Dr30 Front Brake Questions
Hey,
Ive got a quick couple of questions for the tech guys here regarding DR30 front brakes.
I know that DR30 struts have 100mm caliper spacing, resulting in a nissan 4 spot caliper being used, but the hub assembly isnt like hr31 (similar to s14,s14 etc) where the disk just slides onto the wheel studs, bolt caliper back on and bobs your uncle.
DR30 is datsun style (hub bolts to disk)
How do I go about fitting or modifying the DR30 hub to accept a S series silvia disk?
Please dont say "put s13 front coilkovers and bits in" as its out of the question (dr30 struts are going into a stanza)
Now the next question, anyone fit 14" wheels over dr30 front brakes?
Cheers,
Guys!
It's all to do with the OD of the disc rotor vs space in the back of the wheel.
Your wheels need to clear the caliper, simple as that and 274mm dia DR30 rotors wont allow 14's to go on.
The stock fronts are only 250 so 14 is easy then.
Cheers, D
Stock fronts?
As in just plain mr30 strut/brake combo?
Its more the caliper size that kills the fun, I have a similar sized disk on my 1600 struts, using a bmw 4 spot.
Picked up some n/a r32 front brakes yesterday( yay 14" wheels! ) soon as the disks are back from being machined ill send the hubs off to get them modded.
Also going to do a coilover convo on em using threaded colar, will throw up some tutorial style pics as I progress.
Cheers,
Dan
 Share
    • For anyone interested, the Way Back Machine has that Japanese website archived with pictures, etc: https://web.archive.org/web/20051023225805fw_/http://www.a31cefiro.com/air_con.htm "Simply swapping the wiring of the harness will not allow it to function properly. For the outdoor air sensor and sunlight sensor, disconnect the wiring connected to CN1-11 of the air conditioning harness from the harness and connect the sensor side wiring to earth. For the indoor air sensor, disconnect the wiring connected to CN2-3 of the air conditioning harness from the harness and connect the sensor side wiring to earth. The connector PIN numbers listed here are the genuine A31 PIN numbers. To avoid incorrect wiring, check with a tester before wiring. Also, disconnect the wiring in a location close to the sensor. The disconnected harness side wiring will not be used, so be sure to insulate it." Wish someone sold a conversion harness to just plug-and-play a Kouki 180sx digital climate control into C33/A31. I'm decent with wiring but feeling kinda lazy about taking this on.
    • Maybe SAUNSW could see howany members would do a motorkhana day if Schofield's is still available for a reasonable price...
    • Skip the concrete, we just need to smooth a field. Mark knows how to drive a grader Duncan   I reckon 100x100 flat area for skid pan style, and then some sort tracks for rally... Duncan's already got a rally car on the premises to...
    • Well, yeah, the RB26 is definitely that far off the mark. From a pure technology point of view it is closer to the engines of the 60s than it is to the engines of the last 10 years. There is absolutely nothing special about an RB26 that wasn't present in engines going all the way back to the 60s, except probably the four valve head. The bottom end is just bog standard Japanese stuff. The head is nothing special. Celicas in the 70s were the same thing, in 4cyl 2 valve form. The ITBs are nothing special when you consider that the same Celicas had twin Solexes on them, and so had throttle plates in the exact same place. There's no variable valve timing, no variable inlet manifold, which even other RBs had either before the 26 came out or shortly afterward. The ECU is pretty rude and crude. The only things it has going for it are that the physical structure was pretty bloody tough for a mass produced engine, the twin-turbos and ITBs made for a bit of uniqueness against the competition (and even Toyota were ahead on the twin turbs thing, weren't they?) and the electronic controls and measuring devices (ie, AFMs, CAS, etc) were good enough to make it run well. Oh, and it sounds better than almost anything else, ever. The VR38 is absolutely halfway between the RB generation and the current generation, so it definitely has a massive increase in the sophistication of the electronics, allowing for a lot more dynamic optimisation of mapping. Then there's things like metal treatments and other coatings on things, adoption of variable cam stuff, and a bunch of other little improvements that mean it has to be a better thing than the RB26. But I otherwise agree with you that it is approximately the same thing as a 26. But, skip forward another 10 years from that engine and then the things that I mentioned in previous post come out to play. High compression, massively sophisticated computers, direct injection, clever measuring sensors, etc etc. They are the real difference between trying to make big power with a 26 and trying to make big power with a S/B50/54 (or whatever the preferred BMW engine of the week is).
