Rims can be 2 inches bigger than what is stated on the tyre placard.
Wheel track width cannot exceed 26mm from the maximum specified track width of the car in question.
So the MAX track width on, say a R32 GTR is 1506 front and rear.
Edited by CRoNic...
they said the same track width for my 32 gtst when i went through for compliancing.
r32 and r33, both gts-t and GTR, are 1506 front and rear maximum track.
r34 gt-t and gt is 1506 front, 1496 rear, with GTR being same front and 1516 rear
*Thats from the August 08 Edition of "Passenger Car Wheel Track List - 1970 and later vehicles"
nice work bro
cheers :P
i went through regency today. i failed. they picked me on not having my srs airbag lights on when the ignition is on. now i have to get a certificate that says its working from their recommended workshops. so i went and opened the dash up, to find out that there was no bulb in the airbag slot. so i put a bulb in, but when i turned on the ignition it still doesnt go on. can anyone help?
no. ive always had a stock wheel. i checked the abd fuse, it was ok. and i put a bulb in the abs slot. still hasnt worked. i also connected the cable that sits under the drivers seat. yet it hasnt worked.
midlife
i would do that but the thing is, he says it should light up upon ignition - that your idea would fix that, but when he starts it - problem remains as the light would stay on. correct?
luke
i will give that a go.
thanks all
i also need a certificate that abs is working normally, does anyone here work at nissan? or know how much it would cost to get one of these certificates?
midlife
luke
thanks all
Engineer can provide the certificate.
Yep, got defected for my wheels 'hanging out of the guards' but still being in track and legal diameter. That's all he done me for, not to low or loud or ANYTHING other than that. I see that as revenue raising at its finest.
I'll be calling Regency tomorrow morning and explaining the lot to them. The officer even complimented me on how stock my car was! But I still got regency
guys, i went to a mates house yesterday to see if we could sort the airbag light problem. this is what we found...
1. putting another blub in didnt work
2. that there is constant live to the contacts of the airbag slot, as the multimeter shows that power is there but it is pulsing (power going up and down)
3. realised that the pulsing shows that the airbag light would have been flashing (if a blub was in) - hence typical flashing of airbag light ppl on here get
4. disconnected the airbag module that sits under the centre console where the handbrake is and the multimeter showed that power to the abs light slot was on constantly (power steady)
my question is ....
1. firstly, how do i get the light working again?
2. my airbag light (if it had a blub in) is flashing. we have tried the pressing of the door button but that doesnt do the trick. would plugging in a nissan consult be able to reset this or would it just detect that there is an error with the airbags.
3. as for getting a certificate the inspector at regency gave me a copy of repairers they recognise. must i have to use one of them or can i use anyone that can provide me with an engineers certificate. if i was to go to a repairer they recommend, would they just do a visual test to see the light works or would they have to plug in software. cause if they do, bridging the contact would be pointless - i would think.
i know its a long post, but it details what is wrong and any more help would be appreciated.
Edited by Nozila
Not cool.
Usually wheel-related defects, and only wheel related are a cop shop affair. So the cop musn't of liked you to send you to regency!
    • Turbo gods, some assistance and recommendations please I'm looking into a turbo kit for my 2.5 from MX5 Mania >>>>> https://mx5mania.com.au/products/copy-of-mx-5-nc-2-5-litre-engine-conversion-turbo-2005-2013 Power wise I would like about 200kw atw, and of course dose noises, apparently if you keep a stock 2.5 under around 200kwatw the engine and drivetrain will not hate life even when ragging on it a bit Max RPM on the 2.5 is around 6500rpm The turbo MX5 use is something around the disco potato size as  packaging room for the turbo is pretty limited, which will, I believe, give me my power goals I want and not have the turbo either under, or oversized, but the rear housing bit is confusing  It comes with either a 0.64 or 0.86 From my understanding, which so far is based off googling, so make of that what you will 0.64: spools faster = good Makes more EGT heat on boost = bad Less topend power than 0.86 = I'm only looking for 200 atw so that point may be mute????, I don't know, hence my questions  0.86: Spools a "little" slower = how much slower??? remembering 6500 is my max rpm Makes less EGT heat = good Makes a little more power up top = again, power goals is only around 200 Also, this is a street car, so there will not really be any long track sessions, in saying this I would want it so it was happy with at least 3 hot laps at Wakefield Park if the need arises  I already have a fancy pants triple pass radiator, and a oil cooler with thermostat will be getting installed as well Thanks for any information or recommendations you have 👍, and of course, the comments about me wasting money on drive in drive out modifications, or any other snide remarks about my manhood for owning a MX5 🤣
    • Tape some wool onto the vent then take it for a drive I did this to my reverse cowl and was instantly unhappy, as anything over about 60kph would have the wool enter the engine bay, thus just adding underbonnet pressure and stooging my coolant stack, it did let alot of heat out when stationary though, which really didn't help once the car was moving, with the reverse cowl you could watch the coolant temps cheap up the faster you went on the hwy, I assume it would be alot worse doing track day speed With the vented bonnet (just after the radiator and about 1/3 up the bonnet) on my old R33 the wool on the leading edge sat at about a 45° angle as air poured out of it From looking where your vents are, and their size, I believe you should be fine at speed and air should be evacuated from the engine bay, I think it will be a night and day difference when stuck in traffic though for removing the trapped heat, and not sitting there cooking when parked up after driving around... #convection  Post wool tuft pics and data for science  This beastie is one nice and unique rig, enjoy
    • It is possible to do this stuff for "cheap". But you need to be able to get deals on all the bigger items, and it really helps if you're fully capable of doing your own work. As soon as you're paying retail for new parts, or buying "kits" because you can't fabricate necessary bits and pieces, and if you really need someone else to take the reins of doing the work because you don't have the space/time/skills/confidence to  rip deep into the car and put it back together in a working fashions.....then you pay. And these days, pay means a lot of money. You'd think things would get cheaper, but they don't. They just seem to keep getting more and more expensive.
    • It’s almost the price of an engine build, you won’t have anything to bolt onto it though
    • Hopefully it's enough to help with the temps! I was also only shit stirring, regarding Murphy's Law basically. I've found, what ever spare parts I have, are the parts I don't break. Ever. Also have never had issues with oil/spinning bearings until I put oil pressure gauges on the car. 😛
