm from around 2k rpm "ish"....... I'm kinda hoping that they do a N/A build, either with the MZR 2.0 or with whatever they decide to use If I recall correctly they did talk about K swapping one a while ago
