Hi Ben,
I have a HKS Workshop Manual which contains a section called "ECU PIN OUT" where there's a section on the HKS S.L.D.
It's all Greek to me, but the Wire Code Box looks exactly like what's below...
S.L.D. WIRE COLOUR > S.L.D. WIRE FUNCTION
Yellow > Speed Sensor Wire to ECU
White > Speed Sensor Wire To Loom
Black > Earth (Ground)
Red > 12V Ignition Feed
PM me for any further info.
Tez
Hi Ben,
Tez
Thanks Terry,
Much appreciated mate.........
Thanks Terry,
I have just installed a Greddy Speed Limiter Cut Controller on my Stagea which seems to have the R34 pinout and it went:
power supply: pin 31 or 67
earth: pin 25 or 32
speed sensor pin 29 (cut this wire)
there's a pinout diagram here if you haven't got one:
http://www.skylinesaustralia.com/forums/Pi...cu-t112683.html
I don't know what the HKS one looks like but the tricky part with the GReddy one was getting the little toggle switches set right for the car.
Duncan, how much is the HKS speed cut drfrnder roughly??
Mine hit 180 on the dyno last time so If I don more mods, may need to put one in
Hey Bakes, paid $100 for it second hand from a friend. i think they are around the $200-250 mark new.
What was your last dyno reading and mods/boost??
earth: pin 25 or 32
Thanks Rob, much appreciated.. just printed out the diagram, am i going to need to solder these wires or just intertwine them??
Edited by Duncan1
* HKS Front Pipe* HKS Cat Back Hi Power Muffler* HKS Pods* HKS EVC* Nismo Fuel Pump* Nismo Fuel Regulator
242AWKW @ 1.2 Bar
Have fitted HKS SPL pipe kit since, so might have 1Kw more now :)
i'd be soldering wires to ensure they won't be comming loose.. and to ensure they make full contact
Yeah fair point! i was hoping you werent going to say that!! lol. Will get it done tomorrow. thanks
earth: pin 25 or 32
It seems that ecu pinout is for the 34's but not the GTR...
If anyone could help me with the r34 gtr ecu pinout it would be much appreciated, as thursday is the track day, i only have tomorrow to fiddle!!!!!!!
Sorry - I didn't realise the GTR was different. have you tried a PM to Terry GT34 who replied to your first post - it seems he has possibly got the answer in his HKS manual?
No worries thanks anyway.
Tez has the 34 manual, which i do, but for some resason does not have to gtr ecu pinout...
have found 2 since!!! both different!!!! lol.
    • Personal experience. Those f**kers burn. And are actually a PITA to put out. Next time I walk down the back, I'll snap a photo of what the inside of the bonnet looks like when that thing ignites. PS, powder fire extinguishers are useless on that stuff too as it's fibrous and when it ignites, it starts to pull apart. And you end up just blowing powder through a sieve effectively.   Like the big thing is, if it's fire resistant, it's job is to stop what burning? The METAL above it? It's just to try keep heat off the bonnet paint work.
    • Oh man, sorry, $60.00000000... 😛
    • That's more or less what he meant. What it really means is that you do not have to go full crazy on the build. Don't need the best oil pump, expensive rods & pistons, big cams, etc. You can upgrade whatever you want instead of using stock level items, but you don't have to. Having said that - any time an RB is opened up, if anything is getting replaced, I think the opportunity should be taken to do all the sensible upgrades. Pistons, rods, pump, etc.
    • February update 🙂 We managed to get the very last 1/18th "Extra Scale" cars stock available from bookstores in Kyoto. These are actually the last ones and will not be restocked again! Hachette Collections Japan have not decided on a release date for these or other models in the series, so for the time being these are all there are available new.  These are showing up on Yahoo auctions at inflated prices already (especially the Celica and NSX) so get yours now at a very reasonable price before they disappear! Stock quantities: NA1 Honda NSX - 1 left: https://www.oemsoko.co.jp/products/1-18-extra-scale-1990-na1-honda-nsx 1973 Toyota Celica LB 2000GT - 2 left: https://www.oemsoko.co.jp/products/1-18-extra-scale-1973-toyota-celica-lb-2000gt 1968 Mazda Cosmo Sport - 2 left: https://www.oemsoko.co.jp/products/1-18-extra-scale-1968-mazda-cosmo-sport 1970 KPGC10 Nissan Skyline 2000GT-R - 2 left: https://www.oemsoko.co.jp/products/1-18-extra-scale-1970-kpgc10-nissan-skyline-2000gt-r
    • When you say basic rebuild, you mean an oem rebuild?
