Mate its hard to know what your on about need more info on what you want.
Or are you asking about the camber arm mod that other people talk about
where they want to change the top front camber arm to a later model arm
from a R33 set up? If so the top plate in the strut tower just unbolts and then
you can weld it up to suit your new arm set up.Or better again buy the noltec
arms that sydneykid is selling they seem to be the best on the market 20min
job then a wheel alignment
basically my tyre is getting too much wear on the inside. i went to an alignment stand and was told that i would have to jack the strut mount which i am trying to avoide. if i get the aftermarket camber plates were i could adjust the negative and positive camber it would be good but i am also trying to avoide cutting the strut mount so my question is what are my options
Mate just get the Noltec adj camber arms from the sydneykid group buy that should fix
your problem they have some good adj range.Im still confussed as to what you mean
as to jack the strut mount plate if you just get adj top camber arms you should be fine
they just bolt straight in that easy then a another wheel alignment.No cutting needed!
basically where i am if you go to the wheel alignment stand and your camber is way out they will advice you to jack the strut mount so that whe you replace the strut it will be perfect. i would not cut or jack my car thats why i asked the different options.
Oh dear.
There are a few things wrong with that. The first problem is that an R32/33/34 Skylines do not have a McPherson strut suspension. So you can jack the strut mount (by which I assume you mean the shock tower) all you like & it won't make a difference. See the attachment for the layout.
The most common technique is to change the effective length of the upper transverse link either by using offset bushes (eg Whiteline) or replacing the link with a shorter & sometimes adjustable unit (eg Cusco, Noltec etc).
Now all of you, play nice. >_<
front.PDF
Edited by djr81
well thanx for the info. i have seen a car jacked to get 0 degree camber they have machines to do this. when a car gets hit they jack the body and under the wheel well to get the degree in which they want anyways i wont argue this.
which is the better way to go using the noltec? so there are no other ways to do this caz i would have to order these parts and i have already changed my tyres thanx a lot
    • Oh yeah forgot to also mention need to also unplug the IACV as well. Thanks for the reminder @MBS206 Unplugging the TPS takes it out of closed loop so you're able to screw down the IACV without the ECU trying to add/subtract timing to maintain the idle (not sure PowerFC can even do this, but Nistune and the OEM definitely does)
    • For sale is my 1999 Nissan Skyline R34 GT-T, tuned to 234 kW / 313 hp. I've had the car for a few years as my daily driver. The car is original (as far as Skylines go), with only a few minor upgrades to enhance performance and driving experience, as typical for such a car of its age. Overall, it is in great condition with no body rust, thanks to its earlier import date. It features a top-notch security system (not literally, but it's great!) with remote start and still functional 4-wheel steering via HICAS. It comes with several performance and handling upgrades, including:     Hypergear 450HP Turbocharger running 17 PSI boost, installed mid-2021 by Jaustech     550cc injectors     Nistune ECU     Front-Mount Return-Flow Intercooler     X-Force Stainless Steel Exhaust     Upgraded engine mounts     Bottom end bearings replaced     BC Coilovers     Lenso DR1 rims     Bridgestone Potenza Adrenalin RE003 TL 245/40R18 97W tires, fitted early 2023 The interior is mostly stock, with a few additions:     Viper Satellite Tracking System with remote start     Bluetooth Double-Din Touchscreen Head Unit     Steering wheel cover Cons:     A few paint imperfections here and there     Driver’s seat shows more wear than the others. It's not torn at all, but I've added a seat cover to protect its condition. I also have a CarVX Vehicle History report available for serious buyers, so you don’t need to purchase it yourself. Price: $26,000 ONO.
    • I've had two suzukis in the past have an extremely hard time turning over and not starting after sitting for a few weeks. Ended up the alternator would seize up causing the starter to force. Same issue both times.  Maybe they're sourcing their alternators from the same place...
    • Ah right. Maybe my rb just loves chewing through batteries lol.
    • On the R34 can't you just unplug the IACV? This is the way I've always done it on the R33. Disconnect IACV, get it idling around 650rpm, and then do a power reset on the ECU to get it to relearn idle (factory ECU).   The big reason no one has touched on as to why you'd want to get the base idle right, is that it means the computer needs to make smaller adjustments to get a good idle at 700-750rpm.   Also, cleaning the IACV won't normally make the car suddenly idle lower or higher. The main issue with the IACV gumming up is that the valve sticks. This means the inputs the ECU gives, aren't translating to changes in air flow. This can cause idle choppy ness as the ECU is now needing to give a lot of input to get movement, but then it moves too far, and then has to do the same in reverse, and it can mean the ECU can't catch stalls quickly either.
