Hi everyone
wondering if somone can explain to me how to get the bolts out that hold the ignitian barrel to the steering column.
i have included some pictures from both sides of the bolts and circled them in red
just to show that there is nowhere for a spanner or screwdriver to go
thanks in advance ppl
https://www.sau.com.au/forums/topic/246860-ignitian-barrel-braket-removal/
These are designed so that when you tighten the bolts up the bolt heads break off - this means that they can never be removed.
The first question is why do you want to remove the ignition lock?
If the lock has failed or been damaged in an attempted theft then you will have to then find a way to break the housing apart and replace it with a new one (this is what happed to one of our cars after an attempted theft). The challenge is to remove the lock mechanism without damaging the steering column.
Its pretty easy really. Just get a sharp punch and a hammer, hit the punch into the screw far enough to get a large enough "wall" then hit it across. This pushed the screw around and undoes it. Same if your trying to undo any other stripped bolt.
When we did this, we grabbed the grinder and ground a groove through them so we could put them back in with a screw driver easily.
Good luck!
They can eiher be drilled out, or ise a thin drill, place 2 small holes at the ends opposite each other, and use a fork-type screw piece to extract.
Either way, once they are in, the heads snap off and they are next to impossible to remove, and once removed, they can not be re-used.
B.
EDIT: Could also try using a dremel to cut a | into the top, then use a flat bladded screw driver to get it out.
Again, once it's out, it's finished.
Edited by turbo_brian
thanks guys i think i can get these out with one of the above ideas
the reason i am taking it out is this is a parts car and somone has asked for the part
they dont want the barrel itself just this metal bracket
i will give these ideas a go cheers
Yeah awesome, lets just post out on a public forum on how to remove a skylines steering lock....
Just about every manufacturer does it this way.
Thieves already know this anyway. It's time consuming to get it off - if a thief wants to remove it, he simply smashes the ignition barrel off (as he did when he tried to steal my 32), which releases the column lock pin.
Hmmm, lets look at this in real terms here:
Thief gets into car, goes "hmm, dont want to damage anything" so he pulls out his tool kit, gently removes the steering wheel covers, uses a dremel to score a screwdriver mark in the bolts, and then gentle remove the bolts to get the ignition barrel out, and release the locking pin.
OR
Theif gets into car, uses barrel breaker to pop the lock out, which disables the locking pin anyway, then uses any flat object (key, screwdriver, etc) to turn the ignition over, start the car and vanish.
Seriously here, which is the theif going to do???
The only time a thief would even contemplate gently removing the barrel is if they wanted the lcoking mechanism in prestine condition for a re-sale (if they where cars on a hit-list), and they would simply barrel-break the thing anyway, and repair the lock at a hidden location before presenting the car for sale (in a new country for instance).
Do you think a theif will sit there for 30 minutes in a car to be gentle while stealing it, or would they smash the barrel out in 5 - 10 seconds with a barrel breaker and turn the ignition over and drive off??
Common sense son.
OR
Common sense son.
'Tis true the points you bring out as they are valid, but to be honest as a locksmith by trade, I don't believe any sort knowledge to defeat a cars security should be blatantly spread, regardless if it's time consuming or quick or just "common sense". There's enough cars being stolen as there is, we don't need more.
All valid points...
Edited by KeyMaker
thanks to those who helped out i have now got it out with a slight variation of the afore mentioned methods
and to keep everyone happy i will not disclose the exact details of my top secret method :rolleyes:
even though as mentioned it did take me about an hour
maybe im just slow hehehe.
thanks everyone i apreciate your help
Edited by r33rckt
    • Yeah, it was a bit of confusion with me, I rang and asked if they had a boot for a soft top, and then the paint shop when they rang and were asked if it had a hard top on it, which it does, just not a PRHT....LOL Meh, whilst frustrating for all concerned it isn't a war stopper and should be a thing of the past in a week or two In other N/A related news, car is booked in at the end of the month for the cams, springs, retainers, harmonic balancer and retune  I might even pull the lazy arse card and get them to do a full service on it whilst it is there
    • Factory LSD is supposedly a 2 way with a very conservative cam. If you've already tried adding friction modifier to the diff oil and it still locks up too much for your liking you might want to adjust the ramp rate on the cam to be more like OEM instead of reducing initial torque even further. People claim the 8 kgf-m disc kit for the OEM LSD is still very streetable but I've never been able to compare everything side by side on my own.
    • Oh man, at least it sounds they've accepted they stuffed up and not put it back on you...could see some confusion if they asked if it had a hardtop or not, and you've answered truthfully but maybe not answering their real question which is what roof did it have from the factory! Glad your keeping it N/A 2.5
    • Nah, I much prefer colour matched Talking about colour matching stuff, the new/used boot lid turned up, all painted up perfectly......aaaannnndddd, it's for a power retractable hard top, not a soft top.....LOL They are now sending a boot to fit a soft top.....,  whilst frustrating, life is like that sometimes, sometimes you just need to dodge, duck, dip, dive and, ummm, dodge.
    • You would need to paint your hardtop again though
